Virtual travel...frustrating
Submitted: Tuesday, Aug 08, 2006 at 12:16
ThreadID: 36583 Views:2858 Replies:7 FollowUps:12
All this Google Earth stuff sounds cool. Just zoom in and presto, you're there.
So I install broadband and away I go. Yep, zooms on bits of Sydney. Oz...but wait a minute...those big green rectangles dont allow me to see anything ...and how do I know where I am ? Do I need a new video card or something ...is there a "local " version ? Do I have video *issues* ? (or just old timers:)
So far I THINK I can see the Kidson track in WA but I'm not sure.
Even with all the expensive bits I'm now going to be advised to get, what are the practical constraints of Earth for the average at home user?
I can see it might be quite useful for pre and post trip planning if only I knew what I was looking at :))))
Reply By: GoneTroppo Member (FNQ) - Tuesday, Aug 08, 2006 at 12:19
You and me both.
I looked at it and found it worse than useless.
I'll be interested to see what comes out of your question.
AnswerID: 187827
Follow Up By: Footloose - Tuesday, Aug 08, 2006 at 12:23
Hey, my first reply didnt tell me I'm a complete idiot....thanks.
Good to know that I'm not the only one that hasn't been able use its full potential :))))))))
FollowupID: 445084
Reply By: Sand Man (SA) - Tuesday, Aug 08, 2006 at 12:31
Footy,
The free Google Earth you can download and install lacks the search feature applicable to the U.S.A.
What I do is do a search on NATMAP PREMIUM first, which gives me the approximate co-ordinates, then type these into the Google search window to zoom in on that location.
A little tedious but it works.
I don't know if Google Earth Plus will give you much more, no one I know buys it.
Bill
AnswerID: 187831
Follow Up By: Footloose - Tuesday, Aug 08, 2006 at 13:02
Thanks Sandman. Took me a few goes but I finally got it.
FollowupID: 445095
Reply By: Member - MrBitchi (QLD) - Tuesday, Aug 08, 2006 at 12:55
The big green patches are where there is no high res data. These are gradually dissapearing as they take more satelite images. Nothing wrong with your system ;-)
To get real value from it you need to get the subscription version. The freebie is just a casual tool.
AnswerID: 187835
Follow Up By: Footloose - Tuesday, Aug 08, 2006 at 13:01
Ahhhhh....so, no high res pix of Razorblade Bore. How can that be ? heheheheh
Many thanks, thought I was doing something wrong .
FollowupID: 445094
Reply By: Penguin (NSW) - Tuesday, Aug 08, 2006 at 13:07
I recently downloaded a GPS interface to Google Earth. It's called Earth Bridge. It's at mboffin.com/earthbridge. I'm not suggesting that it's a replacement for DiscoverAus or OziExplorer but it's pretty neat.
After installation I connected my Magellan and fired up Google Earth - lo and behold it pointed to where I was (well not exactly, I was allegedly in the next door neighbour's tree but close enough).
Has anyone else played with this or a similar program? I haven't tried it yet whilst moving but I imagine I won't get too far without internet connectivity.
AnswerID: 187840
Reply By: Scoey (QLD) - Tuesday, Aug 08, 2006 at 13:46
I use Google Maps as an alternative. No special program required, no downloads etc. You can select between street level maps and then throw on the Sat Image layer over the top. Piece of cake! ;-)
Scoey.
AnswerID: 187846
Reply By: mfewster - Tuesday, Aug 08, 2006 at 14:16
If you fit a hiclone in your computer you will find that you can see everything much clearer.
AnswerID: 187847
Follow Up By: Footloose - Tuesday, Aug 08, 2006 at 16:48
I fitted 2 and now I don't need my glasses !
FollowupID: 445117
Follow Up By: Gramps (NSW) - Tuesday, Aug 08, 2006 at 17:18
Fit a f***h and you won't sleep either (HWNMNBM will be along soon if I fill in the *s ).
