Portable solar panels vs roof fixture
Submitted: Friday, Apr 13, 2007 at 20:45
ThreadID: 44283 Views:6303 Replies:15 FollowUps:32
I was considering an 80watt solar panel for the caravan roof (around $750 -plus regulator/wiring/ frame) but then looked at the folding case (2 x 40W ) type with included regulator and cable.
There are obviously pros and cons of either.
The fixed roof panel is a lot cheaper more secure (less obvious) and requires some roof rails to be fitted. If the van is parked in the shade to keep cooler- the charging suffers. If you leave the van and take the tent for a night or two on some rougher tracks , The panel stays behind.
With the portable unit (around $1200) you have more options but more work setting it up and I would think a chain was mandatory to secure it when you left the site even briefly and overnight.
(hoping no-one has bolt cutters! ) You also have to store the case safetly when packing up.
I am especially interested in the experiances of those with portable panels.
Are they a hassle? Cheers
Reply By: Jimbo (Vic) - Friday, Apr 13, 2007 at 21:00
IMHO get the portable setup with at least 10 metres of thick cable, preferably 20.
This way you can chase the sun and get the most out of your panel/s.
Your van should be in the shade for comfort and hence your solar will be as useless as hip pockets on your undies should you mount it on the roof of the van. Effective solar panels need to be moved many times during the day to maximise their output.
Also give some thought to an amorhous panel (Uni Solar brand). They are bigger for a given output, but are more efficient.
ATB,
Jim.
AnswerID: 233211
Follow Up By: Wingwang - Saturday, Apr 14, 2007 at 15:43
unisolar much less efficient
much bigger for much smaller output
64w unisolar 1.1 mtr sq 9% efficient
120w suntech 1.0 mtr sq 17% efficient
FollowupID: 494223
Follow Up By: Jimbo Vic - Saturday, Apr 14, 2007 at 20:24
Are you still here Ozi?
Flogging your business.
Telling lies about solar to increase your sales.
FollowupID: 494276
Follow Up By: Mainey (WA) - Sunday, Apr 15, 2007 at 21:12
Ditto.............
However - don't buy elcheapo panels :(
get the true "facts" before you spend the cash
Look at the panel you THINK you want to buy, if your happy with the way it's assembled, eg looks like a blind, one handed monkey assembled it and your happy with that, then buy it.... remember it is the type of panel and what's inside that little black box underneith that counts also.
But - if you want better quality and manufacturing techniques then buy a quality built panel, first look at SunPOWER and Sharp and compare anything you want with them for starters, the really simple things like the type of screws that hold the aluminium frame together and if they are countersunk etc actually become important when you transport it around often.
Also look at the technical numbers supplied and the INability or the Ability to work in low light, generally if it is not specified it does NOT exist.
Mainey
FollowupID: 494491
Follow Up By: Mainey (WA) - Thursday, Apr 19, 2007 at 14:43
This equation;
-> 64w unisolar 1.1 mtr sq 9% efficient
-> 120w suntech 1.0 mtr sq 17% efficient
...as posted above
is like comparing a 3 cylinder Suzuki with a Hummer
and is not to be construed as relevant to battery charging efficiency !!
When panels of ~equal capacity are compared the following results are seen
....Suntech 60w panel,
is only rated @ 3.49 Amp, 17.2v
with only two (2) year quality build warranty.
....Unisolar 64w panel,
is rated HIGHER @ 3.88 Amp, 16.5v
You have to compare like 'apples with apples'
and comparing two totally DIFFERENT types of panels will only give you the "best possible" outcome as I have posted above, the similar wattage panels gives Unisolar the HIGHER amperage and that IS what you buy a solar panel for, to get as many AMPS out of a panel in a given time period, because you only get a limited number of 'sunHours' per day.
It is AMPS that will recharge your battery, as long as the ‘Voltage’ generated is high enough in the panel, and yes it is in BOTH panels, so you use the solar panel with the largest AMPS obtainable in a given time period, in this very limited comparison between only two nominated panels it’s the Unisolar panel that will do the better job, the maths tell me that.
