12 volt indicaters
Submitted: Thursday, Feb 22, 2007 at 20:37
ThreadID: 42601 Views:5073 Replies:8 FollowUps:16
Hi all does anyone use those in car battery indicators they show you how both your battery's levels are.
Where do you buy them from and how much would you expect to pay and can you fit them yourself.
Many thanks
Eric
Reply By: Derek from Affordable Batteries & Radiators - Thursday, Feb 22, 2007 at 21:26
Hi Eric
You get Voltmeters, simple LED indicators and more advanced monitors.
What are your needs ?
Have a look here. monitors
Derek.
AnswerID: 223431
Follow Up By: Eric from Cape York Connections - Monday, Feb 26, 2007 at 21:56
Derek I am after something to look at that lets me know on either my axillary or my cranking battery what charge or life is left in it.
I think thats how to say it.
All the best
Eric
FollowupID: 485041
Follow Up By: Derek from Affordable Batteries & Radiators - Monday, Feb 26, 2007 at 22:11
Hi Eric
Our LCD monitor will show you the available capacity in a bar graph.
The bar graph on the RH side drops as the battery capacity decreases.
Derek.
FollowupID: 485049
Follow Up By: Eric from Cape York Connections - Tuesday, Feb 27, 2007 at 06:22
Derek does it do both battery's at once or do you need 2. How much are they.
Many thanks
Eric
FollowupID: 485089
Follow Up By: Derek from Affordable Batteries & Radiators - Tuesday, Feb 27, 2007 at 08:51
I will send you some infor to your email.
We have a few options.
Derek.
FollowupID: 485099
Reply By: Hairy - Thursday, Feb 22, 2007 at 21:34
Yeh Mate,
About $30 from Tandy.
Had it in my car for a couple of years and works fine.
AnswerID: 223434
Follow Up By: Eric from Cape York Connections - Monday, Feb 26, 2007 at 21:57
Hairy what does it tell you and what is the model of it.
Many thanks Eric
FollowupID: 485042
Follow Up By: Hairy - Monday, Feb 26, 2007 at 23:39
Gday,
Ive never even tried to use half the crap on it but from memory its
Volts
inside and outside temp
time
something to do with ice.
Just had a quick look.
Thermo-tech????
Blue...El...Ice..Alert?
Its a real cheapy that has done really well and chances are you would probably never find another one.
Id just go to tandys or your equivalent and take a chance.
FollowupID: 485076
Follow Up By: Gramps (NSW) - Monday, Feb 26, 2007 at 23:52
Eric,
Same thing from Jaycar. XC0116
FollowupID: 485080
Reply By: Member - Ivan (ACT) - Thursday, Feb 22, 2007 at 21:58
I used to have one in my car - but all it told me was the voltage while I was driving! - and I had to go look at it to see what the voltage was in between times.. Best thing I've done is install a voltmeter at the rear of the car - every time I visit the fridge, I can glance down and see what is going on - it's not an obsession - but I do have a good feel for what to expect from the battery now - and more importantly, when something is not quite right
AnswerID: 223438
Follow Up By: Eric from Cape York Connections - Monday, Feb 26, 2007 at 22:01
Thanks ivan
All the best
Eric
FollowupID: 485044
Reply By: Member - Garth (NSW) - Thursday, Feb 22, 2007 at 22:57
Jaycar have them. Some with voltage readout and coloured leds. Bought 2, work fine. Around $30 I think from memory.
regards
Garth
AnswerID: 223451
Thanks Garth
All the best
Eric
FollowupID: 485045
Reply By: Sand Man (SA) - Friday, Feb 23, 2007 at 01:09
Yes, I use one of the Jaycar ones and they are OK.
I mounted the meter on the centre console using self adhesive Velcro tape.
Also have an additional "ciggy socket" under the dash connected to the auxiliary battery.
I can swap between the primary and secondary batteries simply by plugging the meter into the appropriate socket.
Works for me.
Bill
AnswerID: 223465
Follow Up By: Ian from Thermoguard Instruments - Friday, Feb 23, 2007 at 09:32
Hi all,
Just a warning about the Jaycar $30-odd clock/voltage indicators. I put one on our caravan batteries and it initialy read about 0.3V low. It has a calibration potentiometer on the back. I suggest you check it against a good multimeter (or preferably a couple of different mutimeters, to be more confident) and adjust if necessary.
Ian
FollowupID: 484362
Follow Up By: Sand Man (SA) - Friday, Feb 23, 2007 at 15:33
Ian,
Your statement is fair enough mate, but one good thing a cheap voltmeter does is confirm that the Isolator has in fact cutover to charging the auxiliary battery.
The only other way (on my Piranha unit anyway) is to look under the bonnet and observe the indicator light.
Also, it will show you if the battery voltage is "dangerously low" when stationary, regardless of whether the true voltage is 11.6 or 11.3.
Accuracy is hardly a primary requirement in these circumstances.
For $30 I believe they are a good investment.
Bill
FollowupID: 484411
Follow Up By: Eric from Cape York Connections - Monday, Feb 26, 2007 at 22:00
Thanks Sand man
All the best
Eric
FollowupID: 485043
Reply By: _gmd_pps - Friday, Feb 23, 2007 at 01:42
this is what I use for my Housebank (4 x 6V 220AH)
store.solar-electric.com/tm500-shunt.html
for the two cranking batteries I have a simple Voltmeter and an Amp Meter for the charge current into each .. shows me leaks in the system easily ...
the digital volt/amp meters are good with a good shunt when they are calibrated .. I prefer the two decimal digitals ..
To really monitor your batteries you need both Volt and Amp .. Volts only tell half the story ..
have fun
gmd
AnswerID: 223467
Follow Up By: Eric from Cape York Connections - Monday, Feb 26, 2007 at 22:02
Thanks _gmd_pps
All the best
Eric
FollowupID: 485046
Reply By: Robnicko - Friday, Feb 23, 2007 at 09:18
Eric,
If you have a Piranha dual battery system they sell a monitor which tells you voltages of both batteries. I beleive they now have a digital version as well.
Rob
AnswerID: 223496
Follow Up By: Eric from Cape York Connections - Monday, Feb 26, 2007 at 22:04
Thanks Robnicko I do have a Piranaha duel battery system
I will look into it
All the best
Eric
FollowupID: 485047
Follow Up By: Robnicko - Tuesday, Feb 27, 2007 at 12:48
Eric,
If you have a DBE150 or 180S system I believe the battery monitor plugs straight into it.
Thanks,
Rob
PS : I just use my $16 dick smith multi meter.........
FollowupID: 485172
Reply By: Trev50 - Friday, Feb 23, 2007 at 13:03
G'day all,
Does anybody have a parts list and circuit for a monitor that would show you battery volts and charge/discharge current?
Trev
AnswerID: 223532
Follow Up By: Robin - Monday, Feb 26, 2007 at 22:13
Hi Trev
If your looking to do something at the electronics hobbyist level , check out current (feb 2007) silicon chip mag.
It has simple approach to measure amp hours based on a bicycle computer readout driven by a simple picaxe. Ther exact circuit is for smaller gel cells and panels , and sense resistor would have to be scaled
Robin Miller
(I just use a $40 dollar Jarcar volts monitor as it has low batt volts alarms , and temp sensors which can be placed on battery)
FollowupID: 485052