FollowupID: 445122
Reply By: The Explorer - Tuesday, Aug 08, 2006 at 17:02
Google Earth integrates well with OziExplorer - you can export your tracks and waypoints onto the Google map. You can also mark points on Google Earth and import them into OziExplorer - handy
AnswerID: 187877
Follow Up By: Footloose - Tuesday, Aug 08, 2006 at 17:04
Thanks Greg, that's worth knowing
FollowupID: 445120
Follow Up By: V8 Troopie - Tuesday, Aug 08, 2006 at 20:57
Greg do you know if there are 'instructions for dummies' somewhere, to do what you suggest. I would like to give it a go but am easily confused with importing/ exporting files.
FollowupID: 445187
Follow Up By: The Explorer - Tuesday, Aug 08, 2006 at 21:37
Hello - very simple (just click buttons:) - firstly you must of course have Google Earth installed and working..
earth.google.com/
and a recent version of OziExplorer ..which I figure you already have but..(not sure if non-registered version works but you never know your luck)
www.oziexplorer.com/
Within OziExplorer load waypoints or track files and then use the icon along top of screen - Save - Export To Google Earth - then click on the View Data in Google Earth icon at top of dialog box and it all happens automatically.
Oziexplorer will also import saved KML files (ie saved points from within Google Earth or from saved OziExplorer file). You cant import kmz files (compressed kml files)
Hope this gets you on your way
FollowupID: 445201
Follow Up By: V8 Troopie - Thursday, Aug 10, 2006 at 00:26
thanks Greg, the first part worked like a charm (once I worked out just where the 'buttons' are located !) but it has me bamboozled regarding the import of kml files.
Google earth saved my placemarks (which I arranged as a 15 point route - on Shark Bay) as a kmz file which, as you said, can't be imported into oziexplorer.
What I am trying to do is place marks in the deep channels visible on the google earth images and then upload these into my GPS as waypoints via the oziexplorer program. Can't do that on my electronic charts as it says "inadequately surveyed" at the areas of interest, where I can clearly see deep channels on the satellite image. I recently sailed along such a channel but it was hit and miss a lot of times.
So, how do I get google earth to save my placemarks as a kml file?
BTW, I just have the latest version of the free google earth program and a registered oziexplorer.
Many thanks,
Klaus
FollowupID: 445516
Follow Up By: The Explorer - Thursday, Aug 10, 2006 at 09:28
Klaus - as you have obviously already done - create a placemark on the location you want - it will appear in the listing on the left hand side under PLACES with a default name of "Google Earth - New Placemark". Right click on the name and a menu will appear - one of the options is SAVE AS - click on this - it will then open file explorer and ask where you want to save the file on your PC - default option is to save as a kmz file - click on the arrow next to SAVE AS TPYE box - you can then choose kml as the file type.
FollowupID: 445549
Follow Up By: V8 Troopie - Thursday, Aug 10, 2006 at 21:48
Greg, you are brilliant with simple explanations for people like me. It worked a treat and I now have a stack of new waypoints in my ozi file.
Have you found away around the idiotic way that the placing of placemarks in google earth works? It seems to place the mark in the middle if the image and I can only move the image about, and not the placemark. It would be simpler if one could twitch the placemark on an image that remains fixed.
I thought of putting a texta mark on the screen but am worried in case it won't come off later.
So, how do you place the placemarks accurately on the google images?
Klaus
FollowupID: 445688
Follow Up By: The Explorer - Thursday, Aug 10, 2006 at 22:43
Klaus - glad to see you're having fun - havent actually used GE much myself but it certainly is amazing. Ok.. with respect to placemarks - after clicking once on the "Add Placemark" icon a placemarker will appear on the screen with a yellow flashing square - left click mouse on this and you can adjust position more accurately. Note: I have found GE to be slightly out (+/-50metres or so) with respect to co-ords/plotting tracks and waypoints in some instances - so keep that in mind.
FollowupID: 445698