Mainey...
FollowupID: 495425
Reply By: Sand Man (SA) - Friday, Apr 13, 2007 at 21:09
Mate,
I have a half of a folding panel.
By that I mean that I have one 40 watt framed panel, including the regulator a cable. (BP Solar) I can add another panel and fold it if I need the extra capacity.
My experience with the portable unit is......it works!
Has a couple of legs that fold down and you simply point it towards the sun, or in a direction that the sun falls on the panel as it goes from east to west.
Storage is usually as simple as sticking it under the matress. This works for me with the Camper Trailer and will do the same for a caravan.
Security......Always going to be a problem on occasions. The places I've been I just take the chance. A stainless steel braided cable padlocked to the frame and Camper/Caravan chassis, or A-frame is as practical as anything.
If the mongrels want it, they will find a way of pinching it, or destroying it trying.
Bill
AnswerID: 233213
Reply By: Member - cliff J (VIC) - Friday, Apr 13, 2007 at 21:30
hi there
i have an 80 watt fold panel works fine it has a length of cable as already been suggested ihave put anderson plug on end one on van then move to sun my van is pop top when i leave camp i put on roof its not so noticable i also have a regulator beside battery which also works fine
AnswerID: 233219
Follow Up By: lifeisgood - Friday, Apr 13, 2007 at 21:44
Thanks for those comments guys. It does come with a heavy 8 m cable . The Anderson plug on van sounds good. Putting it on the roof when you go would be less inviting. The uni-solar does have shade advantages if I can find a portable version.( Had been thinking BP)
FollowupID: 494091
Reply By: KiwiAngler - Friday, Apr 13, 2007 at 21:32
I have an 80W folding solar panel from Suntech
As you can see the price of $950 (which includes bag and regulayor and cabling is VERY competitive
I have had one for a while now and it workd VERY well
AnswerID: 233220
Follow Up By: lifeisgood - Friday, Apr 13, 2007 at 22:07
Thanks KiwiAngler Thats an interesting price but the guy has closed his shop , so has only a postal address and no longer a phone contact - only fax or email. Did you buy from this site with your credit card? If so was the service / delivery ok ?
FollowupID: 494097
Follow Up By: KiwiAngler - Friday, Apr 13, 2007 at 22:28
Yes he is on holiday for 8 weeks, back 17th June (according to website)
I purchased from his site using credit card
Service and delivery were 100%. I am based in Wagga and the panel came from Melbourbe cost $25 freight (I think) and took about 4 days
How I use it is :
I have a dual battery setup, through a Piranha managemnt system.
As soon as I arrive at my camp site I set the panel up and connect to my Pirahna (it has a plug built in for this purpose) and lock the panel to my front bumper using LockAlarm ( I have a couple of these including the 15ft one for the Solar Panel) basically the panel charges the second battery, which in turns runs ny lights and Engle.
All I have to do is move the panel occassionally to follow the sun.
FollowupID: 494104
Follow Up By: Sand Man (SA) - Friday, Apr 13, 2007 at 22:58
hey KiwiAngler,
That Lock Alarm is an interesting bit of kit and I want one.
Is there a distributor in Australia that you know of?
Bill
FollowupID: 494113
Follow Up By: KiwiAngler - Friday, Apr 13, 2007 at 23:19
There is an Australian distributor - just cannot recall who - but if you go to this website and fill out enquiry form they will tell you
link text
here is a pic of my setup ( u will have to cut and paste as I cant get the link to work the other way)
Site Link
FollowupID: 494119
Follow Up By: Sand Man (SA) - Friday, Apr 13, 2007 at 23:26
Nice camp set up there matey.
All you need is a river with Trout in it.
Ah, I gotta get back to the Tongarero River near Lake Taupo some time.
