CT kitchens and storage
Submitted: Wednesday, Sep 20, 2006 at 00:20
ThreadID: 37865 Views:4759 Replies:4 FollowUps:6
Hi All,
Just found this site loads of info it's great. i have just brought a new cavalier camper trailer I'm looking at building storage system and kitchen. I really like the drifta system but the dollars are hard to find now days. So i was wondering if anyone has any other ideas, plans, other system etc......... any help would be greatly appreciated :) THANKS
Reply By: Sand Man (SA) - Wednesday, Sep 20, 2006 at 09:09
Hey there Turtle.
Don't have any plans for you, but some people have had success with a system called Cubelock. This consists of sections of extruded aluminium tubing that is assembled using plastic corners, etc. Used in combination with plywood sheeting, you end up with a flexible and easily built solution.
Bill
AnswerID: 195471
Reply By: XLGXL - Wednesday, Sep 20, 2006 at 09:58
Check this site out www.campertrailers.org/
AnswerID: 195475
Follow Up By: Turtle SA - Thursday, Sep 21, 2006 at 13:06
Thanks for the link great site:) very helpful.
FollowupID: 453814
Reply By: Member - Craig D (SA) - Wednesday, Sep 20, 2006 at 10:49
Qubelok is the go - available from Capral Aluminium, Wingfield.
!MPG:9!
AnswerID: 195480
Follow Up By: JAS095 - Wednesday, Sep 20, 2006 at 11:40
Craig a great looking system there mate you have now got my brain ticking over was going to use MDF for the whole lot but was a bit concerned about the weight. what sort of price is the materials and have you used draw rollers to help get the wooden _Affordable_Storage_Drawers.aspx out and what type of latching system have you used once again very impressive.
FollowupID: 453581
Follow Up By: Member - Craig D (SA) - Wednesday, Sep 20, 2006 at 12:29
Guys, the aluminium is 25 mm square and comes in 6.5m lengths for about $22, with nylon joiners about $1 each. The joiners are simply banged into place with a rubber mallet. I have Capral cut the aluminium into thirds so I can get it home (they don't charge for this that I know of) or they will deliver to your home for a fee.
The drawer rollers are on roller bearings and came from Elraco Hardware which is an on-line hardware store in Adelaide. The runners were $12 each and were deliverd within 24 hours to my doorstep. The rollers are attached to 16mm MDF inside the framing. Qubelok also comes with a lipped version for this purpose. The rollers are self latching so I haven't had to provide any other latching (they haven't come open yet after bashing on corros).
The kitchen in the above photo also has 6mm MDF top, 10mm ply sides and 12mm back panels lined with marine liner carpet (hard to see in the pick). This allows me to screw accessories into the sides and hold/tie down points on the back. The whole unit is through-bolted to under the camper.
The _Affordable_Storage_Drawers.aspx are made from cheap builders ply form Mitre 10, but come up really good with a bit of sanding so I wouldn't worry about the expense of Marine Ply (one wrong cut and I'd cry!).
I have attached another pair of piccie's that should explain the above a bit better.!MPG:10!
!MPG:11!
Hope I have been of some assistance - by the way, I had to scratch my head for quite a while just tocome up with this simple outcome.
FollowupID: 453585
Follow Up By: oldbaz - Wednesday, Sep 20, 2006 at 15:56
Great looking setup, Craig..I have just finished my kitchen, bit smaller scale.
Made of 12mm mdf to slide in the trailer on same side tailgate swings. Not as good looking as yours, cost me under $100 & seems to work Ok. Untested in the wild yet. Probably only half the height but uses all the available height available.
Sorry no pics, not digitiesed yet, spent the dough putting together a CT....Baz.
FollowupID: 453627
Follow Up By: Member - Pesty (SA) - Wednesday, Sep 20, 2006 at 18:34
That shows it better than in the flesh on the w/e LOL.
Didnt take you long to get trol pic with golf ball up ? hahahha
Hope you enjoyed your w/e.
Cheers Pesty
FollowupID: 453660
Follow Up By: Member - Craig D (SA) - Thursday, Sep 21, 2006 at 08:24
Cheeky bugga :)
Yep, had a ball thanks Pesty. And I couldn't wait to stick up the new rig pick...as it's something you don't get to see every day is it?
Cheers.
FollowupID: 453758
Reply By: Turtle SA - Thursday, Sep 21, 2006 at 13:12
Thanks.... what a great idea (Qubelock) back to drawing board i guess and try to work out a system :) Thanks for all the input.
AnswerID: 195695
