Rear draws/shelves - what do youu carry?
Submitted: Wednesday, Aug 15, 2007 at 15:29
Member - Pixie
Hello readers
I am planning a trip sometime next year and am slowly working through a number of small projects to get me ready.
My current project is a set of rear draws/shelves. And whilst I have no drama assembling a system I am not sure what the best design should ultimately cater for (I don't want to have to do this twice).
Having never had the luxury of a system like this (everything is usually stacked on top of each other to the roof!!) I am wondering if some seasoned travelers could share how they have set up their own vehicles and what would be worth keeping in mind.
What is the sort of stuff that ends up being carried in this part of the vehicle rather than in the trailer/van? Electrical equipment? Valuables? bedding? Tea and coffee? Recovery gear? Should there be lots of little compartments or only bigger ones?
Thoughts on this?
Also, I intend to have a 40 litre Engel fridge on a slide so would appreciate any advice on the clearances I should keep around it for ventilation.
Reply By: Kev M (NSW) - Wednesday, Aug 15, 2007 at 15:31
What vehicle do you have, it may help with some designs
Kev
| Russell Coight:
257365
Follow Up By: Member - Pixie - Wednesday, Aug 15, 2007 at 15:46
Kev M it is a GQ Patrol
This article is really good but the author already knows what he wants to put in the back.
I know it is an "open question" and the obvious answer is "put whatever you want in the back!!" but like many things to do with
camping, first ideas are not always the best - thus I have asked the question to get some ideas on what other people have settled for.
518621
Follow Up By: Kev M (NSW) - Wednesday, Aug 15, 2007 at 16:20
Like what is in that article, have the fridge mounted low for ease of access, for the space that is left behind it which is a PITA to get to have your
water supply. As for clearances around the fridge I think at least an inch on the sides and about 2 inches at the back should be enough.
You can also get
water tanks to fit in the space between the storage system and the rear seats that way you make best use of an otherwise empty space.
The use of storage tubs is a personal thing if you intend to use them check the space available as
well as what you want to carry in them. Have them on seperate shelves to avoid having to remove all of them to get to the bottom one.
I personally think that an easily removable storage system is best as you can remove it easily when not required.
Good luck and happy building
Cheers Kev
| Russell Coight:
518626
Follow Up By: pepper2 - Wednesday, Aug 15, 2007 at 17:06
My personal viev is that the drawers in most are too shallow i had
mine made with drawers 27cm deep,allows milk cartons,plates,gas bottle and many other items to stand upright much more convenient and efficient storage........but each person has their own ideas all the best with yours.
518635
Follow Up By: pepper2 - Wednesday, Aug 15, 2007 at 17:18
Sorry forgot to add have two drawers as normal each has four equal compartments with removable plywood partitions,in the left side drawer i carry tools,spare parts,fishing gear,air jack,filters,bbq plate,gas bottle,billy, etc ....in right side first compartment has cuttlery,plates,thermos,3 thermo cups,plastic glasses,bbq tongs,egg slice,carving knives.....2nd compartment tinned and packet food,3rd compartment more food, eggs sauces,herbs,spices....4th compartment filled with extensive
first aid set up.
each comparthent holds a similar volume to a normal esky.
you need compartments to stop things sliding around when the compartments are only part filled.
518640
Follow Up By: pepper2 - Wednesday, Aug 15, 2007 at 17:21
For short trips the fridge sits on lhs on top of drawers,for longer trips i remove the rear passengers
seat and strap the fridge to the floor...makes for easy access.
518641
Follow Up By: Richard W (NSW) - Wednesday, Aug 15, 2007 at 18:09
Be wary of qubelock/connect it. I built a system based on the Patrol model above and the plastic joints kept breaking. The reason was mostly likely because I left gaps in the structure to access the sides and rear of the vehicle without any reinforcement.
It probably would have been OK if the framework was fully enclosed with ply.
518646
Follow Up By: Brew34.5(SA) - Wednesday, Aug 15, 2007 at 20:25
Richard that must be the case as
mine has never suffered any problems. I had one join that popped out once and a pop rivet has stopped it happening again.
518681
Reply By: Des Lexic - Wednesday, Aug 15, 2007 at 17:19
I agree with the suggestion to keep the fridge as low as you can. Makes it easier for short assed women to access it and not disturb your drinking time.
2nd Suggestion is to make one of the drawers at least 250mm deep because packets and bottles can then be stored standing up without spillling the contents everywhere.
My set up is bottom two drawers for cooking and tucker, top drawer for spares and junk. Clothes are kept in plastic tubs and so are the tools, spares and recovery gear.
water is kept in 10 litre containers because they are lighter for the missus to carry than the 20 litre types. I know I'm very considerate for SWMBO so you don't need to acknowledge me for it. LOL
257380
Reply By: Brew34.5(SA) - Wednesday, Aug 15, 2007 at 18:09
I made my set up based on the link you posted. Very light and easy to install and uninstall. Only you know what yours will need. Keep the fridge low as mentioned.