Bill
FollowupID: 494123
Follow Up By: KiwiAngler - Saturday, Apr 14, 2007 at 13:47
I was actually setup in Geehi Campsite right alongside a river and in the morning I saw a couple of nice sized brown trout rising - I have now purchased a small rod which breaks down for easy storage and some lures so next time i am down there i will give it a whirl
Next mods are:
fit interior roof console
move UHF up into console
fit Icom HF ICOM and put that into roof console too.
fit Moonraker Autotune HF aerial
remove rear view mirror and replace with 5" reversing camera and screen
fit awning
That should be enuff for a while :-)
FollowupID: 494199
Follow Up By: SARocks - Saturday, Apr 14, 2007 at 15:38
bought Suntech folder 80 for $929 delivered
arrived yesterday del to front door
link text
FollowupID: 494222
Reply By: Derek from Affordable Batteries & Radiators - Friday, Apr 13, 2007 at 21:42
100W minimum for fridges.
I have done tests and only the 50L and under will run off 80W.
I have even stopped producing the 80w Bi-folds.
Derek.
AnswerID: 233227
Follow Up By: Sand Man (SA) - Friday, Apr 13, 2007 at 23:19
Derek,
My tests with a 40 litre Engel has backed up the advise I was given from my retailer that a 40 watt panel was probably sufficient.
I have the option of "doubling up" with another panel if necessary but just haven't found the need.
You must have been testing some hungry fridges mate, given all the sunlight you would get in the "Sunshine State" where you are:-)
Bill
FollowupID: 494120
Follow Up By: Derek from Affordable Batteries & Radiators - Saturday, Apr 14, 2007 at 00:25
Hi Sand Man
I must live in the twilight zone.
I would need 10 to 11 hours 'good' sunlight a day to keep a 40L Engel going on a 3 week camp out using a 40W panel and tracking the sun all day.
Do you back the panel up with a genny or by running your car ? :-(
I see you have around 150 a/h so you could possibly go 8 to 9 days with your 40W panel with 'good' sunlight.
I would be pleased to test your panel on a 40L Engel. I will be on a Birdsville and outback trip for 3 weeks soon.
I will return it in good condition and pay TNT freight both ways.
I have never heard of a 40L Engel running on a 40W panel for more than 4 to 5 days before the battery died. (80 a/h)
Please supply details of your retailer. I would like to put him to the test.
I am not taking a dig at you or the available sunshine in Australia but I will ''NOT" sell a 40W panel to someone and promise them that is all they need.
Our test on the new sidewinder 50L fridge shows it to use less power than the Engel 40L. I will be testing our new 120 a/h battery pack and 100W Bi-fold on the trip running our new 50L.
The following table shows the monthly and annual peak sunhours for various locations in Australia. It is a 'VERY' rough guide and is given for information purposes only. Please do not use this guide to plan your next trip.
MELBOURNE SYDNEY BRISBANE
January 6.9 6.7 6.5
February 6.4 5.8 6.2
March 5.2 5.7 5.7
April 3.8 4.4 4.8
May 2.8 3.6 4.2
June 2.4 3.4 4.1
July 2.7 3.3 4.2
August 3.3 4.4 5.2
September 4.3 5.2 6.0
October 5.3 5.8 5.9
November 6.1 6.3 6.0
December 6.6 6.9 6.3
Annual 4.6 5.1 5.4
The peak power output of modules is rated in kilowatt peak (kWp
Derek.
FollowupID: 494131
Follow Up By: Derek from Affordable Batteries & Radiators - Saturday, Apr 14, 2007 at 00:29
Forgot to mention the source of the chart.
Australian Gov Site
Director
Buildings and Government Efficiency
Australian Greenhouse Office
Department of the Environment and Heritage
GPO Box 787
CANBERRA ACT 2601
FollowupID: 494132
Follow Up By: Russ n Sue - Saturday, Apr 14, 2007 at 05:27
You're spot on Derek. Another thing worth mentioning (and often overlooked) is that while you may be able to keep running the fridge until the battery simply won't do it any more, you are also destroying the battery in the process.
