OT - need help on USB drivers for Win98
Submitted: Monday, Jan 08, 2007 at 14:57
ThreadID: 40994 Views:3042 Replies:20 FollowUps:36
We have a very wide array of experts on here, always ready to assist with the expertise on just about any subject,,,,,,,,,,,,,,that 'nuff sucking up for now.
I have an old Compaq Presario laptop that serves me well for my prospecting mapping in the bush. However it as about 10 years old and runs Windows98. It has a USB port but it doesn't work. I've been told the reason that it doesn't work is that there is no USB driver in the Win98 Operating System. I'd like to get this USB port working so that I can transfer data from this laptop to my desktop.
Does anyone know where I can get a driver for this or know how I can EASILY transfer data from one to the other. The laptop has a CD reader but doesn't have a burner. It has one of those old 3 inch flppy drives on it but the 3 inch floopy drive on my desktop doesn't work either!! So I'm snookered!
Bilbo
Reply By: Mike Harding - Monday, Jan 08, 2007 at 15:03
How much data do you need to transfer? If it's less than a few megabytes then a serial transfer (RS232) between the two using Hyperterminal (yuk! :) and a null modem cable will do the trick.
If it's more then a Laplink type parallel cable transfer would probably be better.
Mike Harding
AnswerID: 214019
Follow Up By: Bilbo - Monday, Jan 08, 2007 at 15:22
Mike,
There ya go!! There ya go!! Getting all flamin' technical again! I don't know what all those letters spell let alone what they mean!! "RS" means ratschitt where I come from. "Hyperterminal?? - What's that? A spaceship?? I'm just a simple bushy!
But seriously, these files are mainly Geological Maps that are BIG picture files - megabyte stuff. I use 'em with Ozi-Explorer. I was thinking of a USB Stick as it's small, easily portable and has a reasonable memory capacity. Using USB would be so convenient.
But I'll ask around Dick Smiths to see if they've got the stuff you mention above.
Bilbo
FollowupID: 474294
Follow Up By: Mike Harding - Monday, Jan 08, 2007 at 15:49
Oh dear Bilbo... we need to get you onto a computer course :)
As suggested below; if you can get the USB port working that will be the best way to transfer data (via a memory stick). I'm not sure that W98 will, natively, recognise all USB sticks? Usually they come with a driver CD which should have a driver (driver = bit of software which interfaces between W98 and the USB stick) for W98 which you'll need to install before the computer can "see" the USB stick. Also, as mentioned, ensure USB is turned on in both the BIOS (startup screen) and the W98 "control panel"/"system".
If you can't get the USB going do as I suggest above (drop me an e-mail if necessary) with the RS232 but rest assured it's perfectly possibly to transfer the data without any major dramas.
If the map files to which you refer show the locations of gold deposits and places where you have found a few nuggets then just post your hard drive directly to me and I'll (free of charge for a mate :) gladly transfer all the data to a CD for you :)
Mike Harding
FollowupID: 474303
Follow Up By: Bilbo - Monday, Jan 08, 2007 at 17:48
Mike,
I lost your email addy when my desktop " bleep the great bleep ". This is precisely why I'm trying to get some mapping stuff off my old laptop. I do the research using the desktop (it's bigger and quicker 'n stuff) and then transit maps and waypoints to the laptop- and then GO BUSH fer a looksee.
Could you please send me a TEST message to:
leslowe@iinet.net.au
Thanks Mike,
As for the "gold maps" - that's EXACTLY what these things are!! They're Ozi Explorer maps of spots that I've found gold over the last 20 years or so and a few tracks on how to get there. I've had GPS since they were first retailed about 15 years ago, so there's a fair number of waypoints.
Not much use really as I've cleaned 'em all out!! Unless you have a big bulldozer!
I should be in bed. I'm dying with a dose of flu here.
Bilbo
FollowupID: 474321
Reply By: Truckster (Vic) - Monday, Jan 08, 2007 at 15:07
either buy a CD Burner which is a bit of overkill unless you burn images to CD from laptop from camear
or a floppy for the PC, they are only $20
AnswerID: 214023
Follow Up By: Bilbo - Monday, Jan 08, 2007 at 15:36
Truckster,
See reply to Mike above. These are big files. I don't think the 3 inch floppy would be an option except for some Excel data that I have on the laptop.
I'm still pursuing the driver option for now.
But thanks as always for your reply.
PS- no reply from Andrew yet.
