Challenger Battery Replacement
Submitted: Friday, Jan 19, 2007 at 00:28
ThreadID: 41374 Views:2528 Replies:5 FollowUps:0
The factory battery has finally died on my 2003 Challenger LS. I would like to replace it with a heavier duty one.
Does anyone have any suggestions or experiences with installing a larger battery to replace the standard one?
Thanks.
Reply By: Gerhardp1 - Friday, Jan 19, 2007 at 09:24
Fit the biggest AGM you can get in the slot.
Then you can run a fridge for days without a dual setup being required.
I have a 100AH, 1000cca unit in the Jackaroo and its excellent.
AnswerID: 216332
Reply By: Sand Man (SA) - Friday, Jan 19, 2007 at 10:24
For a replacement starting battery at a reasonable price, I recommend the Exide Extreme.
I do not support using a single battery in any vehicle to run accessories such as a fridge. That is just asking for trouble unless you include an under voltage cutout device and even then I would be extremely nervous venturing into remote areas with this setup.
Bill
AnswerID: 216355
Reply By: tim_s - Friday, Jan 19, 2007 at 10:37
Hi Lockey
My factory battery died after 2 years and I replaced it with an Centruy/Yuasa Overlander 700 - it was basically the largest "normal" battery I could fit in the tray. Four years later, it is still going strong. I generally do not run the fridge off it - except when driving or for a few hours or so when away from camp fishing etc. I haveinadvertently left the fidge plugged into the car overnight rather than the AGM "battery in a box" I carry and it started no problems teh next morning. I too would not recommend doing this as a regular thing, as it is asking for trouble. Itut it is nice to know that it can be done if needed (or I forget).
Tim
AnswerID: 216362
Reply By: pickle - Friday, Jan 19, 2007 at 12:38
I have a Century N70 in my Challenger, the N70 will fit no problems but would reccomend an Exide Extrene. Doesn't take much to kick over the V6 in them but with a N70 you will have plenty in reserve.
AnswerID: 216397
Reply By: lockey - Friday, Jan 19, 2007 at 22:05
Thanks to all that answered.
I went for the Centruy/Yuasa Overlander 700. I have another deep cycle for running frdge etc, but wanted a good quality main battery.
AnswerID: 216530