The Depth of Discharge varies according to the make-up and chemistry of the battery, but as a rule of thumb, the deeper a battery is discharged, the shorter its lifespan.
I run 2 x Sharp 123W panels and 305 AH of batteries to keep my 50l and 40l Waecos going (plus the odd low current light) and I monitor their condition regularly with my Plasmatronic solar regulator. Hopefully we'll get a few years of operation out of the batteries with this setup.
FollowupID: 494143
Follow Up By: Sand Man (SA) - Saturday, Apr 14, 2007 at 11:17
Derek,
You have misread my reply, or taken it out of context mate.
I said my Retailer suggested that one panel of 40 watts should be sufficient to maintain a charge in the battery to run the 40 litre engel. No statement on how long this could be maintained was quoted and I understood exactly what the Retailer was saying. They also provided a "growth path" should I need more charging capacity, by stating I could add another panel without the need for a different controller, etc.
So they provided a cost effective solution with an expansion capability.
I value this sort of straight talking information from a Retailer and I will have no hesitation in returning to them for additional business.
Of course, they could have promoted a double (80 watt) panel up front, but would I have bought it at that time? Probably not. (I had SWMBO with me)
Derek, I am not questioning your testing procedures but mate, you must be running the 40 litre Engel as a freezer, flat out.
My testing is not all that scientific. I go camping, connect the Fridge to the battery supply and connect the solar panel also. The longest period I have been stationary so far, is three days, after which my multimeter showed negligible drop in battery capacity. Simple as that. And I use two fluros at night as well. If I need a longer time at one spot and find the one panel not sufficient, then that is the time to "boost the juice". Oh, and yes, I can charge the battery supply from the vehicle if I have to.
Perhaps as a Retailer, you are "erring on the side of safety". Nothing wrong with that, providing that you explain to your customers why you won't sell them something smaller & cheaper that will still do the job.
Saying that "100 watt minimum for fridges" is a bit over the top mate and needs to be kept in context. Some people read this information and take statements as "gospel".
It gets down to how a person is using their fridge, (fridge or freezer) how big it is for the size and type of battery its running off, where the fridge is being stored during the day and maybe even how often it's opened.
That is what my Retailer took into consideration when asking me how I intended using my fridge and suggested a solar unit that would (in their experience) do the job.
The name of my Retailer? I have no problem "promoting" them when asked.
Home of 12 Volt (Blue Apple)
Bill
FollowupID: 494178
Follow Up By: lifeisgood - Saturday, Apr 14, 2007 at 12:03
Fair comment thanks Sandman
Whilst bigger tends to be better - it comes at a fair price premium.
My gut feeling is that 80W will probably do for my 35l Waeco and 2 Flouro lights.
I will probably carry the fridge in the car when I leave camp on day trips so the van battery will get a solar boost by itself. I will check that web site too thanks
FollowupID: 494182
Follow Up By: Derek from Affordable Batteries & Radiators - Saturday, Apr 14, 2007 at 12:45
Hi Sand Man
"I said my Retailer suggested that one panel of 40 watts should be sufficient to maintain a charge in the battery to run the 40 litre engel. No statement on how long this could be maintained was quoted and I understood exactly what the Retailer was saying. They also provided a "growth path" should I need more charging capacity, by stating I could add another panel without the need for a different controller, etc.
So they provided a cost effective solution with an expansion capability. "
You must have been testing some hungry fridges mate, given all the sunlight you would get in the "Sunshine State" where you are:-) "
I answered a simple question and offered advice which is intended to be read as 80W for under 50L and 100W for bigger ones. I work on total solutions for my customers.
Your system is running more on the car and battery capacity than the 40W panel. Park it out in the sun and see how many days it takes before the battery reaches zero capacity of +-11.6 Volts. I would say 7 to 8 days on your exide and thumper should do. Set the 40L Engel to what ever you think is the most efficient. Please email me the results, it would be appreciated.
"Some people read this information and take statements as "gospel". "
No, more like the recommended minimum capacity for his or her needs based on the information supplied.
