What PDA
Submitted: Wednesday, Oct 10, 2007 at 19:16
ThreadID: 50429 Views:4094 Replies:7 FollowUps:33
I am looking to set up ozi explorer moveing maps etc .What PDA are good for this as Navman PIN 570 no longer available and Garmin now only do a unit with their own maps.I feel a laptop is too bulky to mount or have on lap.Whats best.
Reply By: mike w (WA) - Wednesday, Oct 10, 2007 at 19:26
There is plenty of info to sift through here:
http://www.gpsaustralia.net/forums/forumdisplay.php?f=38
I myself have a HP that I picked up off of ebay, a haicom GPS with oziexp and tom tom. Just about any current PDA would do the trick, however blue tooth would be adventitious as it means that you can have wireless communication (I know its really called bluetooth) between GPS and PDA.
My system Works well, however my only recomendation would be to make sure that there is plenty of memory and and the provision for a decent memory card. Mine can only take a 1gb card, which limits me to the amount of maps I can use. Occasionaly I drive off the edge of the known (to me) world.
AnswerID: 265951
Reply By: Patrol22 - Wednesday, Oct 10, 2007 at 19:40
HK
There is a fair range on the market these days. I have been running an Asus Mypal 636N for more than a year now and find it to excellent. I'm running Copilot 6 and Oziexplorer. The only drawback I find is that I'm unable to switch between Copilot and Ozi.
AnswerID: 265957
Follow Up By: Patrol22 - Wednesday, Oct 10, 2007 at 19:42
... oh and there is no limit to the size of the SD card. I run 2gb but I believe 4gb ones are now available.
FollowupID: 527981
Follow Up By: Willykj - Wednesday, Oct 10, 2007 at 20:35
I also have a Asus 636 & it is a great PDA with the GPS built in. Have used it on several long trips with no problems. When travelling I have both CoPilot & Ozi running - usually watching Ozi & listening to CoPilot.
It is easy to switch between them - use the right button on the bottom RHS button - it is called the Mode/Task switcher button.
Willy
FollowupID: 528009
Follow Up By: Patrol22 - Wednesday, Oct 10, 2007 at 22:30
Willy
I just tried that and get the message "Unable to open Port. It may be in use by another program or utility or may not exist on this device" - do I need some additional software to get the two programs to share the GPS port?
Pete
FollowupID: 528051
Follow Up By: Sand Man (SA) - Thursday, Oct 11, 2007 at 01:06
Pete,
Franson GPSgate will allow sharing of multiple programs via the one input port.
I have tried this with OziExplorer and CoPilot and it works very well, every time.
I have tried this with OziExplorer and TomTom Navigator 6 and it doesn't. Navigator just doesn't like sharing with anything.
Also, neither CoPilot or Navigator can be "iconised" to allow something like OziExplorer to be displayed.
Under Widows 5 mobile, there is a switcher bar that can be enabled to allow moving between active programs.
As OziExplorer doesn't cover the top of the screen, the switcher icon can be accessed at any time.
CoPilot and Navigator however, use full screen mode and you cannot see the icon to activate switching mode.
Willy's reply above has given me food for thought and I will investigate if I can assign the "switcher" to a particular button.
In the meantime, I start Ozi first, then CoPilot if I'm in the metro area and need it and then shut CoPilot down once I'm in the country. When getting near a largish town, I can start CoPilot again for possible direction around that town.
In this way, Ozi is running all the time.
Bill
FollowupID: 528066
Follow Up By: Member - Oldplodder (QLD) - Thursday, Oct 11, 2007 at 08:40
Also got the Asus A636, for about 18 months now.
Very happy with it.
Have Oziexplorer and Co-pilot 6, but earlier copilot 6, and it will not switch between them. Have tried GPSgate.
Have tried the mode switcher button.
But have been told 2 things.
1. Start ozi before copliot.
2. The latest version 6 copilot may be more friendly to Ozi.
Havn't tried either yet but on my to do list :o)
It also could just be me coming to grips with the system.
If you are planning to use 4gb SD cards in the Asus some work, some don't. The SD card definition for SD card, version 1.1, only defines the format up to 2gb, not above. SDHC (ver 2 of the SD card format called SD high capacity), defines the format up to 64gb I understand. But not all devices support SDHC, including the Asus mypal 636.
Apologies for hijacking the thread.
FollowupID: 528100
Follow Up By: Steve L - Thursday, Oct 11, 2007 at 09:10
Sand Man,
Not sure what version of GPSGate or WM (or even which PDA) you're using, but I can confirm that GPSGate DOES work perfectly for running both TomTom Navigator and OziExplorer at the same time.
