My car fridge idea
Submitted: Monday, Jan 01, 2007 at 22:07
F4Phantom
I was in anaconda looking at engel and waco next to each other and for around $1500 you get this crappy little space that really does not look like it holds a lot of stuff. Anyway you can get a quality bar fridge for around $200 (or more). They hold a heck of a lot more stuff. So what I am thinking is just run an inverter and mod the door to make it 4x4 travel friendly. The only downside I can see is that the vibration may not be good for a bar fridge.
The question is, can anyone tell me why this idea would not work??
Thanks.
Reply By: F4Phantom - Monday, Jan 01, 2007 at 22:09
some examples
Site Link
Site Link
212790
Follow Up By: Gold Member (WA) - Monday, Jan 01, 2007 at 22:49
F4phantom
Personaly i wouldnt bother i reckon the vibrations would kill it in no time and it probly cause the inverter alot off stress over long periods. Anyway as they say its not the size of the fridge that matters it how you use it (stack it).
Cheeeeers
472993
Follow Up By: Philbee - Wednesday, Jan 03, 2007 at 21:47
Gday,
well l reckon most of the cons have been covered, one other though, when talkin' bar fridge they are upright generaly? not real space saving in a 4wd and laying it down would have to remove air flow from the condenser? and the door is quite large on a bar fridge, I have a waeco 90 litre fridge freezer sitting on a outback draw system, the fridge door doesn't open all the way in the car and slid out it hits the tail
gate, but the best thing l have bought, worth every dollar, they may look small when your standing over them in the
shop but you be surprised how much you can get in there, ok you cant get a family size Papa Giuseppe in the freezer part but enough room for frozen meat, veg etc... for 2 for a week, the fridge has enough room for me to get a dozen cans without upsetting the rev limiter, pee her off and i get no food.
Phil...
473377
Reply By: Member - Phil G (SA) - Monday, Jan 01, 2007 at 22:58
We own one of the 50litre bar fridges - identical to your Ebay example above (except we paid $99 for ours, not the Ebay special price of $179 :-)))
It has "Input 85watts" written on the back. I just hooked it up to a car battery, an inline ammeter, and my 300watt inverter, and it wouldn't run. The inverter was pulling over 25amps and going hot after just 20 seconds. I think you'll find they need way too much current to start. They would also flatten a battery in no time. They'd also fall apart.
I guess thats why nobody does it. Having said that, I think Reefer Fridges use an inverter (or they used to).
212797
Follow Up By: Member - Jason S (SA) - Tuesday, Jan 02, 2007 at 02:18
Agree with you Phil.
The other issue is the amount of 'wasted' power that would be used by the extra cables and inverter.
The VERY strong advantage of my Engel and the reason I spent the cash was for the 'Swing' motor. This thing only draws 2.5 amps flat out in the middle of the
Simpson Desert on a 50 degree day.
Beat that and I will buy it!
Jason
473007
Follow Up By: Mainey (WA) - Tuesday, Jan 02, 2007 at 12:18
Well yes, the "original" Liemack did use a 300 watt inverter :(
However the present day Reefer PREMIER uses a completely different electronics system to the Liemack, using an 'electrical device' referred to as a "motor starter" it supplies 240v without the sudden large start up current associated with _ALL_ 240v motors, this is closely controlled by the 'motor starter'
The Reefer Premier also has the benefit of a built-in battery charger that will recharge the Auxiliary battery.
Jason, I believe your Engel will run continuously when in 50 degree ambient temp, there are many & various 'test' results that have shown the resultant numbers, but that will only start another argument :)
473033
Follow Up By: Member - Jason S (SA) - Tuesday, Jan 02, 2007 at 21:25
so are you saying that by using an inverter to power the bar fridge will be better than my Engel?
I am reading your post but I am not getting the information the original post asked for.
Are you for or do you see issues with the suggested method??
I am not sure you 'get' it
473114
Follow Up By: Mainey (WA) - Wednesday, Jan 03, 2007 at 00:54
Jason,
I would NOT use a conventional 240v bar fridge running from an inverter !!
473149
Reply By: Willem - Monday, Jan 01, 2007 at 23:01
Methinks that a Bar fridge was intended to stand quietly in the bar and do its job.
It would probably shake to bits after a short time. Then again you could buy 5 bar fridges @ $200 each for the price of and Engel or Waeco....lol
I wonder why there is this urge to carry even more stuff in fridges out bush.
BTW those bar fridges are only 50litres in size...the same size as many of the E or W brands
212798
Reply By: Dave McC - Monday, Jan 01, 2007 at 23:15
Unfortunately the vibration on would do damage the fridge, and the contents of the fridge such as bottles bouncing around will break the fragile interior of a bar fridge.