You should have said from the start that your longest test on 150 odd amp hours is 3 days with the 40W panel and then "boost the juice".
Your first response was...
"My tests with a 40 litre Engel has backed up the advise I was given from my retailer that a 40 watt panel was probably sufficient.
I have the option of "doubling up" with another panel if necessary but just haven't found the need."
I read this as 40W is all you need, don't bother with a bigger panel.
I know the owner of Home of 12V and he knows what he is talking about. I even did a test he recommended on a particular 7 amp charger and we no longer buy chargers from that supplier.
email me your address and I will send you one of our carry bags for your panel.
Derek.
FollowupID: 494190
Follow Up By: Sand Man (SA) - Saturday, Apr 14, 2007 at 17:43
Good Oh Derek,
I'll Member message you.
I know that you know Gary from Home of 12 Volts.
He has mentioned in conversation that he knows you. (Nothing derogatory either)
My intention in answering some of your comments was to keep the discussion ballanced for those readers without direct electrical knowledge and experience, both of which I have.
Cheers mate.
Bill
FollowupID: 494239
Follow Up By: Mainey (WA) - Sunday, Apr 15, 2007 at 21:28
Russ n Sue posted this followup
"I run 2 x Sharp 123W panels and 305 AH of batteries to keep my 50l and 40l Waecos going (plus the odd low current light) and I monitor their condition regularly with my Plasmatronic solar regulator"
You guy's use quality solar panels, that is the reason they work so well.
I use the 123w Sharp ND-L3EJEA panels because of it's ability to work in very low light and with 17.2v operating voltage (not OC voltage) they are efficient.
FollowupID: 494509
Follow Up By: Mainey (WA) - Tuesday, Apr 17, 2007 at 14:51
SHARP ND-L3EJEA poly-crystalline silicon photovoltaic solar module with 123Watt power.
Link-> http://abcsolar.com/pdf/sol_dow_123W_SS.pdf
FollowupID: 494895
Reply By: crykies - Friday, Apr 13, 2007 at 22:07
G'day not sure what others think but i know what i think from using a 80 watt bp panel for portable use with my home made stand and must say that it works fine Keeps up with a 32 and 39 L engels for my 2 week camping trips on a 100 amp H . panel cost me $650 cable $60 from whitworks and regulator from bcf (on special at the time for $29) home made stand i used bits and pieces from the curbside clean up. Used a old baby rocker works a treat and pulls apart for transport to see here is the link copy and paste Site Link .For security all i did was goto a wire cable place and got a SS cable made up. As already stated if they want it they will take it or destroy it trying.
Fold up great for space, but i have a camper and place it in there when on the move, not like it is in there when ya camping etc. Follow the sun and all should be well, mind you i have a honda geny for back up but have never had to use it !! (NOT MUCH RAIN AROUND LOL)
Any question ask i will help where i can.
AnswerID: 233235
Follow Up By: lifeisgood - Friday, Apr 13, 2007 at 22:21
Nice frame Crykies Keeps it out of the sand too.
I have a 35L Waeco so from what you and Derek are saying that should be ok with the 80W in practice.
Are you running both fridges for 2 weeks from this panel??? Do you switch them off at night or run as 24hr operation. (seems a big ask!?)
FollowupID: 494101
Follow Up By: crykies - Friday, Apr 13, 2007 at 23:02
The waeco will run fine if you have fine weather i think they use nearly twice what the engel uses amp wise. (never had 1 just from reading) but mine run fine bad weather and clouds i am sure would effect my system but u have the generator as back up if need be. i just carry my multimeter and check the voltage morning and night and have not taken the battery down more then 11.5 volts over a 2 week period. 1 engel runs as a freezer don't realy open often. and other as a fridge set at 2c. Works for me and i can also get away with using the torpedo fluro light.
FollowupID: 494114
Reply By: FZJ 80 - Saturday, Apr 14, 2007 at 09:56
Lifeisgood,
We bought an 80w BP panel,cable and morningstar regulator off Derek. Used 50mm angle alloy brackets to mount on poptop roof. Set it up so as it is removable.
