Mapping Software
Submitted: Thursday, Mar 29, 2007 at 16:08
Blaze
Had a rep from Hema post me out a demo version of one of their latest offering. Its called Memory-Map, what I want to know is as the demo version is pretty limited, has anyone used this program and how does it compare with Oziexplorer?
Reply By: Sand Man (SA) - Thursday, Mar 29, 2007 at 17:03
Blaze,
Don't try to compare it with OziExplorer. Two different animals so to speak I would think.
OziExplorer is the engine which can load and use any digitalized map you wish.
Perhaps I'm barking up the wrong tree as I'm not familiar with Memoery-Map, but even if it can run "stand-alone" (as can NATMAP Premium to view maps) I assume you will still need something like OziExplorer for saving tracks, waypoints and moving map capability.
I still thick OziExplorer is the best investment.
230482
Follow Up By: Blaze - Thursday, Mar 29, 2007 at 17:35
Hi Yah Sand Man,
The answer to the last part of your reply re having to run Ozi to do saving tracks etc, its actually very similar to Ozi. I should have put the url Memory-Map up before and you can have a look. The only thing I haven't done yet is check out whether it excepts maps from other sources.
491317
Reply By: Member - Toolman (VIC) - Thursday, Mar 29, 2007 at 18:11
I had a look at this product at the
Melbourne Caravan Show yesterday. They were being sold for around $299 for the software plus lots of Hema maps already loaded. From my very brief discussions with people on the stall, it has similar functionality to OziExplorer but I wouldn't
hazard a guess as to whether its as good as, better or worse. I may be biased but it would have to be very very good to even come close to OziExplorer.
Toolman
230495
Follow Up By: Member - Toolman (VIC) - Thursday, Mar 29, 2007 at 18:12
I forgot to mention, the software come from NZ apparently.
Toolman
491332
Reply By: ozdragon - Thursday, Mar 29, 2007 at 18:42
It comes from the UK. Ampro NZ is only the distributor down here.
230502
Reply By: Member - Doug T (W.A) - Thursday, Mar 29, 2007 at 19:00
Blaze
I will 2nd Sandmans comment here partly. I use my Hema Desert, and
Simpson Desert CD maps on the Oziexplorer set up, so they must be using the similar type of software.
230504
Reply By: curious - Thursday, Mar 29, 2007 at 19:24
Thanks for the url to Memory-map site. The base Discoverer version sold in Australia doesn't seem to have any additional functionality to OziExplorer and from the info on their web site, the two programs would appear to be similar. However the next level is Navigator ($50 US upgrade) and the higher version again is Professional ($175 US upgrade) although it doesn't indicate what you gain in these two higher versions.
There's two other advantages with OziExplorer: 1. it's widely used and if you have a problem, the author and many other users can often assist in resolving problems 2. OziExplorer gets reasonably frequent upgrades or fixes. The latter is a positive
sign from any software vendor. I've been using OziExplorer for work (mapping customer locations etc) and although it's a bit clunky at times, it's still very good value for its price.
230508
Reply By: Member - Russell H (WA) - Saturday, Mar 31, 2007 at 05:35
OK, I'll play the Devil's Advocate here. Why would anyone want Hema maps in the first place? It seems to me that they simply reinvent the wheel. I got Great Desert Tracks only to discover that there is not much more on it that my Natmap Premium raster maps show.
Then I thought about getting the
Kimberley Maps, but the scale is 1:1,000,000 and again, my Natmaps are 1:250,000. So what is the point?
I'm going to stick with Ozi Explorer, Natmaps and my own maps that I have scanned and geo-referenced.
230786
Follow Up By: Member - Davoe (Nullagine) - Saturday, Mar 31, 2007 at 16:50
I agree thay show nothing natmaps dont and alot of the tracks on natmap arnt on hema. Personally for that type of Map I find QPA more detailed
491724
