Duel battery charging
Submitted: Tuesday, Mar 06, 2007 at 20:26
ThreadID: 42973 Views:2643 Replies:10 FollowUps:22
I recently read a post on another forum about using a Diode isolator to charge a duel battery system. A diode is placed in line between the alternator and each battery. This isolates the battery's from each other and while the engine is running allows both battery's to be charged. Knowing a little about electronics I kicked my self for not thinking of this before. From what I can remember about diodes this system would work perfectly. No moving parts and no switches creating voltage spikes. However I'm wondering how it would work in the real world, and if I'm over looking a potential problem. Has any one had any thing to do with diode isolators and what are your thoughts on them.
Steve
Reply By: Bonz (Vic) - Tuesday, Mar 06, 2007 at 20:39
Well considering the current that would flow between the two batteries on charging alone, that would have to be some BIG SUCKER of a diode
AnswerID: 225691
Follow Up By: Ianw - Tuesday, Mar 06, 2007 at 20:43
Not so, Bonz!!
Ian
FollowupID: 486575
Follow Up By: Steve from Albany - Tuesday, Mar 06, 2007 at 20:46
A battery only draws around 8 or 10 amps when charging so a diode rated at say 50 amps would be heaps for each battery.
Steve
FollowupID: 486576
Follow Up By: Bonz (Vic) - Tuesday, Mar 06, 2007 at 20:46
Why isnt it so? I would think that for a 30amp charging flow, easy for a relatively flat that a larger power diode would be needed, voltage drop notwithstanding
FollowupID: 486577
Follow Up By: Bonz (Vic) - Tuesday, Mar 06, 2007 at 20:47
hey Steve how big is a 50amp diode? I better go look at triccky Dicky's or Jaycar
FollowupID: 486578
Follow Up By: Bonz (Vic) - Tuesday, Mar 06, 2007 at 20:51
not very big it would seem
FollowupID: 486581
Follow Up By: Steve from Albany - Tuesday, Mar 06, 2007 at 20:52
I don't think tricky Dicky would have have diodes in the range we are talking. I don't know where you could get them. I'll have to look around
Steve
FollowupID: 486583
Follow Up By: Ianw - Tuesday, Mar 06, 2007 at 20:55
Larger diodes will have at least 1 volt drop across them even at that level of current. In the real world your alternator is putting in much more current than 8 or so amps into a low battery. Won't work, sorry. If it was that easy why would anybody buy, or even make expensive isolators for this type of system
Ian
FollowupID: 486585
Follow Up By: Bonz (Vic) - Tuesday, Mar 06, 2007 at 20:55
That was my point Ian
FollowupID: 486586
Reply By: Ianw - Tuesday, Mar 06, 2007 at 20:42
Sounds easy doesn't it? Not so. Diodes have a voltage drop through them which increases with increased current flow. If your alternator is putting out something like 14.2volts, The diodes will drop this to approx 13.2v and your batteries will not be charged. The only way to counter this is to modify your alternator to put out an increased voltage to compensate i.e. 15.2volts. It can be done.
Ian
AnswerID: 225693
Follow Up By: Steve from Albany - Tuesday, Mar 06, 2007 at 20:49
Ianw,
The block that posted this idea said he used schottkey diodes (what ever they are) and only had a voltage drop of about 0.2-0.3 volts and his batterys were charging at about 14.3 Volts
Steve
FollowupID: 486580
Reply By: Phil P - Tuesday, Mar 06, 2007 at 20:55
In theory this will work ok !
General Purpose & Rectifier diodes have a 0.7v voltage drop.
Germanium diodes have 0.2v voltage drop.
Not sure what will happen if you discharge the second battery, maybe the primary will still feed power into the second battery? The diode will only stop the second battery from discharging into the primary battery.
