What glue to affix velcro to canvas?
Submitted: Tuesday, Dec 18, 2007 at 09:06
Grassparrot
I am wishing to affixe a strip of velcro to my camper trailer to join the awning to trailer with no gap inbetween. I dont have time to get it sewn as I am going away on Monday. I have decided to glue it for now and get it sewn when I return.
What glue should I use???
Reply By: Robin Miller - Tuesday, Dec 18, 2007 at 09:27
Hi Grassparot
You don't say what type of Velcro so I will assume the woven type (not sticky back stuff)
The woven type has an elastomeric binder coat which locks in the hooks and loops in the ground weave and so most commerical glues don't work
well with it.
Hence they reccomend sewing, or at least starting with the adhesive backed stuff and hand sewing a few points to help it hold.
I'd take a little hand sew kit and sew it when you can.
277205
Follow Up By: Grassparrot - Tuesday, Dec 18, 2007 at 09:33
I was thinking of glueing the sew on type but from what you have said this may not work. Could I glue the stick on type?
541100
Follow Up By: Robin Miller - Tuesday, Dec 18, 2007 at 10:53
I would admit to araldite thru the canvas but not to be reccomended
Actually our Velcro rep is pretty good and you may like to call them on 03 9703-2466 (Velcro aust)
541122
Follow Up By: Grassparrot - Tuesday, Dec 18, 2007 at 14:27
Robin,
I have rang the rep in SA and he was very helpful. Said I could glue it with "contact adhesive" as the velcro is not under "load" on the joins. Tent poles are taking all the weight and support.
Thanks for your help
Grassparrot
541178
Follow Up By: Member - Phil G (SA) - Tuesday, Dec 18, 2007 at 16:26
Grassparrot,
I've used contact adhesive to stick velcro in odd spots and it works
well. KwikGrip (thin) works better than most - I coat both surfaces, and leave it apart until its fully dry; then smear a bit more on each, get them tacky and join.
541203
Reply By: Sand Man (SA) - Tuesday, Dec 18, 2007 at 09:34
No glue will provide a bond strong enough to achieve what you desire.
That's why they are sewn in the first place.
I wouldn't risk contaminating the canvas and potentually destroying its waterproof properties.
My tip is to do without the awning "one more time" and have the velcro sewn on at a more convenient time.
277210
Reply By: Redback - Tuesday, Dec 18, 2007 at 09:49
You need cotton glue, apply liberal amounts using a needle or a sewing machine!!!!
Baz.
277213
Follow Up By: flappa - Tuesday, Dec 18, 2007 at 10:33
I like that Baz , good one.
541111
Follow Up By: Grassparrot - Tuesday, Dec 18, 2007 at 11:55
Baz,
Nice and subtle - I like it.
Grassparrot
541144
Reply By: Des Lexic - Tuesday, Dec 18, 2007 at 10:27
Grass Parrot, Give Doug Smith a call on 8586 3647. He works from a shed near the pub on Para Street. He might be able to squeeze you in. He is Gus' brother if you knew him.
277221
Follow Up By: Grassparrot - Tuesday, Dec 18, 2007 at 11:58
Thanks Des, knew his brother, but not him. Have seen the set up behind the drive through and wasn't sure if it was up and running yet.
Grassparrot.
541145
Follow Up By: nowimnumberone - Tuesday, Dec 18, 2007 at 12:26
a pub or para street
how convenient.
ive been para at plenty of pubs
541151
Follow Up By: Des Lexic - Tuesday, Dec 18, 2007 at 13:04
And a fine Pub it is on Para Street
Renmark
541161
Reply By: mfewster - Tuesday, Dec 18, 2007 at 12:19
I reckon that the advice on sewing is the best, but one product I have used on canvas is worth a mention. There is stuff in a tube called "Shoe Goo." You use it to build up new soles on worn shoes. Waterproof, tough and flexible when dry. I have used it successfully on a number of repairs to tents and waterproof jackets. I'd be inclined to use some and sew it as
277235
Reply By: Member - DAZA (QLD) - Tuesday, Dec 18, 2007 at 13:15
Hi Grassparrot
You might laugh but I have seen Velcro Stapled as a temporary
solution,
Daza
277240
Follow Up By: Grassparrot - Tuesday, Dec 18, 2007 at 14:31
Daza,
I like a bit of lateral thinking. I wasn't laughing, but I was surprised. After some thought I will be gluing the velcro as per what the Rep told me but if it gives me grief the staples has some merrit as I have access to a stapler at work that can do 120 pages at a time.
Thanks for your input.
Grassparrot.
541179
Reply By: Willem - Tuesday, Dec 18, 2007 at 15:02
Grassparrot
There is an industrial type glue used by Motor Trimmers and Upholsterers.
I recently had a canopy built for my trailer and the Upholsterer forgot to put the velcro strips on to Dacron type material. He then glued them on and they are stuck fast. Seeing same fella this afternoon and will ask for the name of the glue.
277255
Follow Up By: Grassparrot - Tuesday, Dec 18, 2007 at 15:27
Willem,
A brand name and type would be great. See how you go and let me know.
Thanks in advance.
Grassparrot
541187
Follow Up By: Willem - Tuesday, Dec 18, 2007 at 20:54
My Upholsterer said that the glue I mentioned was only good for adhesive to PVC type materials.
He suggested you speak to Canvas Makers as there is a special glue to be used on canvas but he did not know the name of it. The industrial type glues are made by Ferrari(brand name)
541239
Reply By: Bob Y. - Qld - Tuesday, Dec 18, 2007 at 22:01
Grass,
If you are gunna glue it, try Selley's Liquid Nails. I know its a woodworking adhesive, but we used to use a similar type glue, back in the BTEC days, to stick back tags onto cattle.
It used to stick like the proverbial!!!!!!!!!
Have a good holiday,
Hooroo,
Bob.
277355
