Buying a GPS
Submitted: Monday, Apr 30, 2007 at 11:23
ThreadID: 44905 Views:2639 Replies:4 FollowUps:7
I am considering buying a GPS unit for my Patrol, and would like some advice on what are some good models that are available, as I am new to using GPS. I want to use it mainly when I go bush, for the smaller tracks, with the occasional use as a substitute Melways.
Reply By: Member - Troll 81 (QLD) - Monday, Apr 30, 2007 at 11:31
I have a mouse type GPS that plugs into my laptop that sits under the seat that is plugged into my touch screen. When you use it with oziexplorer you can't go wrong and a good map pack. I also have a Garmin handheld that I find great as a backup. Then I also have a voice guide turn by turn navman for city driving
Do a search on here you will find heaps of info
AnswerID: 236821
Reply By: Patrol22 - Monday, Apr 30, 2007 at 12:31
I haveone of thesewith a 2 gig card in it. Runs Windows PC, Oziexplorer and CoPilot. Runs like a dream and don't have too many cables handing about the cab.
AnswerID: 236832
Follow Up By: Member - Ron H (Int) - Monday, Apr 30, 2007 at 17:24
Hello Patrol22
Do you find the small screen big enough to give you any real detail or overview of your surounding area, I have always thought these may be too small.
regards
Ron
FollowupID: 497923
Follow Up By: Sand Man (SA) - Monday, Apr 30, 2007 at 17:53
Agree with Patrol22.
OziExplorer (and NATMAP Premium) for Country/Bush travel and CoPilot for voice/display map directions in the Metro areas.
I have been "trialling" CoPilot Live 6 for about a month or so and I am very impressed with it. It was the cheapest of the alternatives I researched but I read an unbiased review of it some time back, so bought it to try myself.
Not knocking the other products as I haven't tried them, but CoPilot 6 does the business it was designed for.
I haven't experimented a lot with OziExplorer on the PDA yet. I have been used to it running on a Laptop but SHMBO found it a bit intrusive, even mounted between us. Of couse, if I was doing some serious mapping, out comes the Laptop again.
The only "negative" I've discovered so far is that CoPilot uses a full display area and you cannot "Minimise it" to view other applications.
I get around this by starting OziExplorer first, then CoPilot if I need it in the metro area. After clearing the suburbs, I shut CoPilot down and Ozi has been tracking the Route "in the background" all the time.
Patrol22,
Does the Asus Mypal share the GPS input with both applications at the same time?
I use GPSgate on my PDA.
Bill
FollowupID: 497926
Follow Up By: Member - Rob S (NSW) - Monday, Apr 30, 2007 at 18:38
Hi Sand Man i have lates ASUS A639 much the same as the old 636.
And i cant run Destinator 6 and OZI ce at the same time.
Even been to the guys at GPSOZ said it wont work.
Rob
I only ever made one mistake
and that's when I thought I was wrong!
FollowupID: 497942
Follow Up By: Patrol22 - Monday, Apr 30, 2007 at 18:59
Yeah Ron the 3.5 inch screen is OK for me and shows enough of the map to orientate yourself fairly well. This is expecially so when using oziexplorer as this particular pocket pc can be switched from portriat to landscape mode and in conjunction with the touch screen buttons works very well.
CoPilot give you enough of the map as well as the voice guidance. To everyone their own but the ASUS MyPal works for me.
FollowupID: 497950
Follow Up By: Patrol22 - Monday, Apr 30, 2007 at 19:02
But like Rob S says you can't run ozi and the street maps together....this is not a problem with the computer but rather a software thing with CoPilot which doesn't allow access to the main computer menus....guess it's the same with destinator. The Garmin machine running ozi and garmin maps will allow this but it's quite a bit more expensive.
FollowupID: 497952
Follow Up By: Sand Man (SA) - Monday, Apr 30, 2007 at 19:12
Rob,
Noticed after a search that the ASUS A639 uses Windows Mobile 5 Operating System so GPSgate can be loaded on it. GPSgate is configured to match the input port with the physical port on the PDA then it sets up a virtual port for all applications to share, so you can run multiple applications and input the GPS signal to them concurrently.
franson.com/
Bill
FollowupID: 497954
Follow Up By: Member - Rob S (NSW) - Monday, Apr 30, 2007 at 21:14
Thanks Sand man i will give that a go.
FollowupID: 498015
Reply By: Kiwi Ray - Monday, Apr 30, 2007 at 15:57
Hi.
I use a Garmin 186, it sits on top of the dash and has a built in aerial so you need to mount as close to the screen as possible.
Mine is within 2 metres most of the time this may go out to 5 metres with poor reception.
It can loose the signal under heavy trees ( you can not see the sky ) but you only need to move a bit to get it back.
Ray
AnswerID: 236860
Reply By: Member - Doug T (W.A) - Saturday, May 12, 2007 at 11:42
Smithy-GUIV
Garmin Nuvi 300/310/ 660 depends on what your needs are, or the Garmin Quest,
www.ja-gps.com.au/garmin_nuvi660.aspx
www.ja-gps.com.au/garmin_quest_1.html
My website for GPS members.westnet.com.au/dtilley/maps.htm
AnswerID: 239516
