Collapsable Brazier Design
Submitted: Tuesday, Jun 06, 2006 at 10:06
ThreadID: 34666 Views:10254 Replies:11 FollowUps:21
Hi All
There is mention of a collapsable brazier in another thread and wondering if anyone has a couple of design ideas.
Previous comments are valid in that some National Parks now only allow the burning of "manufactured fuel: i.e. definitely "no timber". Therefore the idea of a collapsable brazier is appealing.
Any thougts ... thanks.
Reply By: Michael ( Moss Vale NSW) - Tuesday, Jun 06, 2006 at 11:06
I guess it will be here in NSW also at some stage.. Its like they dont want you to be there in places you own and pay for. Thats crazy, Even the no gathering of fallen timber here in some parks is stupid. I'm tired of hearing of the burning of small animals homes. What a load of crap. In all the parks i have been in, it is clean on the ground for a few hundred metres around the camp and beyond that its totally natural, thousands of acres of untouched national Park floor. So the cockroaches and spiders will have to move another 100 metres into the bush, so what!!! Michael
AnswerID: 176987
Follow Up By: Member - Bruce and Anne - Tuesday, Jun 06, 2006 at 11:45
And we wander why there is so many bush fires in national parks, and I suppose they say that does not kill the little critters. I was told this morning if you take timber into a national park (Qld) it has to be sawn, not with a chain saw. And we are having trouble that there is no toilets in some popular camping spots, probably cause they do not want to clean them,you have to have a uni degree to get a job with them these days. I would do it for a lot less dollars, but I haven't a uni degree so I cant get a job cleaning dunnies, bugger. Just looking at your rig profile Michael, I had better change mine to "Now thats an Isuzu family" haha.
Cheers Bruce.
FollowupID: 433015
Reply By: Member - Bruce and Anne - Tuesday, Jun 06, 2006 at 11:47
You will have to look in my Rig & Prifile to see what Iam going on about.
AnswerID: 176998
Follow Up By: Willem - Tuesday, Jun 06, 2006 at 14:23
I went to look at you photo gallery and it reminded me of my years in and around Darwin, sloshing through the scrub in the wet season. What fun we had...lol
FollowupID: 433041
Reply By: Sand Man (SA) - Tuesday, Jun 06, 2006 at 11:59
Noel,
I don't believe a brazier is a practical answer.
You can still burn "manufactured fuel" in a campfire surrounded by rocks.
In this way you can still cook & boil the billy on, or in it.
Manufactured Fuel doesn't have to mean heat beads. There is a product on the market colloquially called "fire logs" which provide an excellent and easily transportable alternative to timber.
The "fire logs" burn hot, with much less smoke and leave behind a coal like residue which lasts a considerable time.
After using these recently, I probably won't bother carting firewood any more, even if it's allowed, unless it is convenient to where I'm camping.
Bill
AnswerID: 177001
Follow Up By: Noel W (Qld) - Tuesday, Jun 06, 2006 at 12:40
Thanks Sand Man
All comments appreciated.
When I tried to get a definition of an "open fire" from NPWS officer, I was told a brazier was allowed. I then asked about e.g. a 20lt drum to contain fire and was told "definitely no wood" and "keep it off the ground" i.e. no fire damage to grass or surrounds.
So I still did not get my definition of an open fire but was told in no uncertain terms what I WAS allowed to do in Carnarvon NP. As cold as it wil be, we're still going to enjoy our trip as we have done in the past, even without the comfort of an "open fire".
Thanks ...
FollowupID: 433027
Follow Up By: Sand Man (SA) - Tuesday, Jun 06, 2006 at 14:09
Fair enough Noel.
Just goes to show how some of these idiots create illogical rules.
How the hell is a Brazier (open grill type sides) supposed to be any safer than one on the ground, surrounded by a barrier.
Secondly, how do you put out a brazier before it has self burnt out?...Pea (pee) on it?
Bill
FollowupID: 433036
Reply By: signman - Tuesday, Jun 06, 2006 at 15:04
My swmbo has a collapsible brassiere.....oooops sorry- you talkin about braziers..
AnswerID: 177033
Follow Up By: Noel W (Qld) - Tuesday, Jun 06, 2006 at 15:49
Arrhh signman
So you speak a little French .... me thinks they are all collapsible - given time.
Cheers ....
FollowupID: 433058
Reply By: Alloy c/t - Tuesday, Jun 06, 2006 at 16:39
We made a totaly portable fire pit that takes up about the same space and weight as a 2 burner camping stove,,,made out of old fridge shelves cut in 1/2 widthwise to make 4 panels ,ea panel is 40cm long x 30cm high ,,join panel 1 to 2 to 3 to 4 top and bottom with small hose clamps ,do not join panel 4 to panel 1 ,this allows the panels to stand on edge in a square configuration yet still fold up into a single panel size 5cm thick ,,then covered panel 2 and 3 in very thin ally sheet to act as wind break ,, 1 more 1/2 panel hinged the same way with 2 small hose clamps on top edge of panel 1 or 4 so as not to interfere with the foldingup sequence ,,perfect for toast /small billy ect ,,, have used in nat parks where supposedly "no open fires" ,, never yet had a ranger tell me we are breaking the rules ,, ps ,make sure you burn all the plastic coating from the shelves prior to cooking on the unit,,,,,
AnswerID: 177057
Follow Up By: Noel W (Qld) - Wednesday, Jun 07, 2006 at 15:04
Thanks Alloy.
