Gas Heaters
Submitted: Saturday, Nov 03, 2007 at 20:05
ThreadID: 51252 Views:3540 Replies:5 FollowUps:6
I know it the wrong time of the year but was down rangers today and spotted a couple of gas heaters (coleman and can't remember other brand).
Has anyone got this style of heater?
what do you do in a mobile home or caravan for ventilation?
Would leaving a window open say 4" (100mm) be sufficient?
I know you would loose some of the efect but just looking for a way to knock the chill off in middle of winter.
Rgds
Ian
Reply By: Member - Ed. C. (QLD) - Saturday, Nov 03, 2007 at 22:24
How deep are your pockets??
I got me one o' these Site Link diesel burners, and wouldn't be without it!
Quite a bit more expensive than the portable gas heaters, but IMO the only _safe_ way to heat an enclosed space (when away from electricity, that is)...
Not only safe, but very economical, with the smallest model burning from 0.12 - 0.24 of a litre of diesel per hour, for an output equivalent to 0.9 - 2.0 kW .. plenty good enough to knock the chill off a winter morning;-))
More info here Site Link
Regards,
Ed C
Confucius say.....
AnswerID: 269953
Reply By: disco1942 - Saturday, Nov 03, 2007 at 23:45
Any gas water or space heater fitted to a caravan must draw its air from outside and exhaust the combustion products to the outside. The Coleman catalytic are not suitable for use in vans and any reference to using them in vans has been removed from their accompanying literature.
AnswerID: 269964
Follow Up By: Gone Bush (WA) - Saturday, Nov 03, 2007 at 23:53
While I acknowledge what you're saying Disco, using a Coleman Catalytic with a bit of commonsense isn't a problem.
I used one to heat our van up then turn it off (and open the roof vent slightly) before climbing into the fartsack. So while I'm up and about before beddy-byes it's warm.
FollowupID: 532870
Follow Up By: Sand Man (SA) - Monday, Nov 05, 2007 at 10:46
Quite right Bushy and that would go for any combustion type heater, including the diesel fueled one. It would still give off carbon monoxide from the burning process so an open vent, window, or similar ,should give enough freash air circulation.
If it doesn't you wouldn't know about it:-(
Bill
FollowupID: 533125
Reply By: disco1942 - Saturday, Nov 03, 2007 at 23:54
Any gas water or space heater fitted to a caravan must draw its air from outside and exhaust the combustion products to the outside. The Coleman catalytic heaters are not suitable for use in vans and any reference to using them in vans has been removed from their accompanying literature.
AnswerID: 269965
Follow Up By: disco1942 - Saturday, Nov 03, 2007 at 23:57
sorry for the duplication. When I first hit the send button it did not respond normally and did not return to the thread.. The second time it did and revealed my first attemptat posting
FollowupID: 532871
Reply By: Member - Noldi (WA) - Sunday, Nov 04, 2007 at 10:52
Thanks all,
I can see that if money was of no concern, then the Webasco would be the way to go. Unfortunatly I may have to go the GB route and turn it off before retiring.
I spen 3 years in the UK, the gypsies travel about in all sorts of weather, I don't know how they handle the heating.
It's normally warm enough in bed, but this year we had a problem when we came down with the flu, no problem during the day but at night it was a killer with the cold air.
Alternatively maybe if it occurs again we head straight for a caravan park for power and carry a small electric heater
AnswerID: 269998
Reply By: gonebush SA - Tuesday, Nov 06, 2007 at 20:44
hi, we bought a gas heater last winter for our van, it runs on those gas canisters (around $5 for 4 from big W) our heater cost $140 from Boots camping, have seen them in other camping stores around the same price. i can't remember the name but can find it out for you if you are interested- starts with a K i think. we used it in the van to take the chill off and it worked a treat. we made sure that the vents of the van were not covered over to allow air through and it warmed it up in no time. when it was warm enough or bed time we turned it off and have made slides out of perspex the cover over the vents in the door to keep in the heat when it's really cold.certainly well worth a look and at a good price.
good luck and stay warm, don't hesitate if you want any more info to get back in touch Chris.
AnswerID: 270407
Follow Up By: Robin Miller - Wednesday, Nov 07, 2007 at 21:53
Its called a little sun , made by Kovea Chris
We have one and its a very effective unit, taking up les space and putting out a lot more heat than the Coleman.
But its really meant for a ventilated enclosed area or where the air is still outside but doesn't do much in a windy outside setting.
Robin Miller
FollowupID: 533665
Follow Up By: gonebush SA - Thursday, Nov 08, 2007 at 10:24
yes that's the name, as i said we make sure the vents in the van are open and we don't need it on for long as it warms up the van so well. we would never go to bed with it on. yes i have heard from others that outside it's not much chop. chris.
FollowupID: 533722
Follow Up By: Robin Miller - Thursday, Nov 08, 2007 at 10:56
The following link is worth reading Chris - and downplays the carbon monoxide danger.
Click on Carbon Dioxide Myths
http://www.bushwalking.org.au/FAQ/FAQ_Index.htm
FollowupID: 533724