Bolts slide thru the front angle brackets and padbolts slide thru the rear angle brackets. Put 2 padlocks on,secure as. Post your email and i can send you some installation photos.
AnswerID: 233293
Reply By: Member - Lance S (VIC) - Saturday, Apr 14, 2007 at 10:46
Lifeisgood,
I have 2 x 80w BP panels wired up together with regulator that tells me what wattage, amps, current i am drawing, and how my battery is charging, tells u everything. I run a 110 waeco and 2 deep cycle batteries. Still , i always carry a multi metre. The panels are on adjustable home made stands, where i can move or put them to suit the sun. To be on the safe side, i chain mine up to the A frame of the trailer. I had a weather proof, insulated bag made for them for travelling which stays on the roof rack of the camper trailer. Bought it all from Jaycar in Frankston.
cheers, Lance
Home Away from Home
AnswerID: 233299
Follow Up By: lifeisgood - Saturday, Apr 14, 2007 at 11:35
Thanks Lance and all others above . Its always great to get these varied opinions which helps not only myself but the many other viewers who share an interest in the topic.
Lance did you get the PANELS from Jaycar Frankston ?
FollowupID: 494181
Follow Up By: Member - Lance S (VIC) - Saturday, Apr 14, 2007 at 12:29
Yep, everything from Jaycar in Frankston, they gave me a great deal and were very helpful.
cheers, Lance
Home Away from Home
FollowupID: 494184
Reply By: Russ n Sue - Saturday, Apr 14, 2007 at 12:18
To calculate what size solar panel you need see the example and methodology below:
1) Observe your fridge for a couple of duty cycles - Set your fridge up in a typical place such as you would when camping. Do your test at an average time of the day so far as ambient temperature goes (not the hottest, nor the coolest part of the day. Load the fridge with similar stuff to what you would take camping. Set the thermostat to the temperature you normally would when camping. Allow an hour or two for the fridge to settle - preferably running on mains supply if available. Now record the running and non running time of the fridge for two or three cycles.
Typically you might get a 20% - 30% duty cycle.
2) Find out the typical current requirement of the fridge. If you don't have a digital voltmeter just find out the wattage rating specified for the fridge and divide it by 12. For example if the manufacturer claims the fridge is 36W, then your current demand will be near to 3 Amps.
3) Multiply the current demand by the duty cycle by 24 (hours in a day)
eg 3 Amps x 30% x 24 hours = 21.6 Amp Hours per day.
4) Regardless of what battery capacity you have, your solar panel needs to replace the amount in step 3 in the available sunlight hours if you are not to drain your battery. So when choosing a panel, look at its rated wattage. Take 10% from that figure because the rated wattage is under optimal conditions and not achievable in reality. Let's use the example of a 40 Watt panel:
40W x 90% (efficiency) = 36 Watts.
36 Watts divided by the nominal output voltage (13.6 Volts or thereabouts) will give the current output of the panel.
eg 36 / 13.6 = 2.65 Amps.
Multiply this by the expected hours of sunshine. This is a bit problematic, but if you used 6 hours as a typical figure you would be in the ball park (although personally I think that is more than you would experience over time in southern Australia).
So, 2.65 Amps x 6 Hours = 15.9 Amp Hours.
So, we calculated that we need 21.6 AH and we can supply 15.9 AH (Just as well that you have that battery!)
Ideally you shouldn't use a depth of discharge for a battery of more than about 50% if you are to maintain a good cost versus life expectancy equation.
So if you had a 70 AH battery (which would typically have about 3% internal losses - but we'll ignore those), then ideally you should not reduce your Amp Hour capacity to less than 35 AH.
In our example, 35 AH / 5.7 AH shortfall each day (with a 40W panel) = 6.1 days.
6.1 days of running time. Now all of these figures have been pretty generous. We didn't allow for extra running of the fridge after it has been opened, or new goods have been added that need to be cooled (more beer, for instance). Nor have we taken into account shady/cloudy periods. We didn't allow for any other uses such as lights, fans etc..... also drawing extra current. We didn't allow for hot ambient temperatures.
