Polyairs vs Hayman Reese
Submitted: Wednesday, Mar 28, 2007 at 00:36
ThreadID: 43710 Views:5540 Replies:11 FollowUps:27
Hi Guys
I have a NM Pajero with a 2" Lift, I tow a Coromal Pioneer Silhouette and find that the rear sags quite a bit.
I am stuck between getting polyairs or a Hayman Reese load distribution setup.
I realise that the HR setup is not for off road but I have been told that the poly airs will not push the weight onto the front wheels where the HR kit will.
What are your thoughts.
Reply By: Andrew Kilby (QLD) - Wednesday, Mar 28, 2007 at 06:46
I much prefer the HR setup. They are not strictly for off road because of the travel limitations but are fine on gravel, and undulations. they will probably go anywhere you want to take the van. They do reduce ground clearance a little.
This forum will however support the airbags, but personally i don't want them. the way air bags work is to effectively stiffen up the suspension and so on long stretches of corrigations etc the tyres them selves have to do more work normally done by the suspension. Some tyres will do it but most "road only" tyres will not. The side wall overheats and they delaminate and self destruct.
I suggest you go to a local van park and talk to some people with OR vans and see what they recommend. I have met several people who have moved from airbags to load levelers.
AnswerID: 230149
Follow Up By: Teabag (Queanbeyan) - Wednesday, Mar 28, 2007 at 06:53
Interesting, In my experience with airbags the vehicle runs very well on long stretches of corrugations. Tyres will work hard anyway has you should lower pressures a little when on rough/corrugated dirt dirt......Very interesting........Did the Great Central road last year and down the Oodnadatta track without issue and an excellent ride........
FollowupID: 490946
Follow Up By: MEMBER - Darian (SA) - Wednesday, Mar 28, 2007 at 08:19
Yep - can add the Gibb, the Kalumburu Rd (picture left) and the Tanami track to the "bag run" too Teabag - bags that are used within their limitations (not overloaded or thrashed) seem to work fine (like anything - exceed their design capacity and anything will hapen !).
I'm sure that load levelling hitches are better in certain applications, but they present a severe compromise it seems, for those of us wanting to crawl in and out of camping spots, once we come off the graded roads.
FollowupID: 490962
Follow Up By: Member - Steve T (NT) - Wednesday, Mar 28, 2007 at 09:29
Hi Andrew
The information I'm about to give you is from a guy that owns his own suspension outlet and when necessary makes his own springs.
We were talking the other day about air bags, he said idealy you should lift the car and its load about 1 inch or so with the springs, EG heavy duty, another inch or so with the air bag using the correct air pressure.
If the car still sags perhaps try weight distribution.
This is for coil springs, He said people the sell air bags for leaf springs are nothing but thieves.
If you need to drop tyre pressure to get a better ride on dirt roads, simply means your suspension isn't working properly.
Cheers Steve.
FollowupID: 490984
Follow Up By: Teabag (Queanbeyan) - Wednesday, Mar 28, 2007 at 09:34
Steve,
Can you please clarify something? Are you saying you shouldn't lower your tyre pressures on dirt roads or when traversing our great outback roads? This is the way I took your comment and please correct me if I have it wrong?
Thanks,
Teabag
FollowupID: 490986
Follow Up By: Member - Steve T (NT) - Wednesday, Mar 28, 2007 at 09:55
Hi Teabag.
There has been lots of debate on this forum in regards to tyre pressure on dirt roads, I run Oz made Bridgestone A/T duellers at 40 front and 42 rear.
I have done this on 8 cars over 6 years and covered approx 580.000 km, 1/2 of which was on corrugated roads across the top end, from Gove to Broome.
I have never blown a tyre, Most people on the forum that tell you to lower your pressure and lower your speed, they also tell you to take an extra spare in case of a blow out.
All suspension adds tell you what happens to tyres if the suspension isn't doing its job, I've never seen them say adjust your tyre pressure to fix the problem.
So to answer your question, my opinion is no you shouldn't.
Cheers Steve.
FollowupID: 490992
Follow Up By: Teabag (Queanbeyan) - Wednesday, Mar 28, 2007 at 10:27
Steve,
I guess this is each to his own....I don't do it to cover up poor suspension but for proven longevity of tyres........I have done this for 20 plus years with the similar Km to yourself living in Gove, Darwin etc and has work extremely well for me....I guess we have a difference of opinion on this one.....