257390
Reply By: Member - John and Val W (ACT) - Wednesday, Aug 15, 2007 at 18:30
Pixie,
I built my own from timber/mdf/chipboard, and minimal steel . We sleep in the back of the Troopy, so the whole area is required for a bed at about half height. Under that the wheel arches are boxed for 2/3 of the length of cargo space to provide storage for stuff that is rarely used and provide lateral support for the 2 drawers which also run for 2/3 of the length of the cargo space. One is wide enough for the Waeco fridge (the fridge also determines the height of the bed platform), and this leaves a width of a bit over 600 mm for the second drawer. That dimension is important because 600mm is a nice standard imperial size and a lot of gear is made to this size. (We have a barbecue which folds into 600mm, 600mm plastic
bins... lots of gear fits in "a bit over 600mm" that won't fit in 600mm.)
Why 2/3? The front third is accessible from behind the seats (we only have two front seats, all other seating removed.)
Since we don't drag a trailer, everything has to go in Troopy yet be accessible as required. The general rule then is that stuff you need freqently or in an emergency is stored at the very back just inside the back door, stuff you need rarely can be buried deep. There's a picture of our rear setup in our rig photos here. The "kitchen", and the table and chairs will be used several times a day so occupy prime real estate immediately inside the rear door. Behind that is space for stove, thermos, and the stuff you'll only need once a day. Deeper still are 2 plastic
bins holding canned food, tools and other stuff you'll probably access once a week or more.
The fridge in the smaller drawer also has pride of place. Buried behind it is recovery gear, compressor etc and behind that is bulk
water ( day-to-day
water is stored within easy reach on one of the wheel
well boxes.)
Just how you proceed will depend on you own requirements, but I suggest that you keep in mind the old imperial modular sizes (600mm) and allocate the most accessible space to stuff you'll need frequently or quickly. Also, if our experience is typical, be prepared to go back to the drawing board pretty often!
HTH
| J and V
- Albert Einstein
257396
Reply By: Member - Willie , Epping .Syd. - Wednesday, Aug 15, 2007 at 18:31
Mrs / Mr Pixie ,
I have two drawers ( one on top of the other ) next to my 73 litre fridge . On top of the drawers and fridge I have a flat shelf .
In the bottom drawer I carry all the bottles of sauce , jars of everything and food .
In the top drawer I carry all my cutlery , plates etc and saucepan , billy , frypan , garbo bags , detergent stuff ,tongs and spatula .
On the shelf I put clothing bags etc .
Cheers ,
Willie .
257397
Reply By: Member - Tim - Stratford (VIC) - Wednesday, Aug 15, 2007 at 18:44
G'day Pixie,
I lashed out and bought the 'Outback' drawers with fridge slide. Like others have said - the lower the fridge the better - especially for a taller fridge like the engel 40. My drawers have the fridge on top and can be a pain - it also limits a fridge extension like kool zone etc.
In my drawers I have all cooking equipment and some food (sometimes all food) in one drawer and recovery equipment and
tools in the other. Recovery equipment weighs a fair bit so keeping it in drawers is a great idea IMHO.
Try getting all your camping/touring equipment out on the driveway and packing it as if in drawers - may get a better idea of size and what can fit - you'd be surprised how much gear you can fit in drawers!
257401
Reply By: Member - Alex K (NSW) - Wednesday, Aug 15, 2007 at 18:56
Hi Pixie,
You say "I personally think that an easily removable storage system is best as you can remove it easily when not required". Unless you really have too (too many kids). I think you would never want to remove the draws. Yes you might save 100kg of weight but you never really know when you'll need them. I use
mine on weekend trips and week long trips.
Just a thought.
Alex
257406
Follow Up By: Member - Pixie - Wednesday, Aug 15, 2007 at 19:40
ah yeah Kev M said that but I'll need to use the back for the extra seats when not
camping anyway
518674
Follow Up By: Kev M (NSW) - Wednesday, Aug 15, 2007 at 19:43
Alex,
That was actually my thoughts not Pixie's. and as I said it was for a storage system not a drawer system. If you have a system like Richards then to have it removable would be advantageous as it would free up some space for the times when you need it i.e. when at home and not travelling.
Cheers Kev
| Russell Coight:
518676
Reply By: Member - Pixie - Wednesday, Aug 15, 2007 at 19:49
Thanks for the replies so far
Some very handy tips in there which could become all too obvious AFTER the fact
It's interesting to see how people travel so differently. With children, I suspect it will be a while before I can fit a
camping trip all back into the vehicle alone.