This is purely subjective, but I suspect the true figure would be closer to 4 days. Sure, you could run the fridge for longer than this, but in doing so you start to dramatically reduce the life of your battery too.
You could repeat this exercise for panels of other ratings such as 60W, 80W or more. Each higher wattage you calculate will reduce the shortfall in your battery. Ideally you should aim for a small surplus of energy. (You never know when you might just need a charged battery to start the car!)
OK, these figures are approximate, but close to reality, so please, no-one jump down my neck and reply with "I get this" or "I get that". I'm just trying to simplify it for those who would like to know how to work it out - using reasonable figures.
AnswerID: 233311
Follow Up By: Derek from Affordable Batteries & Radiators - Saturday, Apr 14, 2007 at 12:52
Hi Russ
Best explanation yet.
You understand what most don't.
Derek.
FollowupID: 494193
Follow Up By: lifeisgood - Saturday, Apr 14, 2007 at 14:32
Top effort Russ n Sue
It helps to confirm my gut feeling for 80W panel which will give some spare capacity and allow for more losses and overcast days.
By the way , since the drought Melbourne is now Sunshine city. Fabulous weather.
Sydnet / Brissy eat your hearts out ( Ducking !) LOL!
Appreciate the realistic arithmetic Cheers
FollowupID: 494209
Follow Up By: Member - Brian (WA) - Sunday, Apr 15, 2007 at 12:16
Russ. There are two files in the swap file section for calculating your needs.
Have you seen these. Brian
FollowupID: 494386
Reply By: Member - Brian (WA) - Saturday, Apr 14, 2007 at 12:27
Hi. I have my panels on the roof of the wagon. That way when I leave camp the
panels go with me. I have made a lead up to plug into the camper battery from the
panels to top them up. Have my 2x40L Engels in the wagon.so don't use much power from camper battery only lights. Also T
the engel I use as a freezer I turn back to 1.5 setting when I stop getting power from the
sun and do not open it
AnswerID: 233313
Follow Up By: lifeisgood - Saturday, Apr 14, 2007 at 14:52
Hi Brian Liked your trip photos--- and virtually 3 x 80W panels tilting off the roof.
Fairly secure and quick to set up. No problems getting stuck for long with a flat starting battery.
Actually , that raises another the interesting question. Will a smallish solar panel
(say 3 amp) be able to bring back a DEAD FLAT 4wd starting battery (NZ70 size)
A lot of smaller battery chargers cant cope with this task.
(Ignoring length of time to do it )
FollowupID: 494216
Reply By: harris - Saturday, Apr 14, 2007 at 21:24
I have a 85w Panel {Suntech} mounted on frame roof rack at 25-30 degrees angle facing the front and running accross vehicle. Panel can be removed by wingnuts from frame. Have canvas padded cover for added protection. however rarely use and initially feared rock damage however travelled thousands kms, dirt, rough and rocky no problems. Can use panel when vehicle in motion to charge two static "lifeline 100 amp batteries" inside vehicle. always use regulator on panel stops any damage over charging. This set up took a bit of work however "highly reccommended". My set up is on a toyota troopie. further have small locking device to prevent theft. However if they want it (panel) they have to cut to remove it.
Hope this helps. Further you have to carry the panel somehow so why not mount it and use it. Regards.....Harro......
AnswerID: 233430
Reply By: Member - Blue (VIC) - Sunday, Apr 15, 2007 at 08:21
The way the missus and kids are in and out of our 110L Waeco, I think I need a 3000 watt panel... Anyone know where I can get one under $1k...??? ;-)~
AnswerID: 233492
Reply By: Member - Brian H (QLD) - Sunday, Apr 15, 2007 at 10:05
I don't want to hi jack the tread but I have noticed some use BP panels and others use Suntech (i think is the name) i assume they are only brand names. As with most things you get what you pay for so I assume there is a quality issue between panels so how do you pick a good solar panel?
