Camp shower base
Submitted: Monday, Nov 19, 2007 at 13:47
Member - Mick T (QLD)
Hi all,
just wondering about what others use for the bottom of your
camp ensuite on the shower side, to keep feet out of mud. have tried a pile of sawdust and a rubber mat but with 2 kids it just gets everywhere. want something light enough but able to withstand my fully beer laden weight ...lol
cheers in advance
Mick
Reply By: Member - Troll 81 (QLD) - Monday, Nov 19, 2007 at 13:49
Mick we just have some foam mats that we got from BCF with holes so the
water can drain out but your feet stays clean...works for us
272511
Follow Up By: Vince NSW - Monday, Nov 19, 2007 at 14:26
We also use the foam mats with a shower tent above. If we are staying in the same place for a few days we move the tent. It's one of the self erecting type
Vince
535767
Follow Up By: Member - Crazy Dog (QLD) - Monday, Nov 19, 2007 at 17:54
A Viagra Tent - Gotta get me one of those...
ROFLMAO...
Grrr!!!
535821
Reply By: equinox - Monday, Nov 19, 2007 at 14:14
Back in the old days we use to use a wooden pallet with a rubber mat with holes on it on top.
It helps to have a ute though, for transporting it.
272516
Follow Up By: Willem - Monday, Nov 19, 2007 at 14:25
Al....that Rig Pic of yours would have been a bit of an adrenalin rush???
535766
Follow Up By: equinox - Monday, Nov 19, 2007 at 14:54
haha, It wasn't only adrenaline.
There were lots of foreign skirts around.
What was I supposed to do??
535773
Follow Up By: Member - Davoe (Yalgoo) - Monday, Nov 19, 2007 at 15:25
Was that from around 18 months ago when you posted about it?
Did you end up getting any
water into the G box or diff?
535778
Follow Up By: equinox - Monday, Nov 19, 2007 at 15:55
Davoe,
Yes that was it - post 27365 (18/10/05)
I and the resort mechanic (I was his boss) checked it out the next day , Oil was fine no
water in diff. Didnt check the gearbox.
535788
Reply By: Member - Mark H (VIC) - Monday, Nov 19, 2007 at 14:23
Mick,
We used to use one of the plastic trays that supermarkets keep their loafs of bread on, with a cheap car rubber mat on top. Worked a treat, took up no room to pack.
Mark.
272520
Reply By: Member - Phil G (SA) - Monday, Nov 19, 2007 at 14:32
6x4 Plastic tarp is all we use both in front of and inside the shower tent. Just make sure the back of the shower tent is downhill, so the
water flows out the back.
272525
Reply By: ddr - Monday, Nov 19, 2007 at 15:01
We use a small piece of artificial grass with holes poked through. Weve tried plasic of all sorts but you still get muddy, the grass was the only thing that we didnt get any mud on our feet after several showers.
272529
Reply By: traveller2 - Monday, Nov 19, 2007 at 15:19
A double layer of at least 75% shadecloth,
water goes straight through, dries quickly and packs up small. We've used it in everything, mud, sand, grass and just about everything in between. Also used as a mat at the front door of the tent or camper.
272530
Reply By: Member - Hayjude (NSW) - Monday, Nov 19, 2007 at 15:25
We cover the base of the shower with gum leaves (dry or green) and then have one of those rubber mats with holes on top of that. works a treat.
272533
Reply By: Member -Dodger - Monday, Nov 19, 2007 at 17:34
We use the Rubber mat trick and if on black soil country where mud may be a problem then the old bread crate upside down works great with the rubber mats .
ER or you can just give up showering for a phew days sic.
272557
Reply By: Moggs - Monday, Nov 19, 2007 at 19:05
We just use the Bushranger drivers side floormat - has a rim that stops the muddy
water flowing back onto it. Always in the vehicle and drys in a couple of minutes thrown over the bullbar. Why pack something when there is already a floor mat in the vehicle :-)
272573
Follow Up By: Axel [ the real one ] - Monday, Nov 19, 2007 at 20:08
Goes
well with the theory that all thing in
camp should have at least 2 uses.
535853
Reply By: Muddies Doe(Trippn) - Monday, Nov 19, 2007 at 19:22
Hi Mick T
Bunnings have a slatted wooden one, quite nice for about $35. A rubber mat to the thickness you desire can be put on top of it should you find it hard on the feet.
Used it last weekend and was quite happy with it.
Cya
272574
Reply By: Mike Harding - Monday, Nov 19, 2007 at 20:13
6 x 4 tarp - $1.50 from Super Cheap et al.
272591
Reply By: AT4WD ADVENTURES - Monday, Nov 19, 2007 at 21:34
I cut the base out of bread crate work great drain
water and is easily dryed off, lightwieght
Stuart
272610
Reply By: japmel - Monday, Nov 19, 2007 at 21:51
Another vote for the Bottom of an old Bread Crate, Works great takes up no room...It just works.
272618
Reply By: Bryan 06 - Monday, Nov 19, 2007 at 23:06
Hi Mick
We use a small blow up paddling pool with a drain plug in the base - it fits nicely in the bottom of the shower tent and the drain on the bottom allows the
water to run out without getting muddy feet. The only problem is that the little blue ducks which are printed on the sides make for some humerous comments at some
camp sites!
Bryan
272647
Reply By: Sand Man (SA) - Tuesday, Nov 20, 2007 at 00:01
We use a foam holed mat, similar to the ones shown of the link below.
You can buy them in packs of 4 or 6 and "clip" them together.
We find just one of about 600mm square does the job for us and it fits into the bag that holds the "viagra tent" as someone mentioned above.
Foam Mats
The link shown is for Discount
Camping but I think they would be available in most
camping stores.
272655
