help wanted- what amp wire do i use?? installing waeco
Submitted: Wednesday, Nov 07, 2007 at 18:19
ThreadID: 51385 Views:3480 Replies:14 FollowUps:5
hi, we have just bought a small (21 litre) waeco and are wiring up the car for it, we are going to use anderson plugs and put a connection in the back of the car and one in the boot.
what amperage wire would you recommend? we were thinking of 20amp but don't know if it's an over kill.
thanks from Chris.
Reply By: Member - Doug T (Qld) - Wednesday, Nov 07, 2007 at 18:40
Chris.
I just use a 10a , I know what all the experts will say but mine is a long wire to a switch and the to the rear wheere the fridge is , works all day, no problems, even have to turn the control back or the milk freezes up
AnswerID: 270587
Follow Up By: Member - Graham H (QLD) - Wednesday, Nov 07, 2007 at 18:45
Waeco supply 6mm twin with their power supplies that go down the rear so I guess that will do Raps12RU2 they are called.
FollowupID: 533595
Reply By: Axel [ the real one ] - Wednesday, Nov 07, 2007 at 18:45
Tis not the amperage that you should concern yourself about but the actual thickness of the wire , 6mm sq is the recomended minimum , that being the wire thickness , NOT wire + insulation , you will find that 6mm / 8mm sq fits the 50amp anderson plugs.
AnswerID: 270588
Reply By: Sand Man (SA) - Wednesday, Nov 07, 2007 at 18:45
Chris,
It's not the amperage you need worry about.
The Waeco will only pull about 2-3 amps maximum when it's running flat out.
Voltage drop is the main concern and for this reason it is normal to use something like 6mm(2).
A 10 amp fuse at the battery end to protect the circuit and you will have no problem.
Bill
AnswerID: 270589
Follow Up By: Member - Phil G (SA) - Wednesday, Nov 07, 2007 at 20:47
Sandman,
Have you measured current on the Waeco when cycling?
I measured 5amps normal cycle and 7amps on Boost on a 50 litre model.
FollowupID: 533642
Follow Up By: Sand Man (SA) - Wednesday, Nov 07, 2007 at 21:32
Well bugger me Phil, and I was going to be diplomatic and not get involved in "fridge politics"
Hungry buggers aren't they?
Glad I own an Engel:-))
Bill
FollowupID: 533661
Follow Up By: Member - Phil G (SA) - Wednesday, Nov 07, 2007 at 22:27
Yep, hungry, but they don't cycle as often.
The 40litre Engel _Affordable_Storage_Drawers.aspx about 2.8 amps when cycling, but cycle more often than the Waeco.
Overall, they usually suck about the same amount out of a battery.
FollowupID: 533671
Reply By: Phillipn - Wednesday, Nov 07, 2007 at 18:54
Go to Exploroz home page , click on caravan or camper then click on caravan and camper battery charging. Scroll down to tow vehicle, you will get some good ideas from the diagrams their.
If you use wiring that is too small you will get voltage loss and your fridge may not run the way it ought too.
AnswerID: 270591
Reply By: Robin Miller - Wednesday, Nov 07, 2007 at 19:37
Hi Chris
Use one of them fridges myself , great little unit.
Anderson plugs are probably an overkill.
I think a couple of other respondents have said that its the total voltage drop that counts and I agree with this.
It is particularly important in this fridge because it can draw 7amp continuous and even higher short term peaks.
These can upset the low voltage protection circuit.
You need to use wire with 4mm sq copper area for that 4m long run.(called 30 amp cable), or of course larger.
I run other things as well from the back of the car and just ran 6mm sq copper to rear, split the ends and soldered on 4mm cable which runs off to several socket.
The lead on the end of that fridge can plug into cig lighter or a Merit plug via the removeable red piece.
Merits are better and widely available.
Robin Miller
AnswerID: 270600
Reply By: obee - Wednesday, Nov 07, 2007 at 21:14
High amps are only required if you are charging a second battery and want it charged up in optimum time. I have a second battery in the back so I want the alternator to able to push a good flow. I also run the gennie through a regulated charger; same requirement. I dont think you will have any problems as long as the motor gets a good run every day. Its only a small fridge too so maybe every couple of days. Just keep an eye on the battery voltage while you are getting used to it.
Hope this helps
Owen
AnswerID: 270630
Reply By: Derek from Affordable Batteries & Radiators - Wednesday, Nov 07, 2007 at 21:55
Hi Chris
Use 6mm2 cable. Twin core. Voltage drop is a problem and if you get a bigger fridge later you don't want to have to replace the wiring again.
Here is good quick formula.
Voltage drop equals (cable length (in metres) X current (in amps) X 0.017) divided by cable CROSS SECTION in mm.sq.
Waeco fridges are known to show 'ERROR' if there is voltage drop in the cable and the battery is below 50%.
Derek.
AnswerID: 270640
Reply By: Mick - Wednesday, Nov 07, 2007 at 23:15
You may get away with smaller wire but 6B&S is regarded as the best way to go. Maybe compare it to tow vehicles. You can tow with a Commodore but it is much better to tow with a Cruiser. 6B&S is about 14mm2 and fits snugly into the Anderson plug terminals - just half fill them with solder and pop the wire in (use a butane torch about $13). With the proper wire you will not suffer voltage drop or overheating.
AnswerID: 270656
AnswerID: 270657
AnswerID: 270658
Reply By: Mick - Wednesday, Nov 07, 2007 at 23:17
AnswerID: 270659
Follow Up By: gonebush SA - Thursday, Nov 08, 2007 at 10:15
hi, in fact we do tow with a Commodore, i must admit it does a good job of it too, yes i can see what you are saying. thanks chris.
FollowupID: 533720
Reply By: Mick - Wednesday, Nov 07, 2007 at 23:42
Have a look at this linkhttp://www.fridge-and-solar.net/more.htm
AnswerID: 270664
Reply By: Mick - Wednesday, Nov 07, 2007 at 23:55
http://www.fridge-and-solar.net/dual_bat.htm is good too
AnswerID: 270669
Reply By: gonebush SA - Thursday, Nov 08, 2007 at 10:20
thankyou all for you help, at least now i have a good idea of what to use. the main reason for using the anderson plugs are that we already had them to use with our 3 way fridge but after buying all the bits found out it wont fit in the car by about 1/2 an inch (not happy). once again thanks heaps it's great having this wealth of knowledge just a keyboard away. Chris.
AnswerID: 270706