I have been running both on my JAMin for almost 18 months.
FollowupID: 528113
Follow Up By: Hairy (NT) - Thursday, Oct 11, 2007 at 17:26
Me Too! ASUS that is.
FollowupID: 528197
Follow Up By: Willykj - Thursday, Oct 11, 2007 at 20:21
Pete,
I have had my Asus MyPal for about 18 months. You do need to have GPS Gate to run 2 programmes off the GPS at the same time. Just make sure you have the ports set correctly.
It does not matter which software you start first - either CoPilot or Ozi. They can run concurrently & if you are watching maps on Ozi - the voice from CoPilot still comes through. The switching between programmes is real easy - as indicated earlier just use the switch button - RHS sector of the RHS button.
This button can be used to switch between any open programmes. The 1st time you press it it comes to the Start page & each subsequent press it just rotates through any open programmes.
Let me know if I can help further,
Willy
FollowupID: 528246
Follow Up By: Patrol22 - Friday, Oct 12, 2007 at 06:17
Thanks Willy - could you tell me which GPS Gate you loaded? Figure that if your system is working I might as well go down that path rather then trying to set something else up.
Pete
FollowupID: 528312
Follow Up By: Willykj - Friday, Oct 12, 2007 at 11:45
Pete,
The software is Franson GPSGate. The web site is:-
http://franson.com/gpsgate/
You can get a free 14 day trial - I was recommended to it by GPSOZ in Sydney where I bought my PDA.
You set GPSGate to the port from GPS & then the other software - COPilot & Ozi - as virtual ports.
When you want to use it you start GPSGate first - get a satellite connection & then open the other programmes. I've never had any problems once you get the ports sorted out.
Let me know how you get on,
Willy
FollowupID: 528359
Follow Up By: Steve L - Friday, Oct 12, 2007 at 11:50
It's far easier to setup GPSGate to start up when your PDA starts up - that way you simply start the mapping apps (Ozi or TomTom or Co-Pilot or any combo) when you need to and the rest is always working.
You only need to set up one virtual port - I run both TTN6.03 and OziCE at the same time using the same virtual port.
FollowupID: 528363
Follow Up By: Sand Man (SA) - Friday, Oct 12, 2007 at 14:40
Steve,
The problem I have found with Navigator 6 is that it will not share the Virtual GPS Output port. Looks as though it is the version I have. (6.010 vs your 6.03)
I use a BT-338 which uses bluetooth communication.
Input is via Com8 and Output is via Com6 which is a virtual port as created by GPSgate.
OziExplorer runs on this port OK.
CoPilot runs on this port OK.
Navigator spits the dummy, however, if Navigator is started on its own it will happily use the Com6 virtual port.
Easiest solution is to use CoPilot when also using OziExplorer.
Just for reference I use a Dell Axim X51v running Windows Mobile 5, along with:
GPSgate 2.5.0.169
Copilot V6.0.4.106
TomTom Navigator 6.010 (7720)
I also use a Haicom 4 in 1 BT holder for the PDA, but mine is kind of a 3 in 1 as I could not get the included GPS receiver to work over bluetooth. It works OK when set to use Com1 through the physical connection, but I wanted true portability,so bought a Globalsat BT-338 so I could use the PDA away from the vehicle.
Bill
FollowupID: 528399
Follow Up By: Steve L - Friday, Oct 12, 2007 at 22:47
Sand Man,
I seriously doubt it is your version of Navigator. I was running version 6.00 (older than yours) until recently, and Navigator never had any problems sharing a virtual com port (still doesn't with the new version). I'd say it's something setup incorrectly in your general setup elsewhere.
My setup:
imate JAMin running WM5
Holux GPSlim 236 Bluetooth GPS
GPSGate 2.0.1.125
TTN6.03 (8320) with maps v675.1431
OziExplorer CE 1.12.3
Both TTN6.03 and OziCE are using virtual COM7 as the input, which is the only output port I have setup in GPSGate. Almost every trip I do I run both TTN and OziCE concurrently for at least the onroad parts and they both perform flawlessly together....
FollowupID: 528495
Follow Up By: Patrol22 - Saturday, Oct 13, 2007 at 08:27
Thanks everyone - I will give it a go. About to download gps gate now and put my limited techno skills to the test. Will let you know how it goes.
Pete
FollowupID: 528510
Follow Up By: Patrol22 - Saturday, Oct 13, 2007 at 11:32
Willy
Could you please email me peteandlyn22ATbigpondDOTcom - I have downloaded and installed it on my PDA got both programs working together but buggered if I can get the switch tasker to work.