Bilbo
FollowupID: 474296
Reply By: Member - Blue (VIC) - Monday, Jan 08, 2007 at 15:12
Hey Bilbo... I presume you are wanting to use a flash drive/pen drive to copy information to/from...??? If you know the brand of the usb storage device, go to their website and see if you can download the driver from them. EXAMPLE
AnswerID: 214024
Follow Up By: Bilbo - Monday, Jan 08, 2007 at 15:40
Thanks Blue,
That's exactly what I'm wanting to do. It's BENQ 256 MB USB pendrive (thumbdrive?) whatever they're called.
Bilbo
FollowupID: 474298
Follow Up By: Member - Blue (VIC) - Monday, Jan 08, 2007 at 15:45
Here ya go Bilbo
FollowupID: 474302
Follow Up By: Bilbo - Monday, Jan 08, 2007 at 17:40
Blue,
Now we're making progress. Thanks Blue.
I diD go looking at the BENQ site but couldn't find a driver for a USB stick,,,,,,,,,EVERYTHING else but not a USB stick
I've downloaded it and in a moment I'll burn a CD with it on and then transit to my laptop.
Then we'll see how clever I am!!
bILBO
FollowupID: 474319
Reply By: banjodog - Monday, Jan 08, 2007 at 15:17
Windows 98 will run USB - it was Windows 95 that needed USB drivers.
Check to see that USB is active/enabled in the laptop's BIOS. Press F10 (I think, anyway you'll see the message on the screen which one to select) on the inital startup to enter the BIOS area and hunt around for the setting.
Restart Windows and use as per normal to check for USB function. I think on your model there's only 1 USB port.
AnswerID: 214026
Follow Up By: Member - Cruiser (NSW) - Monday, Jan 08, 2007 at 15:40
The original release of Win 98 did not have USB support. It wasnt until Win 98SE (second edition) was released that there was support for USB.
FollowupID: 474299
Follow Up By: Bilbo - Monday, Jan 08, 2007 at 15:41
Banjo,
I'll try that as well. Thanks mate.
Yes - it has only one USB port. It's a Compaq Presario 1245 model.
Bilbo
FollowupID: 474300
Follow Up By: Member - Cruiser (NSW) - Monday, Jan 08, 2007 at 15:43
If you know the model of the flash drive, look at this site. It might have the drivers you need.
FollowupID: 474301
Follow Up By: banjodog - Monday, Jan 08, 2007 at 16:17
USB support (WDM) drivers are on the install CD if needed - \tools\reskit\diagnose folder.
Whatever the device you use should have the drivers on any CD that comes with it.
FollowupID: 474307
Follow Up By: Bilbo - Monday, Jan 08, 2007 at 16:27
Cruiser,
Yeah, that's what I was told as well. However I've had a look in the Device Manager and there seems to be driver named "Opti" something or other in there. Added to which, if I stick the USB pendrive in the back of the laptop it does recognise that the USB drive is there and goes off looking for a suitable driver - which it can't find!
Banjodog,
I haven't got the original install CD. This laptop was given to me as a "Thank You" many years ago after being rebuilt to brand new by a mate of mine in Sweden and then sent to me over here.
Plus, I can't seem to get this thing to go into the BIOS mode. No matter which key I press it carries on to the Windows 98 screen.
It's not looking real bright is it?
Bilbo
FollowupID: 474308
Follow Up By: Member - JohnR (Vic)&Moses - Monday, Jan 08, 2007 at 17:50
Never had a 98 system here that had a working USB port, then never had SE......... Tried many times, better to move past 1997. Systems are past old hat.
FollowupID: 474322
Follow Up By: Bilbo - Monday, Jan 08, 2007 at 18:06
Now theres an idea. I do have a new legal, original CD of Windows XP Home that this desktop is running on. Is it possible to install Windows XP Home over the top of Windows 98 WITHOUT losing anything?
I can't afford to lose anymore stuff after the fracas with this desktop!! That's why I'm trying to get maps and data from the laptop to replace the lost stuff on the desktop! It all went " bleep itshaped" when I had to install Windows XP Home over the top of Windows XP Professional. THAT can't be done BTW - but it leaves you in the unenviable position of having 2 operating systems on the same PC - one at 100% functionailty and the other at 25%. Poor old PC had a "perpuletic fit" and went "gorgonzola gongoozled". Had to reformat the hard drive and here we are today!!
