Air compressor for 215/60/r16 tyres
Submitted: Friday, Feb 09, 2007 at 19:33
TomHo
Hi there,
I've read all the previous posts on the air compressors and it seems everyone recommends a top quality unit. However, I only drive a forester with 215/60/r16 tyres rather than big high volume tyres. Do you think I'd get away with a small compressor such as the power air II bushranger ($99) or projecta cyclone (similar)?
Tom
Reply By: Sand Man (SA) - Friday, Feb 09, 2007 at 20:38
"Get away with it"
For what purpose Tom?
If you only want to "top up" the tyre pressure a few PSI, yes you may get away with it.
But if you need to inflate a tyre from flat, or even worse, re-
seat the tyre bead on the rim, I'd suggest you may be found wanting.
Bush
Ranger also distribute the more expensive compressors such as the Pro Air ($250) Black Max ($297) Super Max ($495).
The more expensive compressors also provide one other valuable feature. They don't overheat. So if you need to inflate 4 tyres from say 18 psi to 36 psi in
the Desert Country, a Blue Tongue, or Big Red, or Super Max, will do the job, no problem.
Save up for a bit longer Tom and buy something worthwhile.
220888
Follow Up By: Member - Jason S (SA) - Friday, Feb 09, 2007 at 23:14
Yep, with Sand Man.
I spat out 2 compressors of the cheap variety. Very bad news when you need to re-inflate after sand.
Had my Big Red for a while now. Tough as guts. Recommend them to anyone.
481592
Reply By: bigtom - Friday, Feb 09, 2007 at 20:46
Hi Tom,
I've got an '88 landcruiser with 235/70/16 (I think) and I take the kids to beach when I have them every second weekend.
I use the $99 bushranger and so far it's served me
Friends of
mine use the same compressor on their troopys with fatter tyres than
mine, and again, so far no problems. We've both been using them every second weekend for the last six months, and like I said, so far so good.
Good luck
Tom
220891
Reply By: Member - Davoe (Nullagine) - Friday, Feb 09, 2007 at 20:55
I bought a truck air it is air cooled and will run all day. bit slow but would do you around 100bux
220894
Follow Up By: Muzzgit [WA] - Saturday, Feb 10, 2007 at 00:23
Bit slow? C'mon Dave!
Slowest damn compressor I've had the misfortune of using.
Very reliable, American made, but slow as hell on a hot day.
481604
Follow Up By: Member - Davoe (Nullagine) - Sunday, Feb 11, 2007 at 10:13
like i said it will run all day - i know coz thats what it takes!
481768
Reply By: Matt.D (WA) - Saturday, Feb 10, 2007 at 01:08
TomHo,
I just bought an "Aunger" Compressor from Kmart that puts out 72l/min. Have used it a couple of times, And yes on hot days of near 40c in
Perth it has done a great job of re-inflating the tyres. It took on average 2min 30s per tyre for 265/70/16's from 18psi-35psi. I don't know how reliable they are, but as with everything they have a 12 month warranty. My personal opinion is that if you will only use it every now and again then it would be adequate for your needs at $100.
At the end of the day you must decide what sought of budget you have and choose the best value for money that you can afford. To me Nearly $400-500 sounds a bit rich if you only need it occasionally, when you could buy this plus a good quality foot pump as backup and still have a heap of change.
Matt
220915
Follow Up By: Sand Man (SA) - Saturday, Feb 10, 2007 at 11:23
Yea But! No But!
Yea But!
When you have just visited "Big Red" and need to re-inflate the tyres on two or three vehicles and want to get to the Pub in time for dinner to keep the girls happy, then you will appreciate something you know is reliable, will not overheat and will not take all day.
If all you require is something to top up the tyres a couple of PSI, or inflate the kiddies air mattress and beach ball, maybe the lower range of pumps will be OK, but to "Air Up", or re-inflate a tyre after a puncture, I know what I would justify.
Had a cheapie to start with and after realising what it was capable of, gave it to my Son for around town use and bought a good one. So you could say I wasted $100.
"Horses for Courses" I think.
481637
Follow Up By: Matt.D (WA) - Saturday, Feb 10, 2007 at 13:19
Sand Man, You need to tell your friends that are doing the Simpson with you to be better prepared and have their own gear then a cheapie would be all you need to do your tyres only.(If only life was so simple) {:-)
481648
Reply By: Crackles - Saturday, Feb 10, 2007 at 13:12
The small cheaper range of compressors will be fine for your Forrester. Lets be realistic, it's not as though you are going to be regually adjusting preasures & the volume of air in that size tyre is fairly minimal compared to the full sized 4by's so inflation times will still be reasonable. The majority of talk on Ez Oz re quality compressors is more related to quick inflation for over sized tyres, reseating tubless beads, ability to pump up multiple vehicles (continuous duty) & something that will be reliable for remote outback use.
Cheers Craig...........
220948
Follow Up By: Matt.D (WA) - Saturday, Feb 10, 2007 at 13:22
Here, Here.
481650
Reply By: TomHo - Saturday, Feb 10, 2007 at 13:52
Thanks folks, I think I will go with the bushranger. I figure in later life when I spend $40k++ on a real 4wd then add in the cost of
winches etc etc spending another $400 on a decent compressor if I decide the cheap one is no good won't really break the bank.
Tom
220950
Follow Up By: Member - Jason S (SA) - Saturday, Feb 10, 2007 at 23:17
Save yourself at least $75 bucks, go to Supercrap and buy a cigarette plug type $25 thing that thinks it is a compressor.
By the sounds of it, that is what you are after.
481723
Reply By: Member - Phil G (SA) - Saturday, Feb 10, 2007 at 23:35
The cheaper pumps are hit and miss. But you can be lucky. In the 80's I upgraded from a
hand pump to a pair of Kmart's finest electric pumps (about $35 each :-))). They lasted about 10 years, before I handed them onto the kids for their bikes, and got a decent pump for myself. I've heard that the cheapies at BigW are not bad for the money.
221031
Reply By: Member - Jeff H (QLD) - Sunday, Feb 11, 2007 at 01:25
Whoa, get back ,sit: all advice offered seems good, but---.
Mate, as stated, cheapies may be 'hit or miss', so carry a manual pump in case the power unit self-destructs.
I know only too
well how hard it is to find "just another bit of extra cash, [stuff credit]", all at once.
On our first crossing of Big Red, I only had a manual pump. (Younger 'n much fitter then, alas.) Enjoy within your means. Jeff.
221046
