EF 1000iS or eu10i, which is quieter in midranges??
Submitted: Friday, Jul 06, 2007 at 04:11
ThreadID: 47441 Views:3079 Replies:3 FollowUps:3
which gen? YAMAHA EF 1000iS or Honda eu10i... does anyone have the experience of knowing whih is quieter under half-load??
i dont intend on working it but out so will aim for low demand but was mainly wondering whinc is quieter in the mid-range...
Reply By: Derek from Affordable Batteries & Radiators - Friday, Jul 06, 2007 at 08:20
Hi rbt
I would check the data sheets for the specs.
I heard the Honda uses an aluminum sleeve and they glaze up at low loads, I have not heard this complaint with the Yamaha.
Perhaps other will know.
I run the Honda eu2.0 and am very happy with it. It is now 5 years old and runs like new. I keep it in a generator box on my van.
Derek.
AnswerID: 251017
Follow Up By: Go-N-Grey (WA) - Friday, Jul 06, 2007 at 08:58
Got a picture of how you have set up the box and generator?
Can you run it in the box?
FollowupID: 512166
Follow Up By: Derek from Affordable Batteries & Radiators - Friday, Jul 06, 2007 at 10:17
I run it only for short periods in the box, (Boil the jug or use the microwave).
I have made an exhaust extension that allows the hot exhaust gas out the box. I only run the unit with the door open. Never closed.
FollowupID: 512181
Reply By: MEMBER - Darian (SA) - Friday, Jul 06, 2007 at 08:22
On their respecitive spec sheets, there is only a couple of db in it - who knows in reality - both are quiet - I use the Yam - quite happy with it.
AnswerID: 251018
Reply By: Sand Man (SA) - Friday, Jul 06, 2007 at 10:40
Ask the "Warraweena Warriors" to perform a definitive test.
Roachie has a Yammy. Just need someone else with a Honda.
They could run them at opposite ends of the camping area and see who gets the most abuse:-))
Bill
AnswerID: 251041
Follow Up By: Kev M (NSW) - Friday, Jul 06, 2007 at 10:54
I don't think using Roachies would be fair,
He has probably worked the motor over and it most likely has a higher output than the standard one LOL
Kev
Russell Coight:
FollowupID: 512188