Bilbo
FollowupID: 474325
Follow Up By: Gramps (NSW) - Monday, Jan 08, 2007 at 19:54
Bilbo,
This bit got me interested - "when I had to install Windows XP Home over the top of Windows XP Professional"
Why would you want to do that?
FollowupID: 474349
Follow Up By: disco1942 - Monday, Jan 08, 2007 at 20:09
Bilbo
This link may be of assistance tinyurl.com/tcrlr
It came from drilling down from here tinyurl.com/y2jpcp
FollowupID: 474352
Follow Up By: Bilbo - Monday, Jan 08, 2007 at 20:48
Gramps,
It's a LONNNG story mate. But simply put, I had a copy of Win XP Professional running my desktop fer years. I didn't know where the copy came from 'n I didn't ask. I never did have a an Install Dsk fer this. Some 2 years ago the desktop was about to go "tits up" & I bought a new copy of Win XP Home - just in case my son couldn't rescue my desktop.
Needless to say, he did rescue it as he's a bit like his Dad - a genius ;) - so I never had to install the new copy of Win XP Home that I'd bought.
Flash to present day and the desktop PC again goes "tits up" and I phone my son to come and rescue me again. He was too busy with work 'n girlfriends, so I had a go myself.
Now then, when you get 25% of the way through installing Win XP Home OVER Win XP Professional, it tells you that you can't do this, not allowed, verboten and I think it also said, like you "Why would you wanna do this".
Well, I didn't have an answer did I!! I asked it what right it thought it had to ask me, the buyer, the customer, such a question. So it went all "littllgirly" on me and refused to do anything helpful. So I had to reformat the hard drive and we are where we are today - trying to get back up maps off my bush laptop so that I can go prospecting without having to remember where I was 20 years ago!!
,,,,,,,,and that's the simple version John.
Take care,
Bilbo
FollowupID: 474359
Follow Up By: Gramps (NSW) - Monday, Jan 08, 2007 at 21:40
LOL sorry mate. I did'nt mean to distract you from the task at hand. How are you going with that USB driver supplied by Blue ?
FollowupID: 474375
Follow Up By: Bilbo - Monday, Jan 08, 2007 at 23:29
Gramps 'n Blue,
I downloaded it, burnt it to a CD, uploaded it to the laptop. I then tried placing it in all sorts of folders that my laptop was searching through to get a driver for the USB stick (aka "Unknown Device") on my laptop.
So thus far, I have the driver file but I don't really know which hole to jam it in,,,,,,,,,,,,,,,
I'll try again tommorrow but I may go with the PMCIA card. The laptop does have one of these "things".
Bilbo
FollowupID: 474396
Reply By: Sand Man (SA) - Monday, Jan 08, 2007 at 16:12
Windows 98 SE (Second Edition) definitely has native support for a USB port, albeit at the slower (version 1) speed.
Drivers are only required for some specific hardware devices being plugged into the port.
Bill
AnswerID: 214038
Reply By: Bilbo - Monday, Jan 08, 2007 at 17:54
I found a file called "USBHUB.SYS" and copied that to the place in the system where "Windows New Hardware" was searching for the driver software. It still didn't work.
I'll try installing the driver that "Blue" found for me.
BTW - you guys have been really patient with me. I'm always willing to share my knowledge as well ya know. I've done a course in Cake Decorating and Art Works with Icing Sugar and another in Advanced Lawn Edging. All ya gotta do is ask guys. I can't help ya if ya don't ask,,,,,,,,,,,,
Bilbo
AnswerID: 214054
Follow Up By: Mike Harding - Monday, Jan 08, 2007 at 18:03
I reckon we'd get on well Bilbo :)
FollowupID: 474323
Reply By: _gmd_pps - Monday, Jan 08, 2007 at 18:13
whne you have a PCMCIA port on the laptop you buy
a ethernet card and a crosscable and install ethernet.
win98 can do it and its the most elegant solution anyway ..
good luck
gmd
AnswerID: 214060
Follow Up By: disco1942 - Monday, Jan 08, 2007 at 20:35
A PCMCIA USB card may be an alternative way to getting USB going on your computer. Take your lap top to your local computer shop and ask them if they have something that will work. If they get it going for you they may also assist you with your memory stick. If you get really desperate to save your data this may prove an economic way to do it.
FollowupID: 474357
Follow Up By: Bilbo - Monday, Jan 08, 2007 at 23:32
GMD 'n Peter,
Hey - it has a PMCIA card in it!! I've never used it for years. I'll try that.