A bar fridge would not operate efficiently as a waeco or engel in a 40+ deg temps ie. a car parked in the sun/direct sun on the fridge
An inverter will result in 5-15% loss of power when converting to 240v.
engel's and waco's are manufactured to specifically address these issues, thus the extra $$$'s
212800
Reply By: troopywanderer - Tuesday, Jan 02, 2007 at 03:28
A lot of caravan use a normal house fridge or frezer running on 240v
Most caravan are much poorer suspended than cars or 4wd and most do not have shock absorber. These house (bar) fridge seems to survive OK.
212812
Follow Up By: F4Phantom - Tuesday, Jan 02, 2007 at 09:28
I have come to the conclusion that a regular fridge would probably be just fine with the whole vibration thing. I think as per the above post power could be a problem but I would still like to give it a go to see for myself. If it all works out dandy I will make another post of it later on. If my car burns to the ground I will do another post bitching about how no one told me it would not work.
473018
Follow Up By: Chucky - Tuesday, Jan 02, 2007 at 09:49
Just bear in mind that if the fridge coolant lines break you are going to have a car full of oxygen displacing refidgerant inside your car.
You most likely wont here it escape casue of the road nosie and may even not smell it.
Considering the fridge isn't designed to handle the stresses of constant travel, I wouldn't run the risk.
473021
Reply By: Member -Signman - Tuesday, Jan 02, 2007 at 09:26
You'd be surprised just what you can fit into a 40 litre top lid type fridge (eg Engel). When the missus packs our engel 40 litre - there's not much space left. All stuff is packed out of the home fridge into the pre-cooled Engel. Enough perishable tucker, including cryovac meat to keep us going for 3 weeks plus. As we use stuff from the engel, we use a wine cask bladder to fill the void keeping all contents from bouncing around.
I can't see you fitting any more stuff into a (say) 50 litre upright- probably less.
212825
Follow Up By: D-Jack - Tuesday, Jan 02, 2007 at 10:17
Not to mention a full fridge is a more efficient fridge, we ensure ours is full by keeping small bottles of cold
water in it - the
water comes in handy too!
473028
Reply By: Member - Col G (WA) - Tuesday, Jan 02, 2007 at 12:00
One point that has no been mentioned in this thread is the size of the evaporator in domestic fridges. In my 40L Engel the evaporator runs around the four sides of the fridge, in domestic fridges it is usually a much smaller plate or small freezer compartment, usually at the top so cooled air can fall and cool the remainder of the fridge.
It would probably be satisfactory in cooler climates but in summer in
the desert would not cut the mustard. Another point to consider is that cool air will fall out of a front opening fridge, this does not happen in a chest type. This means that the fridge will beaver away for ages to replace the cool that you just let fall out every time you open the door.
Another thing you mention is to modify the door of a domestic fridge. Be very wary of this as there is usually a thing called a mullion heater that runs around the door frame of these fridges. This is a gas line and I have seen several that have been punctured by the Black and Decker by amatuers fitting hasp and staple type locks to keep the door shut. The result either a very expensive repair or a scrapped fridge.
These reasons together with the increased likelihood of fracturing a gas line on corrugated roads would rule such a fridge out for 4WD purposes IMHO.
212840
Reply By: F4Phantom - Wednesday, Jan 03, 2007 at 22:32
Thanks so far guys,
disadvantages so far
- could break
- not cold enough
- draws to much power
advantages
- cheap!
So its obvious a proper fridge for 4x4ing is much better, but as mentioned the RV style vans do use stock fridges. So for long trips in the bush for weeks at a time just spend the money. If you stay mostly on roads and use
camp sites and dont do 3 days of corregations I cant see why a bar fridge will not do alright, especially in the back of the wagon ready to open when the tail
gate is open. You may even use
camp site power. I suppose it comes back to conditions, and your trips rarther than the equipment.
213112
Reply By: Member - Norm C (QLD) - Thursday, Jan 04, 2007 at 20:42
This link is to an area of the 'Fridge and Solar' web site. It details a test between a Waeco 140 litre fridge and a domestic LG 140 litre run via an inverter.
In summary, the Waeco is about $1,200 more expensive than the LG.
The LG uses about twice the power of the Waeco. Add a second deep cycle battery (say $200) and that problem is solved. But you have to replace (recharge) twice the AH you did previously. How you do that may change the financial outcome. If by solar, you will use all the saving so far.
No reference made to durability off road.
www.fridge-and-solar.net/fridgetest1.htm
213281
Reply By: troopywanderer - Friday, Jan 05, 2007 at 02:43
I have a Waeco 45l that I use as a freezer (brilliant) and a 50l no name brand bar fridge (around $150). Been in the truck for over two years. No problem so far. Except the Waeco running 24/7 24 hours a day need the fan replaced.
My caravan have a 120l normal freezer, also have no problem.
Only thing I did to the bar fridge is tighten the compressor mounting a bit so it's not so floppy. (for the
cape york trip)
Hope this help
213341
