Dune Flags
Submitted: Thursday, Jul 26, 2007 at 00:57
ThreadID: 48109 Views:2375 Replies:9 FollowUps:7
Anyone have any info on making your own dune flag ? Its to go on a Patrol with bull bar.
Reply By: Member - Doug T (W.A) - Thursday, Jul 26, 2007 at 01:25
Yeh ...just go into Kmart , flop $4.00 on the counter and ask for a meter of the cheapest red rag on the floor , take it home , cut it into required sized squares, poke 2 holes in it and zip tie it to the antenna, how hard is that, and it's very cheap
www.doug-and-dusty.id.au/desert/desert.htm
AnswerID: 254491
Follow Up By: marq - Thursday, Jul 26, 2007 at 07:19
I paid $2 for a red tea towel at crazy's (discount store) and used a broom handle.
Worked well. Just do not install until you hit the dunes and remove after the last dune.
Cable tied the lot to the roof rack.
FollowupID: 515559
Follow Up By: Member - Doug T (W.A) - Thursday, Jul 26, 2007 at 10:04
marq
Thats what I call using your noggin', good one,
FollowupID: 515577
Reply By: madcow - Thursday, Jul 26, 2007 at 08:31
Have a look around next time you come across some roadworks. Or try your local used caryard they generally have heaps of them :).
Seriously though we bought one for 5 bucks from one the 4wd mags that was on display at a 4wd show.
AnswerID: 254505
Reply By: Member - Willie , Epping .Syd. - Thursday, Jul 26, 2007 at 08:37
Mr Tee ,
I cable tied a small piece of pipe behind an upright on my bullbar . Into this goes a 7' Ugly Stik rod blank ( butt taped for tight fit ) onto which I bound two small guides to tie the flag on .
I bought an excellent red flag on EBay for $10.
I saw a guy wipe out one on a tree at Durba Springs that had to have been 20 ' long - what a classic .
Cheers ,
Willie
AnswerID: 254507
Reply By: Nick R (VIC) - Thursday, Jul 26, 2007 at 09:07
For the pole i used a "wog pole" from a fishing shop, either 5 or 6 metre I think then i found around home a red flag.
NickR
Carpe Cerevisi
AnswerID: 254512
Follow Up By: Scoof - Thursday, Jul 26, 2007 at 09:57
There is 18 flags at every golf course. Ha Ha .
FollowupID: 515575
Reply By: Member - Roachie (SA) - Thursday, Jul 26, 2007 at 11:41
I have an old heavy-duty spring base from a UHF antenna (the actual antenna has long-ago been smashed on a tree). I found that the inside diameter of this is just spot-on to take a tent pole. I then found that a bit of old conduit (thin metal) used for cheap curtain fitted inside the tent pole. Cable tied a piece of red rag I found beside the road (you see a lot of them here in SA......people seem to leave them where the side of the road is a bit "rough" (hahahaha)).
I can fit and remove the flag in about 10 seconds and the spring base (unlike the rigid ones attached to bullbars or roof racks with bolts or 100m/h tape, has a bit of give in it, so you won't damage the flag quite so easily on overhanging trees etc.
AnswerID: 254526
Follow Up By: Nick R (VIC) - Thursday, Jul 26, 2007 at 19:54
Ahhh roachie, I lost one of those, you didn't find it at Beachport did you?
Carpe Cerevisi
FollowupID: 515683
Follow Up By: Member - Roachie (SA) - Thursday, Jul 26, 2007 at 20:02
What did you lose mate? The tent pole?....the bit of curtain rod?....the red flag?....... or the spring base?.......hahahaha
Anyway, I ain't never bin to bitchport, so carnt hep'ya, sorrrie mate.....;-))
FollowupID: 515685
Follow Up By: Nick R (VIC) - Thursday, Jul 26, 2007 at 20:10
I lost a flag over there, should have known better "securing" it with a zip tie from supercarp auto....
the 3 tent poles I lost on Fraser Island...
nick
Carpe Cerevisi
FollowupID: 515688
Follow Up By: blue one - Thursday, Jul 26, 2007 at 20:36
Use the Missus red undies. Gets their attention every time.
FollowupID: 515698
Reply By: selasticman - Thursday, Jul 26, 2007 at 12:28
Hi GeeTee,
Ask a plumber mate if he has one of those flags you get from Reece or Tradelink plumbing supplies etc... Then a length of electrical conduit off the bullbar and away you go!
cheers,
selasticman
AnswerID: 254529
Reply By: Member - Matt & Julie (VIC) - Thursday, Jul 26, 2007 at 17:48
I went to a bike shop I got a flag flexible pole and a bracket $13 mounted it on my roof rack the flag stands at just over 3mt from the ground
Matt & Julie
AnswerID: 254567
Reply By: TD100 - Thursday, Jul 26, 2007 at 18:07
i bought a pushbike flag for 10 bucks and taped it to my uhf antenna and it worked fine was approx 3.5m off the ground.cheers Paul
AnswerID: 254573
Reply By: Sand Man (SA) - Thursday, Jul 26, 2007 at 21:31
You're all a bunch of cheapskates, na na na na na na!!!
I bought my purpose designed and built solid fiberglass Flagpole several years ago from hmm, Opposite Lock I think. bolts through the Bull Bar mount.
Only cost me $90 or so and I have used it oh, at least half a dozen times.
That equates to $15 a tour:-)))
Still looks "brand new" but!
Bill
AnswerID: 254608