Thanks,
Bilbo
FollowupID: 474397
Reply By: Member - Doug T (W.A) - Monday, Jan 08, 2007 at 19:17
Bilbo
You should be able to download drivers from the Microsoft page but I don't think Win 98 supports USB ,Bilbo it's time to move on from P51s I think we use FA-18 s now ......lol
Doug
AnswerID: 214082
Reply By: Member - Doug T (W.A) - Monday, Jan 08, 2007 at 19:27
Bilbo
This is best I can find for you
Windows 98, Windows 98 Second Edition, and Windows Millennium Edition Support ends on July 11, 2006 Final customer notification about the end of Windows 98, Windows 98 Second Edition, and Windows Millennium Edition Extended Support
Support for Windows 98, Windows 98 Second Edition, and Windows Millennium Edition (Me) ends on July 11, 2006. Microsoft will end public and technical support by this date. This also includes security updates. Microsoft is providing final notifications to customers to end the extended security update support for these products.
Microsoft is ending support for these products because they are outdated and these older operating systems can expose customers to security risks. We recommend that customers who are still running Windows 98 or Windows Me upgrade to a newer, more secure Microsoft operating system, such as Windows XP, as soon as possible
AnswerID: 214086
Follow Up By: disco1942 - Monday, Jan 08, 2007 at 20:30
Just because Micro$oft will not support him does not mean that the forum members will turn their backs on Bilbo. Win 98 SE is still a good system. If he does not connect to the net (and how can he when he is out on the gold fields) there is no danger of nasties.
The big problem is Bilbo needs to back up his data onto his desktop before he stuffs up the laptop. Once he has his data backed up he can install XP or whatever.
I am not sure if the hardware on the old computer will handle USB 2 but USB 1 will certainly be fast enough to save his data.
FollowupID: 474354
Follow Up By: Bilbo - Monday, Jan 08, 2007 at 21:49
Doug,
Yep - read that meself on the MS site Doug. Typical bleedin' Microsoft eh! Thye're about as useful as used doggie disposal bag.
Bill Gates sells all sorts of rubbish and then walks away from it!
Thanks anyway Doug mate,
Bilbo
FollowupID: 474378
Reply By: CLC50 - Monday, Jan 08, 2007 at 19:43
I believe you require USB 2 Drive ,USB1 is to Slow.I had the same Problem on my old Lap top,I purchased USB 2 Card & this works Ok. also need USB 2 to run TV on Lap Top
But I am not sure on Windows 98 , I was running Windows XP.
But I am sure someone can set me straight if I am Wrong
AnswerID: 214090
Reply By: Bilbo - Monday, Jan 08, 2007 at 21:00
Disco 42 - Peter D,
Never again will I bash Landy owners. You are indeed very astute. What you have described there is 'perzackerley' how this lot works. The laptop doesn't connect to the Internet, it doesn't do TV, doesn't play CDs, doesn't entertain kids in the back seat etc, etc. It doesn't do anything except act as "Map Holder" in the bush and run a GPS.
I would love to install Windows XP and some extra, fancy software but they are big operating systems that take up heaps of memory and this thing has all it's RAM slots full as far as I can see. Plus where would I get extra RAM for a 10 year old laptop?
Thanks for your help mate.
God Bless Landrover owners -I wouldn't have one meself you understand, but God Bless 'em anyway.
Bilbo
AnswerID: 214106
Reply By: Richard Kovac - Monday, Jan 08, 2007 at 21:40
Bilbo Hi,
I haven't read all the post But
I run two old PCU computers running WIN98SE one has 2 USB ports and it will not run a thumb drive but will run a USB card reader..
So I just transfer data to a card (any sort) pull it out and plug it into whatever comp I need it..
Anyway like I said I haven't read all the post and this may have been said before..it's called a work around LOL..
Richard
AnswerID: 214128
Follow Up By: Bilbo - Monday, Jan 08, 2007 at 23:37
Richard,
That's another great idea. I'll keep that up my sleeve fer now. I'm determined to make this driver thing work - for now.
If you ever need any help sexing your budgies - you can count on me ;)
Bilbo
FollowupID: 474398
Reply By: avro - Monday, Jan 08, 2007 at 21:56
Please do not tell by 2nd PC that Win98 will not run USB! Its not running Win98SE either. I use a Thumb Drive all the time to transfer data between it and this PC running XP Home. Certainly some versions of Win98 do run USB, but it will almost certainly be USB1.