Pete
FollowupID: 528536
Follow Up By: pjchris - Saturday, Oct 13, 2007 at 13:07
GPSGate versions before 2 allowed more than one application to connect to the same Virtual port.
Version 2 and higher of GPSGate you must create a virtual port for each application you want to run at the same time.
To get TomTom and Ozi to run with GPSGate 2.5 you will need to set up two Virtual ports and connect one to each app.
FollowupID: 528552
Follow Up By: Patrol22 - Saturday, Oct 13, 2007 at 14:41
Peter - I ran the wizard to set it up on my ASUS 636N and it only gave me the one virtual port. Both Oziexplorer and Copilot appear to be running OK but I can't get the mode switch button to operate in a way that will let me readily switch between Ozi and Copilot
FollowupID: 528562
Follow Up By: Sand Man (SA) - Sunday, Oct 14, 2007 at 10:07
Yes, that is correct.
The GPSgate version for the PDA only creates the one virtual port which all application programs are (supposed to be) able to share.
The Laptop version however, allows manual creation of individual virtual ports for each application. I have both, although I haven't used the Laptop for GPS tracking for some time.
Bill
FollowupID: 528717
Follow Up By: Willykj - Monday, Oct 15, 2007 at 21:12
Pete,
Have been away for a few days so just saw your post above.
I have emailed you with some more detail on the mode switcher button,
Let me know if you don't receive the email,
Regards, Willy
FollowupID: 528960
Reply By: Member - Lloyd B (NSW) - Wednesday, Oct 10, 2007 at 19:49
I can recommend the HP 6965 it comes with Tom Tom.
Although I haven't actually run Ozi Explorer on it I am sure it would do it capably.
It has built in SIRF III gps receiver, a nice bright screen and the mount that comes with it is excellent.
Also good is the power cable which is mini USB not some proprietary plug.
AnswerID: 265962
Follow Up By: Member - Lloyd B (NSW) - Wednesday, Oct 10, 2007 at 19:59
There I go again. HP 5965 NOT 6965.
Lloyd B
FollowupID: 527986
Follow Up By: John R (SA) - Wednesday, Oct 10, 2007 at 20:56
I have an hp5965 also, and think it's great for navigation.
It comes with Tom Tom, and I've added ozi. They can be run at the same time.
Having previously had a different ipaq with bluetooth gps, I find the 5965 is a bit thicker however it is great to have the inbuilt gps - it means there's one device to turn on, one power cable, the supplied cradle suits me well, and the multitude of shortcut buttons means with a couple of button presses any program you like can be up and running.
It takes and SD card, which I reckon you can now get in 4gb.
The only thing I don't like about it, compared to my old hp 4150, is that it's considerably bulkier so not well suited to slipping into your pocket. I'm just fussy though!!
FollowupID: 528019
Follow Up By: Skippy In The GU - Wednesday, Oct 10, 2007 at 22:04
And you can buy the HP5965 from $400 when on special, Not sure if they will read the 4gig SD card
FollowupID: 528039
Follow Up By: Kumunara (NT) - Thursday, Oct 11, 2007 at 18:49
Skippy
They will read the 4gig SD card
They will not read the 4 gig SDHC card
If you buy a 4 gig card which I have be careful or you will not be able to use it with yout trevel companion
Tjilpi
FollowupID: 528209
Follow Up By: Pajman Pete (SA) - Friday, Oct 12, 2007 at 11:00
Ditto,
Great unit
Pete
FollowupID: 528348
Reply By: blue1 - Wednesday, Oct 10, 2007 at 20:25
I have an almost new Navman PIN570 for sale if you are looking for one.
AnswerID: 265975
Reply By: Kumunara (NT) - Wednesday, Oct 10, 2007 at 20:51
HK
I have a HP iPAQ 5765 Travel companion which is a PDA GPS.
It comes pre-loaded with TomTom.
I have added Oziexplorer CE with Raster Premium and Hema maps.
Used it during travels throughout the Katherine Region and it works well.
Tjilpi
AnswerID: 265983
Follow Up By: Member - Wilgadene (QLD) - Thursday, Oct 11, 2007 at 12:24
Don't suppose you have tried running a wireless SD Card in your 5765 ? I have such a card but am having trouble configuring it
FollowupID: 528142
Follow Up By: Kumunara (NT) - Thursday, Oct 11, 2007 at 18:51
Wilgadene
Sorry - cannot help you as I have not run a wireless SD card in mine.
You may be able to get help from HP.
Tjilpi
FollowupID: 528210
Follow Up By: Member - Wilgadene (QLD) - Thursday, Oct 11, 2007 at 19:13
Thanks Kumunara
We've managed to get ours working now with the wifi SD card - after much gnashing of teeth!! Brilliant little gadget now and works faster than our laptop at doing most things.
