Truck Whisperer- What do they do??
Submitted: Thursday, May 17, 2007 at 09:52
Member - Nick (TAS)
Apparently this is top seceret but am trying to find out what they actually do.A mate had it done to his truck and 4wd and reacons it handles great.Another sceptic got it done , thought his truck drove great so pulled the whole steering system apart to see what had been done but could find nothing touched.
So is anyone willing to spill the beans??
Reply By: Notso - Thursday, May 17, 2007 at 10:05
Sounds like a good old fashioned motor mechanic to me.
My Brother in law was one and he could diagnose any problem just by listening and having a test drive.
Didn't need all the test gear. He worked for the RACV and the
young fellas called on him whenever they couldn't figure something out.
240506
Reply By: howie - Thursday, May 17, 2007 at 10:52
what happened to putting the end of a large screwdriver on the engine and the other end on your earhole.
now they just plug a diagnostic machine in and think it can tell them all the answers.
otherwise, rather than take it to your dealer to diagnose problems, just go round to the local pub about 6pm, open the bonnet, and the lads will be around it and have the problem solved in 5 minutes.
if they don't, you can always join them.
240509
Reply By: Member - Tony J (NSW) - Thursday, May 17, 2007 at 11:11
Got
mine done a few years back, for free as a demo. They reckon they could fix the problem of the front left tyre outer edge scrubbing.
Well, they didn't! Load of hoo-hah. I went right over the front end and not a bit of dirt or gunk disturbed of a bolt or nut anywhere. I do think they might have balance the front
wheels whilst on the hubs - that way everything is in balance but as soon as you rotate your
wheels or even change a flat the benefit is out the window. I think it is more a case of all in the mind with this whispering bullsh1t!
240511
Reply By: T-Ribby - Thursday, May 17, 2007 at 12:43
Only seems to work with Broncos.
You could try it yourself.
1. Start under the bonnet and snort gently into the top of the carby.
2. Run your hands seductively down each side of the bodywork at the same time talking in a gentle tone (note: not the usual talk eg "Stop again on me yer mongrel and you're on yer way to the knackers yard!").
3. Kiss the bonnet above the radiator while holding the
driving lights in each hand (if fitted).
4. Top up the oil, bit more pressure in the tyres, quiet rubdown with a chammy.
4. Starting with light weights, gradually increasing the luggage up on the roofrack.
5. Open the drivers door and caress the
seat - don't get in at this stage - it may frighten it.
6. Do No.5 for a couple of hours then slowly ease yourself onto the
seat and put on your seatbelt as fast as you can without spooking the beast.
7. If there is no violent reaction, start her up and sit quietly for a few minutes, while talking gently.
8. Engage drive and stay in 4L for a few rounds of the block.
9. After a few days of No.8 you should be able to move out of the paddock with confidence.
10. The side effect of this may be that the vehicle wants to follow you around everywhere - get used to it.
Terrence Ribbands
240521
Follow Up By: T-Ribby - Thursday, May 17, 2007 at 12:44
yes yer right - I can't bldy count
T.R.
501454
Follow Up By: Willem - Thursday, May 17, 2007 at 12:50
Number 9(10?)...After a few days of No.8, reverse for half a mile to get the gearbox to unwind....especially if the horse is called Yota.....lol
501456
Follow Up By: T-Ribby - Thursday, May 17, 2007 at 15:01
Get back out into the sand Willem ! you're just toying with us.
501478
Reply By: Member - Blue (VIC) - Thursday, May 17, 2007 at 13:57
His methods are a secret but his results are nothing short of amazing, from what I have seen...
The company I do casual work for had a T604 which was all over the place, KW were unable to find/fix the problem and the truck whisperer was called in. When finished it was the smoothest, best handling tug in the fleet...
I don't know what it cost or what he did but I'm pretty sure I'm lucky I wasn't footing the bill...lol
240537
Follow Up By: Crackles - Thursday, May 17, 2007 at 17:40
It costs about $500 for a 4by & $1000+ for a semi. Like everyone else have no idea what he does but often has brilliant results. Our work Isuzu had a minor improvement but not worth doing in my book. Concidering he only has the lighter type trucks for a couple of hours he can't be doing much, certainly not replacing any parts.
Cheers Craig.........
501503
Reply By: blue one - Thursday, May 17, 2007 at 20:33
Does it work on computers?
240619
Follow Up By: Sand Man (SA) - Friday, May 18, 2007 at 00:44
Nah,
You have to kick them, or if it's a laptop, bang down hard on the tabletop.
501603
Reply By: Member - Doug T (W.A) - Friday, May 18, 2007 at 13:24
SShhhhhh hush. they bend the friggin' axle so it suits Aussie Roads, good one for F250s
240752