AnswerID: 225694
Follow Up By: Ianw - Tuesday, Mar 06, 2007 at 21:13
GP and rectifier diodes have a NOMINAL voltage drop of .7v or .2v. So in theory it might work. If you check the specs of any diode you will see that the voltage increases with more current. In the case of big rectifiers passing 35amps or more this will be in the order of 1.2volts. Even at .7 volt your battery will not charge very well with only 14.2 - .7 = 13.5 volts
Ian
FollowupID: 486593
Reply By: Pavo - Tuesday, Mar 06, 2007 at 20:57
Have a look at www.surepower.com. It looks like their 'isolator' (as opposed to their 'seperator' - which I have incidentally) works like this.
I have no formal auto electrical training, but my only guess at a downside would be the batteries are independent when charging and discharging? So both batteries would charge at their own rate by taking what they need from the alternator? The main starting battery would not get any priority. Whether I'm accurate or not, I really don't know - and I don't know if that would have any real world issues either.
Pete
AnswerID: 225695
Follow Up By: acdc - Tuesday, Mar 06, 2007 at 21:08
Pavo,
The problem with diode isolators is if your starter battery is full and only requires say 8amps to keep it that, that's approx all your second battery will get if it's flat or not, so can be very slow at recharging.
Voltage drop is not a problem it depends where your alternator is sensing from.
FollowupID: 486590
Follow Up By: Pavo - Tuesday, Mar 06, 2007 at 21:12
Thanks. Like I said, I know nothing about them.
But the surepower site is worth a read (maybe not for you, but for others) - there is lot's of information on it about battery/power management.
Pete
FollowupID: 486592
Follow Up By: Ianw - Tuesday, Mar 06, 2007 at 21:23
Voltage drop is the problem! Most alternators' internal regulators sense the voltage at the output of the alternator. If you put a diode between this and the battery, voltage will be lost. The only way to overcome the problem is to make the regulator sense the battery voltage by modifying the alternator.
Ian
FollowupID: 486598
Reply By: Ianw - Tuesday, Mar 06, 2007 at 22:21
If you want to get techo try this site. It explains everything much better than I can.
www.smartgauge.co.uk/facts.html and click on the truth link.
Ian
AnswerID: 225716
Follow Up By: Steve from Albany - Tuesday, Mar 06, 2007 at 22:26
Thanks Ianw I'll have a look
Steve
FollowupID: 486620
Follow Up By: _gmd_pps - Wednesday, Mar 07, 2007 at 02:30
this is only true to a certain extent ..
connecting the two batteries does not happen when the cranking battery
is at 12.7 volt ... it happens when the alternator is running and producing
14 and more ..
recalculate with a voltage drop of 2.5 - 3.5 worst case ...
I agree that the inrush is not as much of a problem as one may think
but still high enough to warm up some smaller relais contacts ...
a flat AGM at 10.8 with an externally regulated 160Amp alternator connected to an almost fully charged cranking battery can draw over 100amps in my opinion ..
but I might be one of those following rumours and may have overengineered my setup.
good luck
gmd
FollowupID: 486646
Reply By: oldpop - Tuesday, Mar 06, 2007 at 22:31
Build one youself check out
www.oatleyelectronics.com $19.00 plus P&H about 3hours to build
Works Great
AnswerID: 225719
Follow Up By: Steve from Albany - Tuesday, Mar 06, 2007 at 22:39
Oldpop,
I had a look at the site. What was it exactly that you bought.
Steve
FollowupID: 486626
Reply By: oldpop - Tuesday, Mar 06, 2007 at 22:44
Sorry Steve
Kit No. K227
AnswerID: 225720
Follow Up By: Steve from Albany - Tuesday, Mar 06, 2007 at 22:53
Looks good Oldpop,
I might have to look into one of these. Much cheaper then an off the shelf model.
Steve
FollowupID: 486629
Reply By: joc45 - Tuesday, Mar 06, 2007 at 22:52
I used one of these successfully on my old Mav (GQ). Used a pair of 100A stud diodes (from the spares box) with a suitable heat sink. Worked well.
It's true that you will drop up to 1 volt across the diodes, but the Nissan/mav alternator monitors its battery voltage right at the battery, so any volts dropped across the diode is made up for in the regulator, hence it charged the battery at the correct voltage. QED.
