last word on cobb
Submitted: Monday, Apr 23, 2007 at 21:53
Member - Mal B
cooked a perfect roast fri my best yet, used a new bag of beads. put in 11 beads and used a new to me brand of fire lighters [red heads match and firelighter in one] i think the secret is in the lighters they had the beads glowing and all even heat first time ever you could here the meat cooking, also cooked indoors [will look into a bra for the base later] safe driveing mal b
Reply By: Sand Man (SA) - Tuesday, Apr 24, 2007 at 01:16
Good one Mal.
Yeah, old, or damp beads will cause grief for sure.
That is why I generally buy the 3 kg bag of Heat Beads EasyLites. Less chance of them "going off".
No smell from the Fire lighters? That used to be the big downside to them.
I must say, I quite often cheat and use a gas torch on the heat beads to get them burning quicker. You can also sit the fire cage with the briquettes over a gas ring.
I generally use this method when using heat beats for the
camp oven, due to the quantity used.
So now you are an "expert" on cooking with the Cobb and you will never ever get any rest again:-)
Good fun isn't it?
235471
Follow Up By: Member - Peter R (QLD) - Tuesday, Apr 24, 2007 at 07:16
Pour a little metho into a sardine tin and place under heat beads is a good way to get the beads going.
Pedro
496596
Reply By: Dasher_Syme - Tuesday, Apr 24, 2007 at 19:58
Hi all,
if you are in
Melbourne and out Preston way you can buy willow heat beads in the Preston Market for $5 - the real deal!! as opposed to $8-9 from woolies.
enjoy,
dasher
235607
Reply By: Member - Mal B - Tuesday, Apr 24, 2007 at 20:59
thanks guys only problum now that its getting hotter takes more cleaning mal b
235626
