What 12V Fluoro
Submitted: Friday, Jul 20, 2007 at 15:02
ThreadID: 47916 Views:4008 Replies:8 FollowUps:5
I know this has been discussed a bit before - but I've done a search and nothing is jumping out at me. So - mind if we discuss again.
I need a 12V fluoro to run from the car to the camp. There has been discussion about some being insect proof? Can anyone suggest a couple to look at that draw minimal power - and insect resistant would be good but not essential.
Reply By: Member - Craig D (SA) - Friday, Jul 20, 2007 at 15:05
Hi deserter, not really insect proof, but the best flouros I have found are the 13watt Narva jobbies - these units are really excellent and for such small power, do an admirable job in the lighting stakes.
Cheers.
AnswerID: 253549
Reply By: Member - Phil G (SA) - Friday, Jul 20, 2007 at 15:24
The way you mount it makes a big difference. Horizontal is much better than vertical, and the higher you can make it, the better.
The higher it is, the less likely that insects will bother you. Some people use a aluminium tent pole and have a simple jig to hold the fluoro horizontally on top.
All the good fluoros draw about 1amp, which is bugger all for camping.
If you're after a really cheap one, the $16 Jaycar fluoro throws out plenty of light, but the quality is borderline at best - the plugs usually need resoldering, and they are not waterproof.
Like Craig, I use the surface mounted Narva 13watt on my canopy, which is great value at just over $30 and throws out plenty of light. I think Derek on this site sells them, and you can also get them from most places that stock Narva.
AnswerID: 253550
Follow Up By: Mike Harding - Saturday, Jul 21, 2007 at 08:04
Hi Phil
My understanding, also, is that what you say above is correct - but I don't know why, do you?
Only thing I could think of was the earth's magnetic poles having an equal influence on the electrodes when it's horizontal but for all I know it might be because electrons (or holes? :) don't move uphill very well? :)
Mike Harding
FollowupID: 514721
Reply By: baza - Friday, Jul 20, 2007 at 15:33
I've been tinkering with these, $7.50, you need to solder 2 wires and a small capacitor. They have the European style screw in connector, not bayonet. Site Link
AnswerID: 253552
Follow Up By: Member - Crazy Dog (QLD) - Friday, Jul 20, 2007 at 16:35
There is also the NELSON brand - same thing but bayonet fitting. Nothing else to do to them (I mean ya don't have to do any work on em..) but at around $27 a go these ones with the ES base sound good.
What have you found with this brand BAZA?
I currently use the Nelson and have found them to be good.
Grrr!!!
FollowupID: 514613
Follow Up By: baza - Friday, Jul 20, 2007 at 21:32
They seem to give a similar light to the 240 volt Philips ones I'm slowly rolling out through the house. I've only tested them in the shed, they haven't seen any 'real' action yet. Need to find some cheap surrounds for them to focus the light a bit I think. I picked 4 up when I was buying something else off Oatley, they all work fine, but you do need a soldering iron with a small tip to complete them.
FollowupID: 514690
Follow Up By: Mainey (WA) - Sunday, Jul 22, 2007 at 02:41
I use the Nelson 12v (equivelent to 60Wt) screw in globes direct wired to the battery via a low voltage plug, also the similar shaped 240v Nelson screw in globes running off the Inverter, both lights are good as gold.
Are in "natural" light colour and not a hassle with bugs.
FollowupID: 514852
Reply By: Member - Doug T (W.A) - Friday, Jul 20, 2007 at 15:38
Why not go LED, uses less power , but if you do want Fluro then the 12 Volt Shop has some good gear.$79.99 and they internet sales
http://www.12volt.com.au/General%20Htmls/webcat2003/lights.html#handheld
www.12volt.com.au/
AnswerID: 253555
Follow Up By: Andrew Main - Saturday, Jul 21, 2007 at 12:19
LEDs don't draw less power against light output.
FollowupID: 514762
Reply By: Sand Man (SA) - Friday, Jul 20, 2007 at 15:43
The Versalite and the Piranha 12 volt 11 watt fluros are the same unit marketed under different brand names. They are specified as being equivalent to a 75 watt incandescent globe and draw about one amp so are very efficient.
The Versalite is available as most reputable camping stores.
The Piranha is available from TJM outlets.
Versalite also market a great little bracket to attach the fluro to a tent, or annex pole.
Some people place a piece of yellow cellophane over the lamp which reduces the attraction of insects, but it also reduces the amount of light being emitted.
My solution is to place the Piranha fluro at one end of the camper annex (or anywhere else I need adequate light) and I also have a long LED lamp which I use at the food preparation end.
The LED lamp is not as bright as the Piranha, but doesn't attract insects anywhere near as much.
Kind of like "horses for courses".
Bill
AnswerID: 253556
Reply By: Barry 2 - Friday, Jul 20, 2007 at 16:33
Hi Deserter, We use 2 x Piranha lights, one for light around the camp it has extended lead the other has orange celaphane wrapt around it and is great for keeping bugs at bay we use this one when cooking so we don't end up with too much "Protein" in our meal.
Works for us !!!
Safe 4x4'n
Barry
AnswerID: 253570
Reply By: wyrss - Friday, Jul 20, 2007 at 17:29
Do yourself a fovor and go to Supercheap Auto and buy a 60LED worklamp.
They are great lights and draw very little power.
Steve
AnswerID: 253579
Reply By: 93 Navara - Saturday, Jul 21, 2007 at 02:14
They all draw about the same, as long as they're 11 to 13 watt=1amp give or take. Sure the ARB and Pirahna will probably last a bit longer but so they should for 6 times the price. I've got 2 of supercheaps, cheapest best and they haven't faltered yet. Each to their own.
Ben
AnswerID: 253658