It seems to me that his USB port is indeed working, as he said that when he plugs in the drive the PC recognises it and asks for the driver. Its the driver for the Thumb drive he needs, and the link to that has already been provided. So a download of the driver, burn to CD and transfer to PC when it asks for the driver should (fingers crossed) fix it.
Regards avro
AnswerID: 214132
Follow Up By: atoyot - Monday, Jan 08, 2007 at 23:21
Avro's right' USB is working, it's just the driver for the thumb drive that's missing. If the one on the link further up doesn't work, try this.
USB 1 and 2 support is based on the hardware; being 10yo it's got a USB1 port, so no usb2 devices will work fast; they'll run at usb1 speed.
It's not worth upgrading to XP as SODIMM chips are hard to find, and you'd probably have to upgrade the hard disk to something bigger as well. Better bet to buy a new cheapie for < $800.
regards
FollowupID: 474395
Follow Up By: Bilbo - Monday, Jan 08, 2007 at 23:51
Avro,
See above - I downloaded that driver, burnt it, installed it and it isn't working,,,,,,,,,,,
But I'm not sure if it's installed in the right place,,,,,,,,,
I've got a splitting headache.
Andrew,
I checked around about getting new chips, ram, bigger hard drive etc, it was a daunting task 'n I never bothered. I don't really wnat to spend a heap of cash buying a new laptop when all I use it for is mapping, which it does quite well.
Bilbo
FollowupID: 474404
Follow Up By: Bilbo - Tuesday, Jan 09, 2007 at 00:24
Avro,
I tried your link, downloaded it burnt it and tried to intsall it. It came up with," This driver is for Win 98SE. It is incompatible with your version of Windows".
I think it went," Ner,ner, ne, ner, ner" as I closed the error message window!!
But thanks for trying for me, friend.
If ever I can rebuild a 13 speed Allison transmission for you, just let me know,,,,,,
Bilbo
FollowupID: 474408
Reply By: joc45 - Monday, Jan 08, 2007 at 22:53
Bilbo,
I've got a USB driver for Win98 for a Dick Smith thumb drive. Just installed it on a friends lappy so I could transfer some data. Worth a try if you want a copy. email me on:
Gerron at tpg d0t com d0t c0m d0t au.
Gerry
AnswerID: 214143
Follow Up By: disco1942 - Monday, Jan 08, 2007 at 23:37
The trouble is that drivers are fairly specific to their own sticks if you are running Win 98. It is not like running them on XP where one size fits all. I had to install 2 separate drivers for 2 separate sticks on my machine.
FollowupID: 474399
Follow Up By: Bilbo - Monday, Jan 08, 2007 at 23:45
When I bought the 2 sticks that I have, there was no software that came with 'em. I just stuck into my works provided, latest IBM Thinkpad and they worked no probs. I kept the memory sticks when I retired 2 years ago but the company wanted the IBM back :(
joc45 - can you confirm yer email as:
gerron@tpg.com.com.au
It's got 2 "coms" in it. Is that correct?
Mine is: leslowe@iinet.net.au
Bilbo
Bilbo
FollowupID: 474401
Follow Up By: joc45 - Tuesday, Jan 09, 2007 at 14:54
Sorry, Bilbo, it's one 'com'.
The file is on its way.
Peter,
Yeh, I know they are specific, but sometimes there's a generic mfr from China or wherever, churning these out, putting several brand names on the same item. No harm in installing the driver and seeing if the PC then recognises the drive.
Gerry
FollowupID: 474494
Follow Up By: Bilbo - Monday, Jan 15, 2007 at 18:09
Joc 45 (Gerry),
I tried that driver file. It didn't work I'm afraid.
Thanks for trying mate,
Bilbo
FollowupID: 475758
Reply By: Geoff (Newcastle, NSW) - Monday, Jan 08, 2007 at 23:59
Hello Bilbo,
You may find som help in this Microsoft article Enabling USB in 95, 98 & Me
Geoff
Geoff,
AnswerID: 214157
Follow Up By: Bilbo - Tuesday, Jan 09, 2007 at 00:32
Thanks Geoff,
I read it but to no avail. It seems that Win 98 does support USB, but for some reason my Win 98 doesn't want to find the USB driver that I have in there.
Bilbo
FollowupID: 474410
Reply By: Bilbo - Tuesday, Jan 09, 2007 at 00:39
Ya know, you guys have once again been absolutley brilliant at trying to sort this out for me. We are indeed a very special gang on here.
