OT :Formatting hard drive
Submitted: Thursday, Mar 29, 2007 at 15:29
ThreadID: 43769 Views:2502 Replies:8 FollowUps:20
Got a new (2nd hand Laptop) and I want to scrub everything from it and start off fresh.
I assume I have to format it buit not sure how to do it and then reload on windows and my programs.
All help appreciated
David
Reply By: Blaze - Thursday, Mar 29, 2007 at 16:05
Hi David,
Depends whether its Fat32 or NTFS format to begin with. If it is running XP chances are its NTFS and this being the case, all you need to do on most laptops is press F12 when booting to give you a multi boot screen HDD, FDD or CD-ROM. With your XP disk in the rom drive just tell it to boot from CD, then I always suggest delete the partition and re-set it up. If you read all the screens after boot up from the CD it is easy to achieve.
If its 98 you will need a boot disk which can make in control panel, then boot from it and load from rom.
Have fun, Geeeeze now I don't have a Job LOL
AnswerID: 230472
Follow Up By: Des Lexic - Thursday, Mar 29, 2007 at 17:01
!!!!!###########****************????????????WTF
Do you know any computer people that can do it for me?
FollowupID: 491308
Follow Up By: Kumunara (NT) - Thursday, Mar 29, 2007 at 23:25
Des Lexic
If you need any assistance go and see Blaze and he will help you again.
If not you could always come up here and see me. It's only a short drive. I should know the number of times I've done it recently.
Tjilpi
FollowupID: 491382
Follow Up By: Member No 1- Friday, Mar 30, 2007 at 07:41
hi des, how did you get on with that fridge?
FollowupID: 491403
Follow Up By: Des Lexic - Friday, Mar 30, 2007 at 17:48
G'day Nudie,
I've decided to have the repairs done. Will cost about $700 including the new compressor and gassing.
Must put the bite on the insurance Co. see if the fusion policy covers it.
FollowupID: 491502
Follow Up By: Member No 1- Saturday, Mar 31, 2007 at 21:27
put in the house......they must cover it then:))))
in the car the have an out.....................
FollowupID: 491770
Reply By: Sand Man (SA) - Thursday, Mar 29, 2007 at 16:56
Blaze has pretty well covered it all.
Recommend XP for sure. Initial installation will ask "do you wish to format the hard drive" and also what size primary partition you want. If a 40 gb drive or thereabouts give the primary partition as 100% the size of the hard disk and for XP an NTFS formatted option will work best. If the drive is around the 80 Gb mark, you can allocation say 40 Gb for the primary partition (C drive) and the remainder as the secondary partition. (D drive) This way you can direct all your data, pictures, etc. to D drive and leave C drive for the operating system and additional programs.
Just makes the operation and performance of your "new" Laptop that much better.
Bill
AnswerID: 230478
Reply By: Hairy - Thursday, Mar 29, 2007 at 17:02
Gday,
Be scared......If your not good with computers you can really make a mess of it doing that sort of thing!
Take it from someone who knows. Ive done some serious damage playing with things like DOS, BIOS, partitions, boot discs etc etc. Sometimes a little knowledge can be more dangerous than none! If you need to ask the question I would personally say dont do it.....
Good luck
AnswerID: 230481
Follow Up By: Member No 1- Friday, Mar 30, 2007 at 07:43
its just a new hard disk...not to hard
and besides he is a south aussie
FollowupID: 491405
Reply By: warfer69 - Thursday, Mar 29, 2007 at 17:21
Hi David
Download killdisk onto floppy and run the program here,use free version
killdisk
Then install winxp from fresh
if you want more info just text me (warfer2002 @ hotmail.com)
and by the way DONT BOTHER with Vista till at least first big service patch or the first year..
cheers mate
AnswerID: 230486
Follow Up By: Pajman Pete (SA) - Thursday, Mar 29, 2007 at 17:44
Killdisk is brilliant. I wiped 3 computers at work today with it. (I can think of a lot of ways to have fun with it as the CD lives in my laptop bag, but that would be naughty!)
Pete
FollowupID: 491321
Follow Up By: warfer69 - Thursday, Mar 29, 2007 at 17:57
"I can think of a lot of ways to have fun with it as the CD lives in my laptop bag, but that would be naughty!"
Cmon Pete the mother-in-law's not that bad is she ! lmao
FollowupID: 491326
Follow Up By: Member No 1- Friday, Mar 30, 2007 at 07:47
why do i want killdisk?...cos I can?...but why????
FollowupID: 491407
Follow Up By: Pajman Pete (SA) - Friday, Mar 30, 2007 at 08:21
MN1, because you can.
I think it is a power or control thing. Boot it from the CDROM and a few short keypresses and it overwrites the hard drive with zeros. Goodbye data.
