advise on pda gps + memory-map AusTour
Submitted: Friday, Apr 13, 2007 at 20:21
Mike_Tan
Hi all,
I am after my first GPS and wants it to be capable of both Street GPS and loading of topo maps. Rocked up to Johnny Appleseed this afternoon and got the following recommendations:
1) Ipaq rx5965 (which includes TomTom 6 Navigator) @ $729
www.ja-gps.com.au/hp-rx5965.htm
2) Memory-Map Austour @ $249 which apparently has a full set of Hema 4x4 tour maps within and "discoverer" license included
www.ja-gps.com.au/memorymap_1.htm
Now the questions:
1) Has anyone used the Memory-Map Austour before? Is it easy to use? Remember this is my first GPS as such i have no knowledge of Oziexplorer, Magellan, Garmin etc etc.
2) How hard is using a pda compared to say Garmin, Magellan etc etc
3) Anyone used an Ipaq rx5965 before?
Thanks... much appreciated... btw going the pda route because I can salary sacrifice.
Reply By: Doggy Tease - Friday, Apr 13, 2007 at 20:28
I have a Garmin I Que M4 PDA/GPS.It came with City navigator built in (with voice direction). This covers the whole of Australia. I use a 2gig card to run Oziexlorer and Track 4 Australia. Between all these, i can never get lost again i hope...:).
As soon as i turned it on i was able to get things going in the direction i wanted, but even now, six months later i'm still finding bits to learn on it.
meow.
rick.
233194
Reply By: Sand Man (SA) - Friday, Apr 13, 2007 at 20:51
The iPaq RX5965 PDA will run anything you need. As it has Navigator 6 preinstalled you are already setup for Voice controlled street directions.
I assume the PDA must also have a GPS Receiver either built in, or attached.
The PDA on its own is not a GPS.
Have no knowledge of Memory-Map Austour.
You may be better off with OziExplorer CE which will run on the PDA. Plenty of support here for that product.
OziExplorer can reference any digitalized set of Maps you wish to use.
Natmap Premium, Hema Australia 4WD Raster Map Collection, etc.
NatMap Premium maps are great for most situations.
Another point of consideration.
If you go the PDA path, you will need something to hold it and power it in the vehicle. There are PDA holders available to suit most brands, including the iPaq.
I have a Haicom 4in1 holder which, although I am having a hissy fit with, tying to get Bluetooth comms to work, is good for holding the PDA, powering it in the vehicle and amplifying the sound on its built-in speaker.
233207
Follow Up By: Mike_Tan - Saturday, Apr 14, 2007 at 01:31
Thanks for the feedback.
The iPaq RX5965 does have a built-in GPS receiver and comes with a car cradle (presumably suction cups)
The OziExplorer CE (CD & CE upgrade) is currently retailing for 166.60 on Exploroz
Site Link
will this be all i need? Could anyone give me a rough on how much digitalised maps cost? Really only need it for NSW at this stage but would consider set of maps if they do not cost much.
494139
Follow Up By: Bonz (Vic) - Saturday, Apr 14, 2007 at 08:43
you'll need the maps for OziExplorer to use.
Sandy a great reply mate
494157
Follow Up By: Pajman Pete (SA) - Monday, Apr 16, 2007 at 09:34
I have the IPAQ 5765 which is almost the same unit. As wellas the built in Tom Tom I also run OziExplorer CE on it with the NatMap rasters. It all works fine.
I still use my Garmin Etrex away from the vehicle - it is alot more robust.
Pete
494590
Reply By: Phil P - Saturday, Apr 14, 2007 at 16:39
The Ipaq 5965 is a great product to use. The suction mount works very
I run Oziexplorer CE on it. I purchased all the VIC Maps from an EBay seller for under $40 delivered. Try contacting the seller to see if they have the NSW maps available!
Site Link
233353
Reply By: Gramps (NSW) - Saturday, Apr 14, 2007 at 18:09
Mike,
Go to GPSAustralia and put your name down for FREE Nsw and Vic Topo maps rather than feed some of the thieves currently advertising on Ebay.
233367
Reply By: Mike_Tan - Saturday, Apr 14, 2007 at 21:53
Thanks guys for the replies.
Did some enquiries today on using a smartphone pda such as HP iPAQ rw6828 or o2 Xda Atom Exec for running of street GPS and oziexplporer as
well and general consensus from sales persons is that they are generally slower due to running of more apps and the GPS disconnects when there is an incoming call. Any truths in that?
233441
Reply By: John R (SA) - Sunday, Apr 15, 2007 at 13:17
I run a 5965 (comes with a suction cap window mount, which is quite adequate, but worth also getting a cigarette lighter power plug), oziexplorer & natmap raster.
I have a swag of other maps, but find the natmap the most versatile and best suited to the zoom levels I use (ie if I use a local fire map at a zoom level which provides reasonable forward vision, all the text is too small to read. Natmap seems to have larger text, so I can zoom out further and still be able to read it).
Although my old garmin II+ is easier in so far as I turn it on, and it goes, the pda is much more versatile and once you start doing slightly more advanced things, like waypoints,
routes etc, the pda is streaks ahead.
I've not used any of the new, top range garmin or magellan, but some of the advantages I like with a pda;
the memory card allows
- multiple maps to be stored,
- multiple waypoint files, track files
and probably a boat load of other things which don't jump out at me know.
233526
