Change ring time on Next G phones
Submitted: Monday, Jul 23, 2007 at 10:31
Russel & Mary
Hi guys,
It seems that the factory default setting is for 15 seconds, so by the time you register that your phone is ringing and then find it and answer it, often it's too late and you've either missed the call or it's gone to message bank(which then costs you $ to retrieve!). So, to extend the ring time before diverting to message bank, here's what you do.
on your phone..type **61*101**25#
then.... send
The screen should show something like..."requesting"
then hit OK
Done.
If you have vodaphone, type 333 instead of 101, or for optus, type 321 instead of 101.(I only have a Telstra phone so I THINK these are correct)
The 25 is the number of seconds you now have of ringing and can be changed in increments of 5 seconds up to 30, but I have heard that if you set it for maximum of 30 seconds, after six months it will revert back to 15. Then you'll have to try to remember how you did it six months ago. Rus.
p.s. as usual someone will say this is not correct but it works for me.
Reply By: Russel & Mary - Monday, Jul 23, 2007 at 10:49
By the way, over the last couple of weeks we did a 6 vehicle trip from south of
Adelaide to
Innamincka, to
the Dig Tree, back home via Menindie. Next G coverage was excellent at
Lyndhurst,
Tibooburra and
White Cliffs. Get out of these towns a few k's and you lost it. SA Draught beer 30 can pack at
Innamincka $40. BUT, a slab of bundy and cola cans...$92!!!!!!. All those type of cans were the same price. Rus.
253992
Reply By: Member - Doug T (W.A) - Monday, Jul 23, 2007 at 11:05
Mine is already on 25s
253995
Reply By: Member - Uncle (NSW) - Monday, Jul 23, 2007 at 11:11
Thanks for the info Russ, just changed ours after a few frustrating months.Cheers.
253996
Reply By: GeorgieGirl - Monday, Jul 23, 2007 at 14:41
Russel & Mary
I would like to say that this
forum is full of very useful and interesting information.
Thank you very much, I've put up with the short ringing on my nokia phone for years and years.
Will keep this info as I'm about to purchase a new 3G phone in a week or two just before our big trip.
At least I will have a chance to get to the phone before going to message bank.
GeorgieGirl
254030
Follow Up By: Member - Mike DID - Monday, Jul 23, 2007 at 21:58
A 3G phone won't be much use to you in remote areas.
Only NextG has extensive remote area coverage.
515204
Follow Up By: Member - Au-2 - Tuesday, Jul 24, 2007 at 00:10
If you get an LGTU500 Georgiegirl, you will be able to use the notepad feature to copy the above code to give to friends or to repeat the procedure if necessary.
OzeSheila.
515227
Reply By: Member - Davoe (Nullagine) - Monday, Jul 23, 2007 at 15:50
totally sweeeeeeet just done it. It has crapped me for ages. My missus had hers changed by ringing telstra and I always meant to but never got around to it
254039
Reply By: gonebush SA - Monday, Jul 23, 2007 at 17:57
hi, I've had the same problem even before i went to Next G and what i did was to ring Telstra and get them to extend my ring time and all goes
well, i must admit a couple of times after it's been going fine then all of a sudden it will go back to being shorter ring times, so back on the phone i go, this however hasn't happened with the new phone 'yet'.
just think of all the extra money poor old telstra gets when this happens to a lot of phones.
254071
Reply By: Banjo (WA) - Monday, Jul 23, 2007 at 19:50
Russel & Mary
Thank you, the short ring time has been a bugger.
Banjo (WA)
254106
Reply By: Members-Neil & Margie-Cairns - Monday, Jul 23, 2007 at 20:04
Thanks Russel & Mary , been trying to remember to ring telstra for ages to do that ,, all done now , worked
well ,, thanks again ,,
Neil !!
254109
Reply By: Patrolman Pat - Monday, Jul 23, 2007 at 20:53
Thanks for that, worked for me.
254123
Reply By: Ianw - Monday, Jul 23, 2007 at 21:58
Didn't work on my new NxG phone!! Says number not connected, check no and dial again. Done it several times, no go!!
ian
254141
Follow Up By: Russel & Mary - Monday, Jul 23, 2007 at 22:32
make sure you are entering the correct * and # symbles. Are you Telstra? Rus.
515210
Follow Up By: Ianw - Monday, Jul 23, 2007 at 22:39
All double checked, will not work. Maybe I havent set up my messagebank properly yet
Ian
515213
Follow Up By: Russel & Mary - Monday, Jul 23, 2007 at 22:43
I don't know either. I'm going to have a glass of port and go to bed, bye now. Rus.
515215
Reply By: Member - Ray Mc (WA) - Monday, Jul 23, 2007 at 23:23
As most Next G phones are fairly new, take it back to the retailer. They will contact the carrier (Telstra in my case) and the change will take place.
Makes it easier than trying to remember any configuration of numbers and symbols.
I also think that it's nice to have Telstra do something else for their (my) $$.
Ray Mc
254161