Now, as suggested above, if the main battery is fully charged it will only slowly charge the aux battery; this is not really the case, as the discharged aux battery will pull the volts from the alternator down further, bringing the main battery volts down with it. Hence the alternator will correct the voltage and feed more to the aux battery - think about it!
BUT, another problem is the commutation noise caused by the diodes (it's not pure DC, but pulsed of current from the alternator). In my case, the diode combiner generated some radio interference, which I fixed with a 0.1uf capacitor across each of the diodes.
If you're making your own combiner, cheap diodes are the 50A press-fit diodes as used in alternators. But you'll need a big enough heat sink to take the heat away from the diodes. 1v at 50A is 50watts dissipation. Another consideration is that if you fix the diodes directly to the heat sink, then you will need to electrically isolate the heat sink from the vehicle body.
You can get high current Shottky diodes which have much lower volt drop (about 0.2-0.4v at the rated current). A possible source of these cheaply is from an old computer power supply, where they are used for the +5v 30A output. These diodes are capable of about 30A continuous, tho on their own are a bit light-on.
For a switching type of combiner, Oatley electronics have a neat kit which is probably a better proposition link if you want a relay-type battery combiner. Costs $19, and uses a latching 80A relay.
Gerry
AnswerID: 225723
Follow Up By: Steve from Albany - Tuesday, Mar 06, 2007 at 23:00
Thanks for the reply joc45,
I had a look at the Oatley site. Do the latching relay that they use have any issues with creating voltage spikes like a normal relay / solenoid does
Steve
FollowupID: 486631
Follow Up By: Ianw - Tuesday, Mar 06, 2007 at 23:34
Looks like it might be worth a go. Re switching surges refer to www.smartgauge.co.uk/nosurge2.html
Ian
FollowupID: 486634
Follow Up By: joc45 - Wednesday, Mar 07, 2007 at 06:21
Hi Steve,
Good question. Ian's reference I think pretty well sums it up.
Another consideration; the huge current surge via the starter solenoid when one starts the engine. Does that bother any one?
The Oatley module is a bit different to other solenoid type battery combiners in that it uses a latching relay; ie, once it's pulled in, it requires no current to hold it there. When the battery volts drop too much, it is electrically kicked out. Result is very low power consumption on idle.
Gerry
FollowupID: 486648
Follow Up By: oldpop - Wednesday, Mar 07, 2007 at 07:31
More info on dual batterycontroller
Site Link
FollowupID: 486649
Follow Up By: AdrianLR (VIC) - Wednesday, Mar 07, 2007 at 22:44
I use the Oatley kit in my Pajero. It's been in for the last year and we've been to the Flinders Ranges, Murray river, High Country and other places. Works without a hitch. With heavy connecting cables there is no measurable voltage drop through the isolator. The Aux isn't connected until the main reaches a predetermined voltage (you set this). Total cost with kit, postage, case and cables was around $50.
There was a heated debate in a post around 2 weeks ago on this very subject. I'll repeat my offer from that post of a free SurePower diode isolator that I have in the shed but only to someone who understands that it may not work in a modern vehicle.
Adrian
FollowupID: 486871
Reply By: peteC - Wednesday, Mar 07, 2007 at 16:25
Steve,
AnswerID: 225845
Reply By: peteC - Wednesday, Mar 07, 2007 at 16:37
Steve, TRYING AGAIN, I had such a diode unit. It was a Hella unit that had bolt type connections on a sealed aluminium heat sink case. If you checked around Hella may still supply them. From memory they handled about 60amps per battery. I had it installed in my Triton but as mentioned above you loose 0.7volts to the batteries. This was not too much of an issue day to day driving until you camped for a weekend and the sub battery didnt last as long as expected as it wasn't getting full charge. I removed it and installed a solenoid for about $60. I put a timer on the solenoid of about 45 seconds and that allowed the starting of the car without have the chance of the solenoid switching on while you where starting as this could put a few hundred amps thru a 60 amp rated solenoid. You could do without the timer because if you connect the activate wire to the ignition correctly , it should switch off when starting the car. There now a very noticable difference in the life of the battery when camping.
AnswerID: 225849