Wilgadene
FollowupID: 528216
Reply By: ExplorOz Team - Michelle - Thursday, Oct 11, 2007 at 13:25
Just interested to hear what those you using PDAs instead of laptops think of the screen size for navigation whislt driving. As you probably know, our setup is with a laptop desk in the passenger seat and on the go, I like the ability to see everything in front of me without having to get up close to the screen. I often find things "appear" on the maps whislt driving and take a look just because we saw it on the map, and wonder if perhaps using a smaller screen that I wouldn't have such a clear visibility and might miss such opportunities. (Note - we do use a PDA on our boat for navigation but the speed travelled is less, so the zoom level is set differently and not an issue). Just not sure about using the PDA at driving speeds.
Michelle Martin
Marketing & Customer Support
AnswerID: 266093
Follow Up By: Kumunara (NT) - Thursday, Oct 11, 2007 at 18:56
Michelle
I do not have a problem with the screen size. I am 55 and need glasses to read.
I can use moving map on the laptop by connecting the PDA.
It gives you a lot of versatility.
1. You can you Tom Tom for voice direction on road navigation
2. You can use Oziexplorer CE for off road navigation on the PDA
3. You can connect the PDA to the laptop and use Oziexplorer on the laptop for navigation.
4. The PDA is portable so it can be used when walking.
Tjilpi
FollowupID: 528212
Follow Up By: HK - Thursday, Oct 11, 2007 at 21:04
Michelle I am interested in knowing how you use the laptop, does it sit on the passengers lap or is it mounted some how?
FollowupID: 528255
Follow Up By: Kumunara (NT) - Thursday, Oct 11, 2007 at 21:08
I have my laptop in the back seat and run a video out lead to a 7"monitor on the dash.
I wanted to have the laptop in the front and put the trouble and strife in the back seat. I don't know why she refused. No sense of humour.
Tjilpi
FollowupID: 528257
Follow Up By: Sand Man (SA) - Friday, Oct 12, 2007 at 14:58
Hi Michelle,
The Dell PDA running OziExplorer has a big enough display for almost everything. The moving map function works very well.
I am still learning it's finer points, e.g. tapping the screen to record a waypoint. I am yet to be convinced that it would be as practical as the Laptop when recording data to create Treknotes.
Compactness is the biggest advantage.
My Wife mildly objected to the Laptop's "intrusion" when travelling.
She used to have it sitting on her lap until I installed the Laptop holder so it sat over the centre console, but she still thought of it as an intrusion, so I invested in the PDA solution. I agree with your point about the larger screen allowing those finer details to be more apparent. It all becomes a compromise in one way or the other I guess, but you just cannot beat the bigger display size the Laptop provides.
From my point of view, the jury is still out on what is the best setup.
Bill.
Bill
FollowupID: 528400
Follow Up By: The Explorer - Tuesday, Oct 16, 2007 at 11:37
Hello Michelle - use a PDA/OziExplorer all the time and cant say I find the issue you mention significant....but this doesn’t mean it isn’t an issue for some as we all have different requirements. No doubt the bigger the screen the better but range of advantages using a PDA and disadvantages of using a laptop outweigh any screen size issues, for me at least . Also note that most handheld GPS units have smaller screens than PDAs so if it was a universal problem there would be a lot of sufferers, though no doubt some people find PDA (and I presume handheld GPS screens) too small to use properly in a car.
OziExplorerCE has ability to show more of the map in your direction of travel, which does help in giving forward warning of approaching features of interest (though doesn’t help if they are to left or right of displayed area). The PDA touch screen also allows you to pan outside current view for sneek peek of adjoining areas in any direction (though you have to turn off GPS communication to view adjoining map sheets).
A bit of forward planning on the PC (making waypoints, map features, routes and tracks) before departing on trip also goes a long way in making sure you don’t miss anything special (applicable if using PDA, handheld GPS or Laptop)...so you can work around the screen size issue if it becomes an annoying problem.
FollowupID: 529081
Reply By: HK - Thursday, Oct 11, 2007 at 21:00
Thanks to all-Iwent to look at the HP5965 today and have been told their will be a new model in 2 weeks time .Nobody can give any details regarding specifications so I may wait.
AnswerID: 266210
Follow Up By: Kumunara (NT) - Thursday, Oct 11, 2007 at 21:10
HK
That's probably why the HP5965 is selling cheap at the moment.
It will be interesting to see what the cost is of the new model.
Tjilpi
FollowupID: 528258
