Welding plastics - need some advice,,,
Submitted: Thursday, Dec 07, 2006 at 19:01
ThreadID: 40152 Views:4406 Replies:9 FollowUps:4
G'day you "know alls",
That's what I like about this forum - there's always an exper somewhere on here.
This time I need an expert on plastics and plastic welding.
I have an old 80 litre plastic water tank off my old camper trailer. It has a small split in it, There are many differnet types of plastic on the market these days - polyethylene, PVC, HDPE etc,etc, I don't what can be welded and what can't.
This tank would make an ideal additional tank on my Supreme Offroad van, but I'd need the split patched up, some nozzles welded shut and some extra nozzles put on.
Can it be done?
Thanks - as always,
Bilbo
Reply By: GaryInOz (Vic) - Thursday, Dec 07, 2006 at 19:15
Without knowing what sort of plastic it is, I can't really suggest any repair ideas, other than to take it to a boat chandler and see if they have any ideas on repairing it.
If it has split there is a good chance the plastic is degrading and may not be viable for a patch anyway. If I was carrying water in something on a decent length trip, I would want to make sure it wouldn't dump it's load out in the middle of nowhere.
Safest bet would be to buy a new one and know exactly where you stand with it, it really is something you do not want to go wrong...
AnswerID: 209181
Reply By: Member - Crazy Dog (QLD) - Thursday, Dec 07, 2006 at 19:52
Aaba Industries WA
7 Redfin Pl Beldon WA 6027
ph: (08) 9403 2114
map
All things Plastic
Wellard WA 6170
ph: 0412 357 938
advertisement
Amaroo Auto Coat
12 Lockhart Street Kelmscott WA 6111
ph: (08) 9497 1515
map
Complete Plastix Services
52 Elgee St Bellevue WA 6056
ph: (08) 9250 6055
map
Katana Plastics
Unit 8/ 15 Carbon Crt Osborne Park WA 6017
ph: (08) 9244 1691
advertisementmap
Plastonics
15 Newlyn St Belmont WA 6104
ph: (08) 9277 1737
map
Polytech Plastics Pty Ltd
Unit 12-13/ 6 Hayley St Maddington WA 6109
ph: (08) 9493 0300
map
Sandgroper Plastic Welders
Hope Valley WA 6165
ph: (08) 9410 0520
Try these mate - in Perth
LOOK UP SEARCH YELLOW PAGES on the tool bar of your browser. The rest is easy...
Grrr!!!
AnswerID: 209183
Follow Up By: Max - Sydney - Thursday, Dec 07, 2006 at 20:02
And hopefully they will be ethical enough to tell him that if its got one split its probably only good for the recyclers as the rest will be going too.
A few years battering and bouncing of water in the tank have probably done a great job of starting cracks in all the weak spots like around outlets, support points etc.
Maybe look up "plastics recyclers" for him! LOL
FollowupID: 469185
Reply By: Wayne (NSW) - Thursday, Dec 07, 2006 at 20:39
Bilbo,
I have repaired a plastic 4wd battery that split and lost some acid. After the repair the battery was topped up again at it was good enough to get us home.
Also a 1000lt plastic water tank at work. The boss was going to through it out so there was nothing to lose by welding it up. We are still using the tank to-day a year after the repair.
A small piece of plastic as a filler. A plastic coke bottle top can be used and a soldering iron.
Melt the plastic on to the split and at the same time melt the split together.
Wayne
AnswerID: 209191
Reply By: Neil & Pauline - Thursday, Dec 07, 2006 at 21:21
I have done some welding repairs using an electric soldering iron and the same plastic as the original. Was slow and have sometimes needed to redo.
It is possible to buy plastic welding gadgets that work as quick as a metal welder. A small unit is about $300 so I guess there must be more people out there with them now because it used to be very expensive 10 years ago.
By the way I am not an expert but just a farmer (ex farmer now) getting things to work again when the shops have shut early because of daylight saving.
good luck
Neil
AnswerID: 209198
Follow Up By: Sand Man (SA) - Thursday, Dec 07, 2006 at 21:57
but, but, but,
The shops should be open an hour later when it's Mickey Mouse time.
Bill
FollowupID: 469204
Reply By: slush - Thursday, Dec 07, 2006 at 21:47
most older crash shops would have this kind of thing, the old guys like to repair not replace. there called real tradesman.
AnswerID: 209202
Reply By: Bilbo - Thursday, Dec 07, 2006 at 22:27
Hmmm,,,,,,seems like there's a few on here that take a dim view of an attempt to recycle and save money too.
The split was caused by a hose nozzle that was being forcibly bent out of line by rubbing against the trailer chassis. So I thought it might be recoverable.
Thanks to those that contributed helpfully. The others must be part of our "consumer society" eh?
Bilbo
AnswerID: 209207
Follow Up By: Member - Michael J (SA) - Friday, Dec 08, 2006 at 07:52
G'day Bilbo,
I don't qualify as any sort of expert...lol, but what about sealing it with a hot glue gun???
Have no idea even if it is practical, but someone here will tell me;))))
Seems to stick like the proverbial to a blanket.
Michael
FollowupID: 469222
Follow Up By: Heefers - Friday, Dec 08, 2006 at 08:05
And if you're worried about strength, rivet a small ally patch over the split to brace it up. That combined with a good dose of silicon sealant will get you going again. May not look like the worlds flashiest job but certainly functional.
Cheers Heefers
FollowupID: 469224
Reply By: Member - Athol (NSW, 2527) - Friday, Dec 08, 2006 at 06:15
Bilbo,
Try some of the bigger plumbers/suppliers they should be able to help. I had some welding done on some PVC pipe last week, they supplied the filler rod the guy has an elec heat gun and just uses it as you would an oxy torch. If they dont have the matching filler rod they can use a bit of the parent material as filler.
Not rocket science and I thought to myself, mmm!! there could be a market for this but I'm to old to go starting a new line of work.
Athol
AnswerID: 209222
Reply By: galfeysteve - Friday, Dec 08, 2006 at 13:31
Hi Bilbo,
Some years ago whilst working in a chemical plant,i attended a one day plastic welding course.The instructor showed us the 2 ways to identify the plastic so as you knew which filler rod to use.You need to burn a small piece in a gas flame and if it smells like candle wax from memory it is polyetylene and if it burns with green flame it is pvc.Specialist plastic weld mob probably best bet.The biggest question is why did it crack in the first place,followed by will it crack again or somewhere else? I currently work as a boilermaker/ welder in a steel manufacturing plant and i always ask myself these questions before attempting any crack repairs on heavy equipment or machinery.Your tank may be breaking down through age or not being mounted correctly.Steve
AnswerID: 209286
Reply By: Hairy - Friday, Dec 08, 2006 at 13:52
Gday,
the only way to determine what sort of plastic it is is to do a couple of tests.
1.Cut a small piece off the seam or something you can afford to cut off.
2.Light it with a cigarette lighter and note a) The colour of the smoke.
b) The smell
d) Weather it drips or not as it melts.
I cant remember off hand which one is which but if you buy a test pack of rods from someone like BOC gases and do a comparison you can work out which filler rod you need to use.
Most plastics can be welded as long as you find the right filler.
I personally wouldnt muck around with a soldering iron or anything. If you cant borrow a plastic welder Id take it to someone who has one.
Let me know if you need more info and Ill dig out my plastic ID chart.
AnswerID: 209288
