Coleman stoves
Submitted: Monday, Jul 10, 2006 at 18:43
Member - Crazy Dog (QLD)
On my post about gas stoves it was suggested that the Coleman was the go as
well as the cheapie chinese things. Is the number below the model we are talking about with the Coleman because the adds state high pressure therefore jets I presume...can someone clear this up please...
Grrr!!!
Model No: 5430B700A is the one I spotted on the Coleman site...
Reply By: Sand Man (SA) - Monday, Jul 10, 2006 at 19:09
Yes, that's the one Crazy. The "high pressure regulator" is misleading.
Basically the regulator (very compact) attaches to the gas bottle andthe other end to the stove. Two 10,000 BTU burners.
But it is all Low Pressure.
There is also the same stove with electronic ignition model available. (5435C700A)
182764
Follow Up By: Member - Crazy Dog (QLD) - Monday, Jul 10, 2006 at 19:34
Thanks Sand Man - By the way I was born and bred at the "Bay" so I know Crow eaters pretty
CYA!
Grrr!!!
439213
Follow Up By: Mike Harding - Monday, Jul 10, 2006 at 19:34
Ah! In that case that's my stove (with electronic ign). Terrific stove works very
well from -5C (not too much of that in
Cairns I suspect :) to 45C+. Only complaint is that the top plate and it's finish make the stove hard to clean. Should be around $130?
Mike Harding
439214
Follow Up By: Member - Crazy Dog (QLD) - Monday, Jul 10, 2006 at 19:39
Your right Mike - not even in the beer fridge - but heh it does get cold here - last nite 17 degrees - froze my rrrrr's orf..... LMTO....
Ok gents I now will be the proud owner of 2 stoves - 1 Coleman and 1 cheap chinese one..
Thanks fella's....
Grrr!!!
439215
