Rear window cover
Submitted: Monday, Mar 12, 2007 at 23:34
ThreadID: 43185 Views:2891 Replies:12 FollowUps:12
Does anyone have any recommendations on rear window covers to protect against stones while towing a camper trailer and where to purchase them from...
We are about to head off on a 14 week trip around Oz and think we might need one.
Reply By: Motherhen - Monday, Mar 12, 2007 at 23:42
Easy to make - member Willem made some for us from materials on hand. Get some of that heavy duty clear plastic (Spotlight sell it) and some self adhesive Velcro - Velcro brand stands up to the heat better than cheaper alternatives. Cut to shape of window and stick in place with tabs of Velcro. Will cost yo next to nothing.
AnswerID: 227056
Follow Up By: Member - brad B (WA) - Tuesday, Mar 13, 2007 at 01:47
Great idea. I'll be onto that tomorrow.
FollowupID: 487891
Follow Up By: Willem - Tuesday, Mar 13, 2007 at 20:29
Glad to hear that my on the spot invention is still in use....:-)
Mine fell off on the last trip but will get better Velcro next time.
FollowupID: 488043
Reply By: Richard Kovac - Tuesday, Mar 13, 2007 at 00:20
Leah C
Ihave a www.obiesoutback.com.au/ and have never broken a rear window on the troopy since we have had them
Richard
AnswerID: 227062
Follow Up By: Sand Man (SA) - Tuesday, Mar 13, 2007 at 11:14
I'll go along with Richard on this one.
I also have an Obie's Outback screen saver (2 pieces for the Jack).
I cannot understand why people bugger about with el-cheapo solutions, unless it is a one off trip. The cost of the Obie's is around $200 and saves something like $1500+ if you bust the big window. I was "lucky" when I broke my window as the Insurance Company covered the cost of replacement. Sure was inconvenient at the time though. I was in the Birdsville/Innamincka region.
Bought the Obie's very soon after that incident.
The only thiing I have changed from standard is to replace the strips of Velcro (on the vehicle glass borders) to Velcro spots (22mm). This was to eliminate the expansion/contracting I experienced with the strips over 6 months or so.
Have had the spots permanently on the Windows for over two years now without any evident problems.
Bill
FollowupID: 487911
Follow Up By: RovingOz (QLD) - Tuesday, Mar 13, 2007 at 19:18
Sandman
where did you get the velcro spots and were they 3M?
FollowupID: 488021
Follow Up By: RovingOz (QLD) - Tuesday, Mar 13, 2007 at 19:20
...and sorry, did you also replace the velcro on the wondow saver with the spots or just on the vehicle's glass?
FollowupID: 488022
Follow Up By: RovingOz (QLD) - Tuesday, Mar 13, 2007 at 19:22
and when you remove it to clean do the spots come off?
sorry on my 3rd can....hic...
FollowupID: 488023
Follow Up By: Sand Man (SA) - Wednesday, Mar 14, 2007 at 18:30
I left the original strips of Velcro attached to the Screen Saver. The screen saver is not exposed to the weather like the vehicle's Window glass is.
I found the original strips expand and contract over a period of time and not only look bad, but lose their adhesion too.
The spots (22mm) have a smaller cross section and I have not had one come off A yet.
Nothing special about the loop & hook Spots, although they are genuine VELCRO® brand. Available in most larger Hardware stores. Bunnings have them.
Eventually, I may replace the whole lot and reverse the hook and loop setup, so that the softer "loop" material is on the vehicle.
Bill
FollowupID: 488208
Follow Up By: Richard Kovac - Wednesday, Mar 14, 2007 at 21:10
Hi RovingOz
That's a nice looking bit of gear you have in your rig pick.
How to you fined the strap type mirrors?
I have the clip on type and even with a brace they are useless
Richard
And by the way I did brake the rear window in the Prado just outside of Birdsville
FollowupID: 488244
Follow Up By: RovingOz (QLD) - Wednesday, Mar 14, 2007 at 22:42
Hi Richard
The aussie truck mirrors are very good, nothing moves.