"I'm having problmes with XP booting slowly, can you help?"
"Just put this disk in and XP will never boot slowly again."
Pete
FollowupID: 491410
Follow Up By: Member No 1- Friday, Mar 30, 2007 at 09:03
"Just put this disk in and XP will never boot slowly again"...is that because it deletes everything? or because it cleans out the junk...does'nt msconfig do this using startup tab?
FollowupID: 491418
Follow Up By: Pajman Pete (SA) - Friday, Mar 30, 2007 at 10:50
Other benefits:
It will make sure you no longer get windows error messages
It will solve all your disk space problems
It will clean all viruses and spy ware
It will wipe your IE Explorer history so SWMBO cant see where you have been
It removes the need to defrag your HD
But the most of the problems will return fairly quickly because it wipes the drive completely clean of the operating system, programs and data and you have to reinstall everything from scratch. ;o)
I use it for wiping hard drives before sending computers out for disposal.
Pete
FollowupID: 491443
Follow Up By: Member No 1- Friday, Mar 30, 2007 at 12:13
i knew that was a catch to it
FollowupID: 491453
Reply By: Gramps (NSW) - Thursday, Mar 29, 2007 at 18:33
Blaze, Sand Man et al,
What are you blokes doing? Your predecessors took great pains to hide all that knowledge away from the great unwashed so it could remain one of the 'dark arts' and here you are giving the game away !!!!
Many an old techo is rolling over in his grave ( or at least sitting uncomfortably at his screen ) now that you have revealed the Great Secrets LOLOL
AnswerID: 230499
Follow Up By: Mr Fawlty - Thursday, Mar 29, 2007 at 20:08
Soooooooooo True gramps, next they'll be showing them the skeleton and with this mob's penchant for goats well anything could happen... Why carn't they leave things alone?
FollowupID: 491354
Reply By: Gerhardp1 - Thursday, Mar 29, 2007 at 19:11
Did you get the "Recovery CD" set with the laptop?
If not, you will have to do an install of XP with native XP drivers and then go to the web and get all the special drivers for your model. If XP doesn't recognize the network card you could be in a catch 22 - no web access to get the drivers you need for web access !! You will need drivers for Modem, NIC, Chipset, Touchpad, Video, and maybe a couple of others as well.
There's a good chance the XP install of the laptop won't have SP2 so you will be faced with quite a few hours of updates to bring it up to date.
Then you can put your Antivirus on, and start installing your programs, printers, stc and configuring your e-mail, etc
My suggestion - find someone who knows about this process and let them do it.
AnswerID: 230506
Follow Up By: Mr Fawlty - Thursday, Mar 29, 2007 at 20:11
And don't think that if you have a "copy" of XP that you'll be "allowed" to download the SP2 upgrade. Actually you can it just comes up on your monitor a big flag that proudly declares "This is an illegal copy of windows XP", tres embarrasing especially at a Maccas wireless hot spot....
FollowupID: 491357
Follow Up By: Mr Fawlty - Thursday, Mar 29, 2007 at 20:12
This information was gained from an investigation, not from actual personal experience you understand....
FollowupID: 491358
Follow Up By: Gerhardp1 - Thursday, Mar 29, 2007 at 20:24
Yep, they're tightening up a lot more nowadays, quite right too.
But the used laptop should have the XP sticker on it if it's a name brand one. All name brand PCs that get returned to the lease companies have to have the Sticker and should have the media/recovery CDs as well. It's been like this for a few years now, at least with the lease companies I have sent stuff back to.
Making a few assumptions here.
FollowupID: 491359
Follow Up By: Gmouse - Friday, Mar 30, 2007 at 09:14
you can get xp-sp2 here www.soft32.com/download_992.html
FollowupID: 491422
Follow Up By: Mr Fawlty - Friday, Mar 30, 2007 at 11:57
Gmouse is the the version of SP2 that does not detect if your copy of XP is a fake? It's a huge download & I'm not interested in downloading it it it is going to tell me embarassing things...
FollowupID: 491448
Follow Up By: Gmouse - Friday, Mar 30, 2007 at 16:45
Hmmm.. so your not sure if its a legit copy :)
May be a corporate versions of XP could be required then :)
FollowupID: 491490
Reply By: Kumunara (NT) - Thursday, Mar 29, 2007 at 23:30
Outnabout David
Is it a HP laptop?
HP laptops come with the recovery software in a hidden partition on the harddrive. If you run the recovery program it will do it for you. If you format the drive yourself you will destroy that software.
If you have a manual - read it. If not go online and download one.
Tjilpi
AnswerID: 230558
Reply By: snow - Friday, Mar 30, 2007 at 15:41
Do people really still use FDDs and floppys? Ihaven't seen one for a long time.
AnswerID: 230645
