stainless steel security wire locks
Submitted: Tuesday, Nov 20, 2007 at 21:31
Member - Mick M (QLD)
has any member come across these,i need 3 to secure engel next to caravan when out of nissan,1 to secure outboard and hydrolic jack to front draw bar, i to secure book case solar panel remote from van. come in various lengths i think,can anyone help me where to buy them regards mick
Reply By: HK - Tuesday, Nov 20, 2007 at 21:53
Hi do you mean lock alarms as I have just ordered 2 today .can give you the contact numbers if interested.
Regards HK
272836
Reply By: Stu050 - Tuesday, Nov 20, 2007 at 22:24
A ships
chandler (boat stuff) should be able to make them up for you to your required lengths.
272844
Reply By: Sand Man (SA) - Wednesday, Nov 21, 2007 at 01:49
Mick,
Saw these lockable straps at Roof Rack World the other day.
They have hardened stainless steel cables running down each side.
SPT Lockable Tie-downs
272870
Reply By: Member - Gavin B (NSW) - Wednesday, Nov 21, 2007 at 08:58
If you're talking about stainless wire rope with swaged ends so you can lock them with a padlock, I've previously had them made up on
the spot at Whitworths or Bias boat chandlers.
If you're buying the rope/swages etc from them they normally do the swaging free for you.
272896
Reply By: Steve Ellis - Wednesday, Nov 21, 2007 at 09:59
GDay Mick. I went to a bike
shop and bought a security cable for about $25 to do exactly what you want. They had them dearer and cheaper than that. Comes complete wth a pretty flash lock with 2 circular keys. A decent lock alone is $20 these days.
272905
Follow Up By: Steve Ellis - Wednesday, Nov 21, 2007 at 10:04
Gday again Mick. I forgot to say that most stainless steel flexible cable can be cut with large sidecutters and bolt cutters. Dont forget to locktite the handle screws on the Engle so they cant be undone or the best lock and cable in the world is useless.
536226
Reply By: Member - Mainey (wa) - Wednesday, Nov 21, 2007 at 10:51
If someone wants something bad enough they will do whatever it takes to "remove" it from you, best you can hope for is to slow them down.
I've seen an electronic siren that attaches to the 'fridge or solar panel' that screams like a banshee when the power is de-activated from it by cutting the security cable, it had a small "notice" attached to warn would-be 'light handed priks' that the siren would activate immediately the cable is cut, and clearly stated they should be able to run very fast with the goods before the legitimate owner put their head out of the door to see who was stealing their beloved possessions.
(use thick chain inside a thicker plastic 'hose' to secure outboard to front drawbar)
272914
Reply By: Member - barry F (NSW) - Wednesday, Nov 21, 2007 at 19:54
Hi Mick, problem is the old saying that locks only keep honest people out. If the mongrels want it, they will take it.
Good luck & cheers
273000
Reply By: Hoyks - Wednesday, Nov 21, 2007 at 21:05
All you can do is make someone else's stuff look more appealing.
The more inconvenient it is to nick, then they will go else where. I used to fit security windows to shops and found that after a second attempt to get in, the shops we fitted the products to wouldn't have any more problems for quite a while. The little toe rags are often repeat offenders and the word gets around quickly who the easy targets are.
Hardened chain inside an old bike inner tube works
well. Wire rope can be cut in time but, again, if you make it too hard they will look for an easy option.
Claymore mines should be made available to honest campers ;-)
273020
Reply By: Sand Man (SA) - Wednesday, Nov 21, 2007 at 23:44
As far as securing outboard motor security is concerned, most of them have clamp handles that are lockable.
Whether you are clamping them to the boat transom, or to a "transport" bracket on the drawbar, etc., by doing up the clamps, you should them be able to pass a padlock through the holes in the handles, making it very hard to remove the outboard.
273050
Reply By: Member - City_Wombat - Wednesday, Nov 28, 2007 at 22:43
Mick,
I came across this site some time ago. Maybe it has what you want...
Allen
Lockalarm
274144