257422
Reply By: Member - Duncan W (WA) - Wednesday, Aug 15, 2007 at 21:31
For what it's worth my mods can be viewed
The various mods I've done, including the drawers and how they fit around the duel battery set-up and fridge. Not a Patrol but you get the idea. Drawers are deep so stuff can stand up.
257447
Reply By: Sand Man (SA) - Wednesday, Aug 15, 2007 at 21:39
Pixie,
I have a commercial Drawer system in the back of the Jack.
Two drawers side by side with a built-in fridge slide on the left side.
I stack whatever is required/fits on and around the top surface of the drawers.
The right hand drawer contains all the safety & recovery equipment and is accessible at all times without unloading anything.
The left hand draw is a "utility" draw containing things like
first aid kit, torch & 12 volt light and usually some bottles of red stored in a strong cardbord box which stops them rattling.
My Bride doesn't worry about the height of the drawer. She just makes me access the fridge for her Jack Daniels or Chardonnay.
257448
Reply By: Crackles - Wednesday, Aug 15, 2007 at 21:46
Gaday Pixe. For ease of installation/removal the storage system should be no wider than
the gap between the wheel arches. By utilizing the tie down rings & mounting brackets for the 3rd row seats you can hold the box in place securely and still remove it easily in 15 minutes. (many unit's are bolted in permanently)
The simplist & lightest system can be made of RHS steel tube with weldmesh fitted on the sides for fridge ventilation. 12mm marine ply on top trimmed with carpet will be strong enough to store almost any weight. Mounting the fridge to the bottom will allow easy access inside & 2 draws (1 above the other) can be mounted beside. I use the top draw for food, drink, cleaning items, thermos & eating utensils. It's an easy draw to access so everything required to make lunch is in there along with the 1st aid kit. Bottom draw has all the heavy gear, tools recovery, billies, spares, lights, pegs etc.
Beween the box & the rear seats is a small cavity large enough to fit 3 x 20L jerry's. They can be accessed by simply folding the back
seat forward. I have a small 12 Volt pump with a hose running out the back for convienient
water at the rear of the car.
A 1/2 cargo barrier extends from the storage system to the roof secured utilizing the screws for the rear handholds.
Down the sides of the storage on either side sleeping mats & bags along with pillows, coats & shoes can be squeezed in. By not building the boxing system too high there is sufficient space to fit plastic storage crates up on top along with a full sized Minute type tent.
Aluminium makes the best draws trimmed with marine carpet & pinchmould. 100 kg sliders will hold the fridge & bottom draw while the lighter one up top would only need to be 50kg.
Be very aware of keeping the weight down minimising materials to the size they need to be. Many of the commercial ones are far too heavy making them difficult to remove & far too heavy to be carting around for the life of the car. Chip board & MDF to a lesser degree disintergrates over time on the rough corrugations so stick with the dearer but lighter marine ply.
Pull all your
camping gear out & measure it up to ensure they fit the size of your draws. I'm a big fan of building a pattern first to see if it all fits. Heavy cardboard taped together will give you an idea of what it will look like before you start cutting & bending the expensive materials.
Cheers Craig.................
257449
Reply By: Dave B (NSW) - Thursday, Aug 16, 2007 at 14:42
I am going through the same process Pixie.
In my case I have a new CT, so the kitchen and some small storage is in the CT.
I have made a fridge slide for a 60 Evakool on one side of the drawer system at the moment.
Next to that I plan to have a compartment only a few inches high so that I can slide a BBQ plate and frame in there. Keep as much of the heavy stuff down as low as possible.
On top of the BBQ plate area, I plan to put a drawer slide the will hold various spares and recovery equipment and also the
camp oven.
Then I will see how much room I have to play with for a 2nd drawer slide on top of that. The more space you have, the more you want to take because you have room. Not always a good idea.
On top of the whole frame, I will have a bifold 6 ft table. That is only a few inches high and the folded table is about the same size as the frame for the drawer system. I figure it will be very easy to get the table in and out if we need it.
I would like to keep it all at a height that I can still see out the back window.
That's the basic plan, but I also have quite a lot of space in the CT.
I just wanted to put some of the heavier stuff down low in the car and not having it going walkabout in the car in an emergency stop or on rough roads.
257513
Reply By: geocacher (djcache) - Thursday, Aug 16, 2007 at 23:44
Pixie,
The plans for my drawers can be downloaded from my website at
Dave's 4wd Project Page.
I solved the fridge height problem by tilting it as it slides out.
That way I could still maximise my space by storing all the recovery gear below it. Space above the fridge is often wasted in many storage systems.
There are also good pics of my setup in the article on my ute in January's 4wd Monthly from earlier this year.
Many others have built my drawers now and I haven't had any complaints.
257598
