Fridge slides and power leads
Submitted: Saturday, Jan 20, 2007 at 16:22
CRASH
I know there was a post not long ago on fridge slides and how to stop them cutting the power lead to the fridge but i cant seem to find it (i'm new here so forgive me!) I have just put in a black widow fridge slide and the first thing i did was almost sever the cable! I actually cut the cable a small amount and luckily the fuse blew first, but i was hoping that someone can tell me if there is a tried and true method of keeping the fridge lead out of the way of the slide so i dont do this again in the bush!
Reply By: Kev M (NSW) - Saturday, Jan 20, 2007 at 16:37
I cable tied
mine up out of the way of the slide.
Kev
| Russell Coight:
216666
Reply By: Member - Duncs - Saturday, Jan 20, 2007 at 16:40
Hey Crash.
I am very fmailiar with the problem.
What I now do is to tye the fridge lead around the bottle screws I use to keep the Engle in place.
This does 2 things. 1 it keeps the lead out of the way. 2 it keeps the screws from rattling loose.
I leave just enough lead free to allow the fridge to slide in and out without getting in the way.
Duncs
216670
Reply By: Gmouse - Saturday, Jan 20, 2007 at 17:37
Hi Crash,
With
mine I use an ockie strap from the rear handle of the fridge connected to the wire mesh on the cargo barrier, with a few cable ties to hold the fridge power cable out of the way
It just retracts when you slide it back into position
216683
Reply By: Rick (S.A.) - Saturday, Jan 20, 2007 at 18:24
I put the power cable in some corrugated black electrical tube (dunno the name of this stuff. It is split along one dimension for installation of cables/wire/etc).
Then I taped the black corrugated tube together at 100mm intervals.
Then ran it from the 12 V power plug, in an inverted U-shpaed aluminium strip, across the back of the cargo area, as it potentially could snag frequently as it is in the high traffic region of the rear - i.e. as you open the
barn doors, on top of the sliding drawers.
Then a red posties rubber band provides tension for the enclosed cable, as it emerges from the al. strip. The lead is cable tied up along the side of the storage unit. This allows the slide to travel freely without jag/snag/scissoring etc. In the shut possie the red posties rubber band is at 70 % stretch.
216693
Reply By: Member - Tim - Stratford (VIC) - Saturday, Jan 20, 2007 at 18:38
Crash,
BUGGER - I sent you a few ideas by email before I read this thread - also some photos of
Campsite 8 that was hit by the fire.
Tim
216694
Reply By: Sand Man (SA) - Saturday, Jan 20, 2007 at 21:22
Do you have a grab handle above and to the side of the fridge location.
I simply pass the cable through the handle then back down to the fridge, so the cable moves in a pendulum motion as the slide is opened and closed.
216733
Reply By: Ozesheila - Saturday, Jan 20, 2007 at 22:13
Hi Crash, regarding fridge slide cords, my husband has just finished making his own slide & read on the
forum of others' problems with the power cord. After putting a lot of thought into it he came up with an idea which he put on our slide made for an 80 ltr Engel. What he invented could solve most folks problem with this. It's made to fit in the back of a Jackaroo, the fridge slide sits on the passenger side with power outlet same side out of the jack recess, power inlet is on the right side of fridge . On the LHS of the slide near the centre he bolted a small right angle 1.5mm thick plate just to clear the top of slide with a small bearing and a bolt thru the middle then a 6mm steel rod about 5mm clear of fridge side to 20mm clear of top of the fridge on top of the bolt. The rod is bent at right angles to the right side of fridge. The cord is cable tied up the bar and over the top . Slide fridge in and out the cord folows fridge in and out perfectly .
We will post pics on Monday when our
membership is validated.
216754
