Deep cycle batteries
Submitted: Thursday, Apr 19, 2007 at 16:51
ThreadID: 44505 Views:2836 Replies:2 FollowUps:1
Hi all, Deep cycle batteries apparently are harder to charge. When camping would it accept charge from a solar panel during the day to compensate for the Engel or does one need to "punch in" the charge from a charger ? Thanks
Reply By: Crackles - Thursday, Apr 19, 2007 at 17:06
Most deep cycles accept charge at a slower rate & ideally should be charged at a slightly higher voltage as well making solar panels ideal.
Cheers Craig...............
AnswerID: 234525
Follow Up By: Member -Dodger - Thursday, Apr 19, 2007 at 17:38
AGM batteries will take whatever charge that is available until charged and are excellent for solar charging, some even use them for starting batts.
Mine runs the van and all its equip and recharges from one of three sources when available IE. From the vehicle, from the 240v charger and from the solar panel.
It has lasted 7 years to date'.
Cheers Dodg.
FollowupID: 495456
Reply By: Sand Man (SA) - Thursday, Apr 19, 2007 at 17:57
"Wet cell" deep cycle batteries take longer to charge fully from a vehicle alternator. In fact, it may not be possible to get a 100% charge via the alternator in a dual battery setup.
AGM deep cycle batteries however, will charge much quicker and to 100% charge from a vehicle alternator.
Regardless of the type of battery though, a reasonable solar panel will have a beneficial effect on battery life.
If you take a 40 litre Engel as an example, the maximum draw from the battery is 2.7 amps (for the current model) and in practise will be somewhat less as the fridge cycles on and off. The actual amount of current draw will depend on ambient conditions and how high the thermostat is set but again, taking a 40 watt solar panel as an example, you can expect in the order of 2.5 amps in normal conditions so you will be putting back about as much as you take out (or more) for several hours per day.
Cloud cover, etc. may have an adverse effect on the amount of current you return to the battery and larger capacity fridges, with a subsequently higher current draw, will determine the need for a larger panel.
In my practical experience I have got a minimum of 3 days running the fridge of a 75 Ah+ AGM battery pack, supplemented by a 40 watt panel. At the end of this period the battery pack was still showing "charged" and I believe I may get much longer from my setup if I needed to, but I have no desire to "experiment" unnecessarily.
I have the backup of an auxiliary battery in the vehicle and the ability to also charge both the auxiliary battery and portable battery pack from the vehicle alternator.
This setup may not be the "optimum", but it works for me and I have an expansion path in adding another 40 watt solar panel if necessary, for a moderate cost outlay.
Hope this has given you some ideas.
Bill
AnswerID: 234538
