Compact 406MHz EPIRB's
Submitted: Wednesday, Jul 18, 2007 at 02:10
ThreadID: 47826 Views:4479 Replies:4 FollowUps:4
Hi troops,
Noticed in a promo for the Adelaide Boat Show on now, GME have recently released a compact (Personal) EPIRB using the new 406MHz frequency.
The MT410 Accusat PLB is available in two configurations:-
MT410 - Accuracy - 5km
MT410G - Accuracy - 45 metres (Built-in GPS unit)
Both models include a strobe light, protective carry pouch and retention strap, with a 7 year battery life and 7 year warranty.
The price for the standard (non GPS) model looks reasonable too. RRP is $449 but available from Witworth's Marine for $399. That is close to the current 121.5 Analogue units which will become defunct by February 2009.
Someone (Government?) was supposedly going to offer owners of an analogue unit some sort of rebate to upgrade to the digital 406MHz technology, but I haven't seen anything to this affect thus far.
I just may mosey along to the boat show and see what is offered in the way of "show specials".
Bill
Reply By: Member - Kiwi Kia - Wednesday, Jul 18, 2007 at 07:43
Hi Sand Man,
I have just had a look at the GME web site for the specs.
Wt. 250 gm
H. 135 mm
W. 71 mm
D. 38 mm
Now that really is a neat item.
I was rather disapointed to see that GME is still advertiseing the old 121 MHz model !
AnswerID: 253096
Follow Up By: Michael Carey - Wednesday, Jul 18, 2007 at 07:52
Remember that commercial aircraft will ALWAYS monitor 121.5 MHz, lots of commercial shipping/fishing vessels also have radio direction finders that will receive 121.5 MHz.
I'm not sure if any rescue agencies will be able to directly monitor or direction find your location if you set off a 406 MHz EPIRB, or have to rely on the satellite monitoring system alone.
If you set off a 121.5 MHz EPIRB in the middle of Australia after the satellite network is closed down, I'm sure there are enough commercial flights over Australia to raise the alarm.
Michael.
FollowupID: 514169
Follow Up By: Member - Kiwi Kia - Wednesday, Jul 18, 2007 at 08:52
Hi Michael, To be effective the EPIRB has to be heard and the 121.5 EPIRB has a VERY limited range. It will not be heard by a satellite so will need to be heard by a passing aircraft. As the busy airways are in direct line between the large cities and if you are not 'under' a busy airway it is unlikely that your beacon will picked up unless someone is actually already 'looking' for you. The beacons transmission will be heard in an area shaped like an inverted cone and the radius of the breadth of this cone will (under ideal conditions) only be around 200km at 25,000 feet. So, if an aircraft is listening on 121.5 MHZ (and not all aircraft do) and it is flying at 25,000 feet then you MIGHT be picked up at a range of 200 km. As most light aircraft will be below 10,000 feet then their track will have to be less then 100km from you to pick up your EPIRB signal. If an aircraft is monitoring 121.5 MHz and the squelch is turned down to reduce background noise then a strong signal may be required to burst through the noise limiter so I would not bet on your beacon being heard if the aircraft was more then 75 km away ! Australia is a big country so my advice is get a 406MHz beacon
Also, remember that non-gps EPIRB's require two passes of a satellite to fix the position of the EPIRB. The satellite system gives two possible positions on each pass, when the second pass positions are checked one will coincide with the first pass and that will be where the beacon is located. Yesterday there was an accidental epirb activation near Adelaide, the two possible positions on the first satellite pass indicated that the beacon could have been (a) near Adelaide and (b) close to the New Zealand coast line !
FollowupID: 514179
Reply By: Kiwi Ray - Wednesday, Jul 18, 2007 at 08:38
Hi Sandman.
I have one of the new 406 units on order, there seems to be a bit of a hold up getting them certified, they are supposed to be signed off this month.
i think this is going to be a better option for in truck use as it can be registered to a truck and land use.
The agent I was talking to is not sure how effective the gps feature will be in hilly and tree covered ares.
The 121 feature will still be used as a radoi direction findinf system.
Ray
AnswerID: 253106
Follow Up By: Member - Kiwi Kia - Wednesday, Jul 18, 2007 at 08:55
Hi Kiwi Ray,
All epirbs can be registered as land use if you want.
Also, the GME web site says that the COSPAS certification has now be granted.
FollowupID: 514181
Reply By: Member - Phil G (SA) - Wednesday, Jul 18, 2007 at 08:57
Speaking of Whitworths, they are having 15% off all floor stock this Friday and Saturday.
AnswerID: 253107
Reply By: Member - lyndon K (SA) - Wednesday, Jul 18, 2007 at 09:29
What is the cost of the 410G ?
Now is the only time you own
Decide now what you will,
Place faith not in tomorrow
AnswerID: 253113
Follow Up By: Sand Man (SA) - Thursday, Jul 19, 2007 at 00:05
Lyndon,
Again, from the Whitworth Marine site, the 410G (RRP) - $649...their price $589.
Bill
FollowupID: 514387