I been thinking,,,,,,,,,,the amount of time that I've spent on trying to fix this little USB problem - all day - I could have had the engine out of a Scania, stripped it down, put a new crankshft in it and refitted the motor & been half way to flamin' Alice Springs by now!!,,,,,,,,when I was a younger man of course!!
Bluddy Bill Gates - I bet that barsteward can't drive a Scania!!
Bilbo
AnswerID: 214166
Reply By: Member - Davoe (Nullagine) - Tuesday, Jan 09, 2007 at 01:21
email it from the lappy to the desktop
AnswerID: 214168
Follow Up By: Bilbo - Tuesday, Jan 09, 2007 at 01:41
Davoe,
That's a possibility but,,,,,,,,,,,
These files are massive - map jpegs - and my lappy is configured for a dial up connection that no longer exists as I'm now on broadband. It hasn't been used on the 'net fer about 6 years.
But thanks mate - now go to sleep.
Bilbo
FollowupID: 474416
Reply By: Gmouse - Tuesday, Jan 09, 2007 at 10:26
I would consider a BIOS upgrade may be needed for your PC go to manufactures web site and do a search usually under “support”
d/l all relevant updates for your pc and burn to disc and install
hope this helps
AnswerID: 214202
Reply By: Sand Man (SA) - Tuesday, Jan 09, 2007 at 15:39
Bilbo,
First of all, determine that the physical USB port is OK.
Start Windows - System - Hardware - Device Manager
Look for an entry called Universal Serial Bus Controllers - Generic USB Hub
Is there any conflicts reported?.......red cross?......yellow question mark?
If no, then the USB port itself is working OK.
Then you need to determine what you wish to connect to it.
You can plug in a stick drive, memory stick, whatever you want to call it, but under Windows 98, you will need a specific driver for the device.
You may be able to download a driver file for the specific brand of "USB drive" you have.
Or you could purchase a "Laplink" cable which connects to the serial or parallel ports of each PC. (Parallel port operation is the next fastest thing to USB ports). A "Laplink" cable is also available for connection to USB ports but again, you need to confirm the Laptop one is working. With the "Laplink cable" connecting two PC's, you can see a drive on one PC as an additional drive on the other and this works well, through Windows explorer.
A parallel port "Laplink" cable is available from Dick Smiths for $9.94 (X8259)
Bill
AnswerID: 214254
Follow Up By: Sand Man (SA) - Tuesday, Jan 09, 2007 at 16:15
Just one more thing,
If using the Parallel Laplink Cable option, you will need to select Windows Start - Communications - and double click the "Direct Cable Connection" to run the Wizard.
P.S. Bilbo, I know about Janome Sewing Machines too.
I do all the machine sewing in our house.
Diversification!
Bill
FollowupID: 474503
Follow Up By: Bilbo - Tuesday, Jan 09, 2007 at 21:35
Sandman,
Thanks for you help. It seems to be recognising that "there is something plugged into the USB port" as it comes up with "Device Unknown" in the Device Manager screen. I've had look in the "Device Manager" and there is something there on the USB tag with a big yellow question mark alongside it. Thanks to the people on here I've been able to try several drivers, none of which seem to work. The Wizard goes off looking for a particular driver and even when I direct the Wizard to precisely where it is located in the filing system, it comes up with "Driver Not Found". I'm then back where I started.
I'll have one last try at making a driver work and getting the USB port operational. After that I'll go with the direct connection. It's messy and not as flexible but beggars can't be choosers eh?
I've been told that I can use the PMCIA slot. There is a PMCIA card in the laptop.
I'm learning more every day. Sewing machines are next,,,,,,,,,,,,
Thanks,
Bilbo
FollowupID: 474542
Reply By: Bilbo - Monday, Jan 15, 2007 at 18:22
For those that are STILL interested, I've given up on the USB driver idea.
I'm having success transferring these files with a little programme called "FileVan" - easily downloaded from the 'net from the USA for USD$24.95. That and a Parallel Data Transfer cable from Dick Smiths for AUD9.95. It's slower than a USB and not as convenient but it works and it's gotten me out of the "manure business".
Thank you to everyone that helped.
I just love the people on this forum.
(End of sucking up here and exit stage left,,,,,)
And a special big thank you to "Angela" that contacted me when I mistakenly typed in "vile trans" instead of "file trans" when searching for a file transfer programme. "Angela" used to be a truck driver in Arkansas until he found his true purpose in life,,,,,,,,,,
Bilbo
AnswerID: 215480