FollowupID: 491002
Follow Up By: kiwicol - Wednesday, Mar 28, 2007 at 16:12
Hi Steve, i to run the aussy made bridgestones and have never had to run them at the pressures you are talking about, i also have done trips you have spoken about and have also towed C/T and wagon fully loaded and have only ever run at 32- 33psi all round including C/T, i have never had a blow out and get about 100,000ks per set, i have only a 2inch lift with big heavy duty shocks. Its my opinion that tyres will do the same job no matter what sort of suspension or up grade fitted to any vehicle, i also carry an extra spare and never had to use it but for peace of mind.!! The pressures you run at must give a horrid harsh ride when on corrugations. What sort of prssure do you run with an unladen vehicle. Col
FollowupID: 491079
Follow Up By: Member - Steve T (NT) - Thursday, Mar 29, 2007 at 10:30
Hi Teabag and Kiwicol.
Firstly Teabag there's nothing wrong with agreeing to disagree, If we all agreed with each other life would be pretty boring.
Hey Kiwicol It just goes to show what a great tyres they are,My springs give a 65 mm lift and when the truck is fully laden the ride is perfect, on my own it is harsher but I'm not going to lower them for myself these trucks are primarily for work.
Have a nice day
Cheers Steve.
FollowupID: 491249
Reply By: Teabag (Queanbeyan) - Wednesday, Mar 28, 2007 at 06:48
Mate,
I have a different vehicle and different Camper but I have had Polyairs in the back of both my Patrols and personally think they are great. Had no issues simple to use are also get when the vehicle is loaded up and no camper on the back.....For me I personally think the Air bags are a little more versatile.......My set up is Patrol towing a Kimberley Kamper, rather heavy ball weight.....
AnswerID: 230150
Reply By: Craigjackaroo - Wednesday, Mar 28, 2007 at 07:01
I use both the air bags and the distribution hitch on my Jackaroo. The air bags are also good for when I am not towing but am loadded up with the roof rack etc.
The Distribution kit is required for the Jackearoo to increase the towball load over120kg legally.
The air bags are adjustable and give a different feeling to just having stiffer springs - not as much jolt on the bumps.
Can be set up together or seperate which can help with load biasing on one side of the vehicle.
AnswerID: 230152
Reply By: Pajman Pete (SA) - Wednesday, Mar 28, 2007 at 07:44
I havd both on my Paj and find the setup excellent.
I had the hitch by itself before I fitted the bags and find the ride with bags and hitch much better than the hitch alone.
The air bags are also good for the times you don't take the van and load up with gear.
Pete
AnswerID: 230155
Reply By: Member - Toolman (VIC) - Wednesday, Mar 28, 2007 at 07:51
I use both.
Toolman
AnswerID: 230159
Reply By: Member - jeff M (SA) - Wednesday, Mar 28, 2007 at 08:48
Dr
I have poly air's on my NP Paj and they do a great job.
If you fit a H/R set up you can't fit a long range fuel tank to the Paj
(I was told),that's if you were to go that way.
I have had H/R on a sedan and it was great the weight distribution is excellent but restrictive when turning tight.(well it use to make some noises)
Cheers Jeff
AnswerID: 230176
Reply By: japmel - Wednesday, Mar 28, 2007 at 10:53
There is a set of Polyairs on ebay at the moment for a Pajero
here's the link:
Site Link
The usual disclaimer (I'm not the seller etc etc)
AnswerID: 230204
Follow Up By: IT Dr - Wednesday, Mar 28, 2007 at 13:28
Thanks for the tip off John but wrong model and I have a 2" lift plus the guy wont ship.
Looks like I am up for a new set.
FollowupID: 491036
Reply By: IT Dr - Wednesday, Mar 28, 2007 at 13:32
Thanks everyone for your responses.
Looks like it is even stevens but ultimately getting both will be the way to go.
I will probably go with air bags first to cater for non towing load-ups and non-flat off-roading. If it still sags or if the front is still pointing upwards then enter the hayman reese for highway and flat off-roading.
Is it just me or do we all have the feeling that the money funnel is upside down, a little bit coming in the top and bucket loads falling out the bottom.
AnswerID: 230234
Follow Up By: Alloy c/t - Wednesday, Mar 28, 2007 at 15:10
Best price for airbags , www.trucksprings.com , you get them delivered to your door for about 1/2 the price even allowing for $au to $us conversion rates.
FollowupID: 491062
Follow Up By: IT Dr - Wednesday, Mar 28, 2007 at 16:18
They don't list the air bags as being available for the 2000 or 2001 Montero (Pajero)
FollowupID: 491083
Follow Up By: Alloy c/t - Wednesday, Mar 28, 2007 at 16:49
Ya cant be looking hard enough , click onto montero sport 2000 model , firestone air helper springs ,{yes I know the picture doesnt look like its what you want } click on it a voila , Firestone airbags for your Paj , $77.28 us , easy as to self fit.
