OziExplorer CE
Submitted: Monday, Jul 02, 2007 at 19:35
Member - Mick T (QLD)
Have recently purchased oziExplorer CD and CE upgrade. I have installed CE onto my HP RX5765 PDA, which has Sirfstar GPS receiver. i cant seem to get it to pick up a signal. Had a look in the book that came with the PDA..can't find the information to correctly configure the GPS for OziExplorer...Has anyone got one of these and if so could you help a tecnologically challenged person out...any help would be greatly appreciated....
Reply By: Doggy Tease - Monday, Jul 02, 2007 at 20:01
Does the PDA have abuilt in GPS ?
If it does,,,then the PDA needs to talk to it,,,,go into Ozi- FILE-configuration-NMEA(GPS),,,,,find the port that will let the streaming start,
Page comes up with three tabs.....Port Settings
Other
SIRF
Use the Port settings tab and simply scroll through each com port till the GPs start talking...:) Do each port, one at a time, till you get a location fix on your map.....
mine works on COM4.
AT least that is what i had to do with my Garmin i-que.....:)
I have not activated my sirf side of the GPS signal.
Hope this helps.
meow.
rick.
250376
Reply By: howie - Monday, Jul 02, 2007 at 20:10
ozie is only looking for the NMEA output from the gps.
is the port set in FILE-NMEA(GPS)=PORT SETTINGS ON THE PDA?
also, you might need to stop any other program that is using the NMEA data, which i assume is on the pda as
baud rate 4800?
250378
Reply By: Sand Man (SA) - Monday, Jul 02, 2007 at 20:11
Yes, Com4 is a common port for GPS input. You should be able to check the PDA to see which port its using.
Apart from this, check in OziExplorer under File - Configuration - GPS and make sure you select NMEA Only as the GPS type. Baud rate 4800.
If your PDA runs Windows Mobile you should have a GPS Info application you can select also.
250379
Reply By: Member - Mick T (QLD) - Monday, Jul 02, 2007 at 20:22
Thanks everyone...got it sorted now...had to use com port 7
thanks for the help
250383
Follow Up By: Skippy In The GU - Monday, Jul 02, 2007 at 23:51
My HX 4700 uses comport 8
511611
Follow Up By: Member - Toolman (VIC) - Tuesday, Jul 03, 2007 at 08:54
My HX4700 uses com port 6 - I use a Haicom HI305 III GPS
511628
Reply By: Member - aussichef (SA) - Tuesday, Jul 03, 2007 at 06:19
my hx 2750 uses com port 4
see u all in Warraweena
warren aka aussichef
250422
Follow Up By: obee - Tuesday, Jul 03, 2007 at 21:38
Mine cannot make it's mind up and uses different ports on different occaisions.
Owen
511747
