Weber Cooking
Submitted: Friday, Oct 27, 2006 at 16:12
ThreadID: 38880 Views:14499 Replies:6 FollowUps:0
I have just got a second hand Weber and would like some recipes and cooking tips.
Its a 21 inch cooker, my first attempt was not bad, but it should be better.
Things like number of heat beads to use, cooking time.
If I get good at it I will invite you over to try it.
Reply By: Jodi - Friday, Oct 27, 2006 at 16:30
I love cooking a chook on the webber at home. There's nothing like it. I stuff a couple of lemons up its bum, sprinkle steak spice over the skin. Get the webber going with those easylite heat beads, let them burn to white. Put whole potatoes in their jackets not wrapped in anything on the grate at the edge but not directly above the beads, put lid on. Half hour later put chicken directly on grate. Lid on. Hour later all should be done and ready - just need the wine, some steamed green vegies and a good gravy. All washed down with a homemade stickydate pudding. Nothing like it on a fat sunday night.
Lamb - I always use the leg withthe bone still in - it doesn't dry out as much.
Stab holes in the lamb and stuff with minced garlic and fresh rosemary leaves. Put on rack in webber with potato as above - all goes on at same time though. Squirt honey all over lamb and potatoe. More honey about 40 mins later. Should all be ready in another 40ish mins (depends on size of lamb).
Make sure all holes are always open while cooking. Close all holes at end to put beads out.
I nearly use the whole bag of beads split between both sides. But I know that is way overkill. I'm just a pyromaniac.
AnswerID: 201271
Reply By: Jodi - Friday, Oct 27, 2006 at 17:07
Now you've gone and got me thinking about it. I'm going home to cook a chook on the webber for dinner.
That's another thing I forgot to mention. The left over carcass and meat from the webber chook is great the next day used in the slow cooker to make a soup.
AnswerID: 201279
Reply By: Sand Man (SA) - Friday, Oct 27, 2006 at 18:55
Hey Wato,
Go direct to the Weberbbq Web Site. Do not pass go, Do not collect $200.
www.weberbbq.com.au/
This site gives cooking times for different meats and the quantity of heat beads to use, etc. Also some good recipes to get you started.
Pretty well all roasting type meals you use the indirect method where the heat beads are located at both sides of the kettle rather than in the middle as for the direct method used for BBQ'ing.
I had a quick read and was surprised at the suggested number of heat beads.
Enjoy your experimenting mate.
My "workshop manual" that came with the Weber recommended 22 heat beads each side and I always had success with this quantity.
I hardly ever use the Weber now though as I prefer the simplicity of the Cobb Cooker, even at home.
Bill
AnswerID: 201292
Reply By: Muddy doe (SA) - Friday, Oct 27, 2006 at 20:36
Hi wato
Webber also put out a cookbook that came with it so you maybe able to source one of those from somewhere or try the person that sold it to you.
Happy cooking!
Cya
Muddy's Significant Other
AnswerID: 201315
Reply By: coll964 - Saturday, Oct 28, 2006 at 11:00
Bets move we did was convert our Webber to gas - same taste, less hassle with heat beads etc.... We picked a second hand Webber BBQ book up from the used bookshop - worth a look ??
AnswerID: 201405
Reply By: wato35 - Monday, Oct 30, 2006 at 10:04
Thanks all for your replys.
Wato35
AnswerID: 201763