I (borrowed) tried the ora clip on with the brace but no go.
FollowupID: 488277
Reply By: Member - Doug T (W.A) - Tuesday, Mar 13, 2007 at 00:56
Mine was very cheap in fact no cost at all and done the job, I used opened beer cartons taped on with 100mph tape ,and when not needed just rip it off , of course if you want to see you could go buy some clear perspex , it can be obtained ftom Bunnings in small sheets and different thickness , just one of about 2mm would do the job and once again tape it on
AnswerID: 227068
Follow Up By: T-Ribby - Tuesday, Mar 13, 2007 at 12:30
Ditto. I use a large windscreen sunshade secured with race tape (cloth duct) plus a stoneguard on the CT.
T.R.
FollowupID: 487917
Follow Up By: Member - Lance S (VIC) - Tuesday, Mar 13, 2007 at 12:41
Ditto, to Doug T, all we used was the carton of the VB box with 100mm tape, and it worked a treat for 6 weeks in outback SA,QLD and NSW.
cheers, Lance
Home Away from Home
FollowupID: 487920
Reply By: Member - MUZBRY (VIC) - Tuesday, Mar 13, 2007 at 07:29
Gday
And when you get to Melbourne , call in and we can make one for you as well as have a cuppa.
AnswerID: 227076
Reply By: spliney - Tuesday, Mar 13, 2007 at 08:43
Coreflute (the stuff real-estate signs are made from) is also readily available, cheap, able to be cut to size and works well with velcro fastenings.
Spliney
AnswerID: 227082
Reply By: Member - Oldplodder (QLD) - Tuesday, Mar 13, 2007 at 09:21
Been a few postings lately on www.capertrailers.org yahoo forum.
Site Link
For the rear window itself, the beer carton, to perspex fixed with suction cups or the rear louvre tabs, to bought items.
Or stone screens and all sorts of ideas to deflect stones down from the front of the trailer.
AnswerID: 227088
Reply By: messmate - Tuesday, Mar 13, 2007 at 15:16
Hi, we just used some real estate agent corrugated plastic and attached with velcro. worked beautifully and cost us $25. Managed the Sturt Stony Dessert ok.
Enjoy your trip. We are heading over to WA as soon as the go down.
AnswerID: 227142
Reply By: Gob & Denny - Tuesday, Mar 13, 2007 at 19:20
i have some 1/2" thick felt cut to shape and held up with velcro straps
works o/k
steve
AnswerID: 227214
Follow Up By: Member - MUZBRY (VIC) - Wednesday, Mar 14, 2007 at 13:01
You want a plastic one??? you can see through them ....
FollowupID: 488155
Reply By: Hairy - Tuesday, Mar 13, 2007 at 21:07
Gday,
Most people I see come through town use Beer cartons.
But I think that might have been too late! LOL
AnswerID: 227252
Reply By: Motherhen - Tuesday, Mar 13, 2007 at 22:18
Gee and i thought beer's only use when motoring was as a fire extinguisher!
AnswerID: 227278
Reply By: Member - Leah C (WA) - Wednesday, Mar 14, 2007 at 01:48
Thanks all for the ideas - so many things to do before the big trip hope to see some of you out there!
AnswerID: 227300
Reply By: Member - Julie P (VIC) - Wednesday, Mar 14, 2007 at 18:56
We made our own from a product similar to perspex called Tuffex - from a perspex supplier - made a pattern (we have an odd shape rear window) - cut it out with jigsaw - stuck it with velcro - but only buy the Velcro brand - the cheaper ones have inferior adhesive qualities - Spotlight have Velcro brand - 25mm wide is ok - cost us about $60 all up - another thing to remember is not to leave it on when you are just parking for a while especially in the heat - the glue will soften in the sun and your cover will slide off - you may not notice it till it's gone. We did this, of course, after we broke the rear window on a big trip - typical isn't it?
Enjoy your trip.
jules
AnswerID: 227461