FollowupID: 491091
Follow Up By: pjchris - Wednesday, Mar 28, 2007 at 17:43
Montero Sport is a Challenger not a Pajero....
FollowupID: 491108
Follow Up By: IT Dr - Wednesday, Mar 28, 2007 at 17:57
pchris
You beat me to it....that'll be why the picture doesn't look like what I want Alloy c/t.
Thanks Guys but Easter is rapidly approaching and local warranty carries a lot with me, so I am going local with supply and fit. I carry pretty valuable cargo (family) so I don't want any unexpected surprises.
FollowupID: 491116
Follow Up By: Alloy c/t - Wednesday, Mar 28, 2007 at 19:06
And if the pair of you looked properly you would find that that the part required is 1 and the same !! ooh well spend your $s how you wish ,wont bother trying to help u again., lest to say that the Warranty is not a real excuse , the Firestone "bags " are heavy duty while the polyair does the job at a price only.
FollowupID: 491144
Reply By: Member - Doug T (W.A) - Wednesday, Mar 28, 2007 at 15:03
If you want superior ride, carrying ,Towing then forget Airbags, Air lines, compressors,pumping up,letting down, Old Man Emu is the way to go, I have heavy duty OME on my Troopie, I put the 20ft van on it and it might drop 1 inch, on a dirt road it has exceptional handling , is predictable , and the vehicle is a pleasure to drive,
Site Link
www.arb.com.au/emu-dakar-leaf-springs.php
AnswerID: 230252
Follow Up By: IT Dr - Wednesday, Mar 28, 2007 at 16:17
Thanks for the tip Doug but the Pajero is a coil spring vehicle.
FollowupID: 491080
Follow Up By: Member - Doug T (W.A) - Wednesday, Mar 28, 2007 at 18:12
I know the Paj is coil sprung, didn't you read the OME link
Here it is again, THE OME LINK FOR COIL SPRUNG VEHICLES
Site Link
I must add that Steve in the NT has pushed his mates springs before on the Forum, wonder who's going to drive all the way to Darwin just to get a set of springs, He also pushes the idea of running tyres at high pressures on rough road , That is plain Stupidity ,
FollowupID: 491120
Follow Up By: IT Dr - Wednesday, Mar 28, 2007 at 18:23
OHHHH!
That link, I could have sworn that it said "leafs" but keyboards have been known to misinterpret the typists commands from time to time.
Your 20' van would be dual axle wouldn't it?
My camper has a hellish tow ball weight the wheels are at about 75% from the front of the camper (no not the draw bar).
FollowupID: 491125
Follow Up By: Member - Doug T (W.A) - Wednesday, Mar 28, 2007 at 18:33
I wouldn't know an NM Pajero if I fell over one ....lol I wasn't sure that's why I put both up, you know "kill two birds....." your right the link was for Leaf in www format but the other link for Coils came up as only "Site Link".
Now on the subject of Mitsubashi's, have you seen the 2007 Delica , just one word say's it ....WOW , Keep an eye for a new post , I will put it up for you .
Doug
FollowupID: 491129
Follow Up By: IT Dr - Wednesday, Mar 28, 2007 at 18:41
Doug
hehehehe cheeky lot aren't we.
No I can't say I have seen the 2007 Delica but I am going to have a look now.
We a having a demo at the end of the month on the new "Bush Winch" with the club and some of the Delica Club guys are coming along so no doubt I will hear about it then as well.
Paul
Oops....like a speeding Mitsubishi I beat you to it.
<img src="http://www.mitsubishi4wd.org.au/images/delica2007.jpg"
FollowupID: 491130
Follow Up By: Member - Doug T (W.A) - Wednesday, Mar 28, 2007 at 18:44
You Mongrel .....
Do I detect a slight Honda CRV in the window lines
Doug
FollowupID: 491133
Follow Up By: IT Dr - Wednesday, Mar 28, 2007 at 18:47
With the risk of going so far of topic I would need a GPS to find my way back, I would say you are right and that is the problem with the newer stuff these days all starting to look the same.
FollowupID: 491135
Follow Up By: Member - Doug T (W.A) - Wednesday, Mar 28, 2007 at 19:18
Why did you say ...."so far off topic" these vehicles run Pajero running gear so they would be a very capable 4x4, maybe these new ones are lower in the roof too , I know a couple of blokes in the East that have the older ones as Pilot Vehicles, ,
Now we here in Australia pronoince the word wrong too Pa j ero , the J should be sounded as an H , Pahero , Pajero's are a South American Wild Cat so in South America, Mexico, as an example San Jose , we don't say Jose , more like Hozay .