FollowupID: 433220
Reply By: Jugs - Tuesday, Jun 06, 2006 at 17:16
Saw a great South African invention when I was hitching round Africa. The would get a piece of large down pipe about 200mm Dia and fit a mesh grate about 1/4 to 1/3 from the bottom. The pipe had a series of 25-30mm holes drilled into the bottom 1/2. a jug style handle was added to the out side of the pipe. It was used in a couple of ways if they wanted to get some heat beads up to speed quick, you would put some dry tinder in the bottom and throw you heat beads in on top. light the tinder and the whole thing acted like a chimney with a heap of draw this got an excellent flame going over the heat beads or other fuel to get them all going. You then tipped the lot in to the BBQ pit or brassier for the quickest cooking coals I've seen. If they just wanted a billy it would go straight on top of the pipe. It had a Afrikaans name but I cant remember it.
Jugs
AnswerID: 177063
Follow Up By: Noel W (Qld) - Wednesday, Jun 07, 2006 at 15:05
And to you Jugs. Sounds like another great option.
FollowupID: 433221
Follow Up By: Outbacktourer - Wednesday, Jun 07, 2006 at 16:37
Weber make these, you can get them from BBQ's Galore etc...
FollowupID: 433240
Reply By: Member - Crazy Dog (QLD) - Tuesday, Jun 06, 2006 at 21:35
AVVA squizz at this one.
I have just made one but with a few variations that make it an oven, a bbq plate, a hot water maker, a smoker, even boil s the billy..... A brilliant design by Barry. It works bloody good oh!
Grrr!!!
eck it out</a
AnswerID: 177107
Follow Up By: Member - Crazy Dog (QLD) - Tuesday, Jun 06, 2006 at 21:39
Bugger the link is gone...here tis..
Site Link
Grrr!!!
FollowupID: 433118
Follow Up By: Michael ( Moss Vale NSW) - Tuesday, Jun 06, 2006 at 22:16
Looks like something that fell of SkyLab a few years back!!!
FollowupID: 433129
Follow Up By: Rick (S.A.) - Tuesday, Jun 06, 2006 at 22:26
Crazy Dog,
that link takes me to Darian's site, not you pic.
try again?
FollowupID: 433132
Follow Up By: Noel W (Qld) - Wednesday, Jun 07, 2006 at 07:53
Crazy Dog
I've been pondering the use of an old gas bottle for some time. Maybe not collapsible but you have convinced me to continue with this project in any case.
Many thanks ...
FollowupID: 433151
Follow Up By: Noel W (Qld) - Wednesday, Jun 07, 2006 at 08:43
Oops ... forgot to ask ... any photos of yours?
FollowupID: 433157
Follow Up By: Pajman Pete (SA) - Wednesday, Jun 07, 2006 at 09:58
Try this
Nice setup
Pete
FollowupID: 433175
Follow Up By: Noel W (Qld) - Wednesday, Jun 07, 2006 at 17:12
Crazy Dog
I love the "Chad Morgan" lookalikes in your photo gallery! I'll bet they croon on a full moon.
Cheers ....
FollowupID: 433249
Follow Up By: Member - Crazy Dog (QLD) - Wednesday, Jun 07, 2006 at 21:51
Guy's guy's guy's (and any girls who are interested)
When it is complete I will post pics ok - so hold ya "orses OK!
Grrr!
FollowupID: 433345
Reply By: Noel W (Qld) - Wednesday, Jun 07, 2006 at 07:55
Thanks to everyone for contributing to this thread. On with the project ...
Happy camping ....
AnswerID: 177154
Reply By: Grizzle - Wednesday, Jun 07, 2006 at 09:36
I bumped into a guy who made collapsible braziers for all the reasons you spoke about. It was a couple of years ago but I could possibly get his details if you are serious and not just kicking ideas around.
AnswerID: 177169
Follow Up By: Noel W (Qld) - Wednesday, Jun 07, 2006 at 09:50
Thanks Grizzle
I sure am serious because I only have a small vehicle and need something compact for when travelling.
Many thanks if you can get some more information.
FollowupID: 433171
Follow Up By: Grizzle - Wednesday, Jun 07, 2006 at 14:53
Have left a message on his mobile. I will let you know when he calls back
FollowupID: 433215
Follow Up By: Noel W (Qld) - Wednesday, Jun 07, 2006 at 17:04
Thanks Grizzle
It looks like my options are increasing so am looking forward to what you can get hold of for me.
I will make one out of a gas bottle as well for use closer to home.
Plenty of assistance out here when you need it hey! Thanks again for your efforts.
FollowupID: 433247
Reply By: Russel & Mary - Wednesday, Jun 07, 2006 at 12:06
We ran into a chap and his wife up near Ned's Corner on the Murray last Easter. This may have been this Barry. He showed us his 9kg gas bottle camp fire set-up. It looks like the link photos. When I get my hands on a spare bottle, I'll do a similar thing. One tip he said about cutting the bottle with an angle grinder was to take out the tap and fill it with water so there's no gas in there. Leave the water in while you cut it open, a bit will seep out as you get a cut through but won't hurt anything. Rus.
AnswerID: 177205
Follow Up By: Noel W (Qld) - Wednesday, Jun 07, 2006 at 15:02
Thanks Rus ... I'm gonna have a crack at this myself as well.
FollowupID: 433218
Reply By: Jugs - Thursday, Jun 08, 2006 at 10:23
When ever I go to the wast exchange they have a spot for old out of date gas bottles next to the scrap fridges etc that they don't want in the compactor. I know its getting harder to get this stuff out of the wast exchanges but it may be a source.
Jugs
AnswerID: 177411
Follow Up By: Noel W (Qld) - Thursday, Jun 08, 2006 at 11:46
Thanks Jugs
Just got back from picking up 2 old cylinders the local gas supplier didn't want - no charge. He was glad to get rid of them.
FollowupID: 433485
