12 v portable compressors
Submitted: Monday, Jul 23, 2007 at 14:42
ThreadID: 48012 Views:2314 Replies:11 FollowUps:3
Would like to know how Big Red, Max Air and ARB compressors rate with anyone as I'm wanting to buy. Did a search but not alot on Big Reds apart from the fact they seem to be dearer than the others. Anyone have any advise
Cheers Dave
Reply By: Time - Monday, Jul 23, 2007 at 14:49
I have an ARB one (had no experience with the other brands), have had it 5 years and no problems, never cut out from overheating, never let me down. I have it installed behind my back seat (Dual Cab Hilux) out of the mud and crud that they would get if under the bonnet. Would I buy one again, yes.
AnswerID: 254031
Reply By: Redback - Monday, Jul 23, 2007 at 14:51
I have an ARB compressor and a mate has a Big Red, in the time it took me to pump one tyre from 24psi to 40psi he pumped all 4 of his tyres to 40psi.
I know what my next compressor will be!!!!!
Can't comment on the other one never seen one in action.
Baz.
AnswerID: 254032
Follow Up By: itsdave - Monday, Jul 23, 2007 at 16:02
Might be worthwhile spending the extra $$ on a Big Red if thats the case.
cheers Dave
FollowupID: 515105
Follow Up By: Dave(NSW) - Monday, Jul 23, 2007 at 16:44
I have a Big Red it pumps up 3 tyres then cuts out on over heat, it now sits at home on shelf and I use an Endless Air which pumps up 6 tyres the same time a mates ARB pumps up 2.
Dave....
GU RULES!!
FollowupID: 515110
Reply By: Scoof - Monday, Jul 23, 2007 at 15:30
I have a Max Air it's been great no prob's, only had a 4wd systems heap of rubbish before that.No experience with the other brands.
Cheers Scoof. :-)
AnswerID: 254036
Reply By: Footloose - Monday, Jul 23, 2007 at 16:05
Have had a Big Red for 5 years. It does what I need, and hasn't given me any dramas.
AnswerID: 254044
Reply By: playdoe27 - Monday, Jul 23, 2007 at 17:11
i bot a max air II this year, and it seems okay to me. the big test is next year
AnswerID: 254060
Reply By: TD100 - Monday, Jul 23, 2007 at 17:35
my arb compressor has been rebuilt 3 times under warranty,at last repair i was told not to use it to pump up tyres! WTF! i thought that is what it was designed for?so no prizes for which one i would suggest! cheers Paul
AnswerID: 254068
Follow Up By: itsdave - Monday, Jul 23, 2007 at 17:47
ARB told me today that they have a new one just released within the last few weeks. I guess the reliability has not been proven as yet.
Am swaying between the Big Red & Bushrangers Max Air at the moment
cheers Dave
FollowupID: 515122
Reply By: mattie - Monday, Jul 23, 2007 at 18:32
Hi Dave
i have a Big Red i don't use it all the time but have used it a fair bit and have had no trouble at all. I have pumped up 8 tyres one after the other in about 30 degrees maybe a bit hotter i know this isn't hot but it never cut out and all 8 tyres were pumped up to 45psi, 4x4 Australia mag did a test on all the popular compressors a couple of years ago and it was one of the better compressors once under pressure(litres per min), BUT if u want the best the endless air can not be equaled if u have the room under the bonnet.
MATTIE
AnswerID: 254081
Reply By: Sand Man (SA) - Monday, Jul 23, 2007 at 18:38
Dave,
I have a slightly different perspective on Big Red.
I selected it because it was available as a "portable" unit.
Came in its own case with everything held inside. (was also a good price at a 4WD show at the time)
I liked the portability as you can take it to other vehicles.
Performance wise, I have no complaints. Don't know if it pumps up tyres quicker, or slower, than other brands and I don't care.
It has never cut out due to overheating, but then again, I don't use it every day and it doesn't sit in the engine bay where it could be heat affected from an "external" source.
Bill
AnswerID: 254083
Reply By: Markymark - Monday, Jul 23, 2007 at 20:17
I have the Bushranger Max Air and have no problems with it. RRP is $390, bought it at last years 4x4 Show in Melbourne for $275! They have since released a series 2 with minor mods. It's been used a fair bit but the hardest I've asked of it is to blow 2 vehicles from 18-20 psi back up to 30+, too easy. I think they're rated to do 5 odd vehicles before the thermal cut-out kicks in. 5 year warranty too.
The ARB was designed for engaging diff-locks, not blowing up tyres and they are finally admitting that.
Other than some the twin-head designs (and the Max Air), the Big Red has been the hardest pumping 12v compressor for years but they cost a small fortune. I would imagine you'd only ever have to buy one though.
Mark.
AnswerID: 254113
Reply By: just*Managing - Monday, Jul 23, 2007 at 21:27
Try & get a copy of last months Western 4 Whel Driver. They did a full comparo on about a dozen of the most popular compressors including the ones you speak of.
AnswerID: 254132
Reply By: Member - Barnesy (SA) - Tuesday, Jul 24, 2007 at 00:58
I have mounted my ARB under the bonet and it pumps my tyres from 20 to 40 psi without any problems at all. Has done so for several years now.I don't really care if one is 10% faster than the other or whatever. It's a good chance to inspect the tyres for possible damage sustained driving whilst deflated.
AnswerID: 254170
