L.E.D's and tail lights.
Submitted: Tuesday, Jun 20, 2006 at 17:30
mattfinish
G'day there, I recently posted some questions regarding firing up my dummy GU IV Patrol tail lights. Someone suggested using L.E.D's instead of standard globes. I checked out the link they kindly provided. They looked the go, clusters of 8 diodes so they should be pretty
bright you would think. Somebody else said they tryed some from J-car and they were to dull during daylight.
*Are they best only used with earlier patrols with the clear tail light lens?
*Are they worth the $50 for the set required?
Anyone who has had some experience with these much toted little diodes, please let me know!
Reply By: mattfinish - Tuesday, Jun 20, 2006 at 17:38
www.ledshoponline.com/ Is the link given to me. Check them out see what you think.
Cheers Matt.
179494
Follow Up By: Wisey (NSW) - Tuesday, Jun 20, 2006 at 21:10
Matt
I've got some pics of my ute with led's and with standard. The way my lights are designed is typically for the reflector to do it's thing with full illumination on it, but the led's don't utilise any of the reflector.
Send ya addie and I'll send the pics
Andy
435734
Reply By: revhead307 - Tuesday, Jun 20, 2006 at 17:59
Hi Matt,
What benefit are you chasing from LED's over standard?
LEDS have their uses, low power draw, very long life (probably never need replacing etc)
but in the application of tail lights on a 4x4:
I've never had to replaced tail lights on any vehicle I have owned (granted, holding period is limited to 5 years max).
As for current draw they are excellent for trucks who run multiple running lights etc...but the power saving will be so negligible it wouldnt be a consideration.
Im sure the LEDS would do a fine job but for my money, i'd buy a carton with the difference.
Rev
179496
Reply By: Martyn (WA) - Tuesday, Jun 20, 2006 at 19:53
Mattfinish,
I fitted LED's to my Patrol, dim during daylight is an understatement, if you buy the right reflectors to go with the globes they work, this is one very important detail they don't mention when buying the globes. Plus if the globe faces out, you are better off than a globe that faces the reflector or some such similar design.
For my money and what I know now I would rather spend the difference on a carton or maybe some very expensive fuel as mentioned earlier.
If you want some to try I've got some sitting in my shed for a small fee you can buy them and try them I don't require them any more.
179513
Follow Up By: geordie4x4 - Tuesday, Jun 20, 2006 at 20:06
Thanks Martyn,
I was looking for some to fit my Pathfinder and a boat trailer as I figured they would be better than standard globes. Newer isn't always better. Took your advice and I got a carton instead.
435725
Reply By: Sand Man (SA) - Tuesday, Jun 20, 2006 at 20:22
geordie,
Now that you have mentioned a boat trailer, I can recommend LED trailer lights.
They are Maxilite brand and are available from AutoPro stores for about $40 each.
They are about 115mm square and should fit most trailers.
I got sick of the old lights. The globes made poor contact with the terminals from time to time and proved to be less than adequate.
179523
Follow Up By: Member - Alanc - Tuesday, Jun 20, 2006 at 23:19
I'll second that - I have LED lights on my camper and they are as
bright as. Not sure of the brand but there are four separate lights , 2 x red brake & 2 x
orange flicker with each being about 80mm square.
Since fitting these LED lights I have not had any light problems when hooking up the camper, with bulbs I was never sure they would work.
435789
Reply By: Barnesy - Tuesday, Jun 20, 2006 at 22:52
I converted the dummy lights on my GQ II to tail/brake lights. the dummy lens is slightly tinted and standard globes are dull during the day but not bad at night, certainly more useful than dummy ones.
I got 1 LED to see what it was like-waste of 20 bucks. barely enough light to get through the lens, they were more dull at night than the globes were during the day!
Needless to say the standard globe went straight back in and i'm currently trying to find use for the LED so my money isn't completely wasted.
Barnesy
179574