Brian
AnswerID: 233507
Follow Up By: Mainey (WA) - Sunday, Apr 15, 2007 at 21:53
Brian, the guy who sells suntech will tell you it's the best :(
the guy who sells the unisolar will tell you the same story
Compare them to a quality built and specified Sharp or SunPOWER solar panel first in appearance of build quality, yes nothing at all to do with the way they work but how well constructed they are.
Next compare the technical numbers of each panel and if they are specified as suitable or in fact will even work in very low light.
Low light panels will start collecting 'power' from sunrise till sunset and in very heavy cloud as well, this all adds up to more power per given day.
A hint is to use an AGM battery that is sufficient to run the fridge for at least 4 days, the solar panel only has to replace the power used by the fridge/lights.
While the fridge is off, the battery is being recharged, while the fridge is running the solar panel is actually replacing the power for the fridge, so the battery is "almost" never below 12v unless it gets down that low after a few nights with-out sun.
My own battery 'cut-off' switch is set @ 11.5v and has never, ever been activated, and my fridge runs at ~8 amps, and its on 24/7.
That is your starting point.........
if you use 30amps you have to replace it - simple.
FollowupID: 494515
Reply By: Bat - Sunday, Apr 15, 2007 at 15:30
Hi,I went throught the solar panel idea but in the end brought a genenator,wired a 20amp three stage battery charger into the Toyota plug in the caravan if the battery is low otherwise just charge the frig batteries work like a dream being on the road for over twelve month.Bat.
AnswerID: 233549
Follow Up By: Russ n Sue - Sunday, Apr 15, 2007 at 23:14
G'day Bat,
We gave some thought to getting a generator but eventually went for purely solar. I think if we were occasional travellers the generator would be the answer, but we will be on the road full-time as of May 25th. In the end the decision to go solar came down to these factors:
To run what we want to run and to keep our batteries topped up we would use about $6.00 per day in fuel (This was based on the fuel consumption figures for a 1KVA Honda that I saw on a couple of different websites.). If we elected to stay at caravan parks and get powered sites, the price difference between powered and unpowered appears to be (on average) between four and six dollars per day. Either way we would be looking at something in the order of $2000.00 per year to pay for this.
The cost of a decent generator (eg a Honda) was the same as one of our solar panels. The two solar panels cancel out the $2000.00 running cost of a generator in one year. Knowing how much it costs for decent high current, three stage battery chargers, you have probably outlayed almost as much for the generator and charger as we have for our solar panels.
No need to carry volatile fuel and oils and the risk of spillage that goes with them. No need for servicing. No breakdowns. No noise. Similar weight to carry (although the volume occupied by the panels is much more than a generator - but we found a way to fit them in.)
Having camped at some unbelievably tranquil places only to have the silence broken by neighbouring generators, we did not want to be in a position where we would be annoying others.
All in all, we just couldn't see too many reasons to go with a generator, but I can understand why some people do. We have done quite a few trial runs and so far have not suffered from a prolonged lack of sunlight that has forced us to run the vehicle to top up the batteries - but I'm sure it will happen some day. In the meantime, we've had the panels for more than a year now and they've paid for themselves.
Each to his own I guess. I'm glad the generator solution works for you.
FollowupID: 494533
Reply By: Bat - Monday, Apr 16, 2007 at 10:43
Hi Lifeisgood,What we found up north it can be be very hot even in the winter months and bush camping it nice to have the air to put on.You need 2kva to run it and my Honda in very hot condition found it hard going,so top the batteries up then. Super Cheap have a 17amp two stage charger for $200, Australia made see a lot around good product.Allso the honda has a 8amp out let.People I spoke to long term travellers all say If you can keep the battery top up they will last for years.As you say everone has a idea but I found running 2 frigdes battery in the Toyota and allso being able to use the caravan battery for fridge, running the generator was not a problem.Just used a Anderson plug,well have a great trip.Bat
AnswerID: 233727