The Mitsubishi Pajero, known as the Mitsubishi Montero in the Americas and Spain, and as Mitsubishi Shogun in the United Kingdom, is an SUV built by Mitsubishi Motors. The name Montero (meaning "mountain warrior") was used because Pajero is slang for wanker in Spanish.
Check link
Site Link
FollowupID: 491149
Follow Up By: IT Dr - Wednesday, Mar 28, 2007 at 19:23
I am saying off topic because the thread was about Poly Airs vs Hayman Reese.
Yes the Delicas are very capable indeed. Can't see them not being able to go anywhere a Pahero can go.
FollowupID: 491150
Reply By: Graham & Ann - Wednesday, Mar 28, 2007 at 20:20
IT Dr we use both the polyairs and the HR WDH towing our 2000kg van behind our 1999 Pathfinder all over this great land including the Plenty Hway into Alice, the Oodnadatta into Mt Dare the Tanami into the Kimberley, Gibb Rivber Rd, up to Kalumbaru, and many other dirt roads including the Flinders Ranges, but unlike you we have standard suspension, and needed the polyairs to level the loaded vehicle before the van was hooked up. If your vehicle fully laden is sitting level without the van on, you probably dont need the poyairs just the WDH should do the job, no need to take it off on dirt road unless your really going up/down very steep creek banks, we've not taken ours off yet. If you do fit polyairs dont inflate them real tight we use max of 22psi less stress and still lets the suspension do its job. Wev'e towed over 115000km using polyairs and no problems.
You didn't ask about tyre pressures but have got plenty of replies re same, we lower our tyres by around 20% for dirt roads (and the keep the speed down) much easier on the vehicle and never had a problem. (a ballon full of air will burs much easier than one with less air, same goes for tyres, a baskett ball full of air will bounce much higher when full of air, let a bit out and it wont bounce as high, same with tyres)
AnswerID: 230329
Follow Up By: IT Dr - Thursday, Mar 29, 2007 at 02:12
Graham & Ann
My vehicle fully laden is sitting level at the moment. I have a 2" lift with heavier duty springs but that hasn't firmed up the suspension enough to carry the load of my camper. I have a drawer system and recovery gear in well underneath that. Even when I put the fridge in and extra water etc the car is OK but when the camper goes on it sags a good 40-50mm.
The camper is front heavy with the 115 amp battery, fridge, boot and water tank all forward of the axle line. The read overhang of the camper has only the spare tyre to counter balance. I have even contemplated moving the water tank to the other side of the axle line.
Polyairs I hope will stop most of the sag, I have a pair of load levellers that lift the rear about 30mm and I am hoping the poly's will stop the other 20mm sag. If not I will have to upgrade to Hayman Reese kit to get it level.
My main concern is that the poly airs may well prevent sagging in the rear but will not transfer the weight onto the front wheels like the levellers will. Hence I feel having both will be the ultimate.
I agree with you on the tyre pressures it has been proven many times over. Although many tyre experts say that if your tyre pressure between hot & cold is more than 4 degrees you don't have the correct inflation for your speed.
FollowupID: 491204
Follow Up By: Graham & Ann - Friday, Mar 30, 2007 at 12:03
Your right the polyairs wont transfer any weight back onto the front wheels to aid steering/braking etc. if your only using a light 2 bar system for up to 85kg tow ball weight at the moment maybe the 4 bar 110kg system would do the job for you. The 250kg units are very heavy & bulky themselvs adding probably around 20kg odd to the ball weight...
www.hardingscaravans.com.au/towing4.htm
FollowupID: 491451
Follow Up By: Graham & Ann - Friday, Mar 30, 2007 at 12:57
IT Dr, just noticed some other lighter WDH systems 125kg & 130kg
that maybe suitable. tinyurl.com/326sq3
FollowupID: 491464
Reply By: Go-N-Grey (WA) - Thursday, Mar 29, 2007 at 20:37
I'd go for the HR. They do more than just fix the sag. They stiffen the connection between the car and the caravan, and on some of the goat track bitumen highways in Oz they significantly reduce the pitching that occurs when cruising at 80Km/hr plus. There is also some reduction or reduced susceptibility to swaying which can occur in a badly balanced rig, or strong crosswinds.
The other advantage is there is a large range of adjustments on the towball height. This can be used to ensure the caravan travels exactly level (very critical for stable towing and improved fuel consumption), regardless of the load in the towing vehicle.
i.e. we have very little gear in the our LC when doing a weekend trip away, but on long trips to bush camping sites both car and caravan avery heavy, particularly with dinghy and all the other long term isolated camping equipment. The hitch height can be adjusted relatively simply with a couple of spanners.
AnswerID: 230529
