3.0 ltr Patrol Auto Towing Capability
Submitted: Thursday, Jan 03, 2008 at 15:31
ThreadID: 53077 Views:4054 Replies:8 FollowUps:3
I am considering purchasing a camper trailer (950 kg dry weight) but am a little concerned about the capability of the towing vehicle (2006 3.0 litre Patrol with AUTO transmission).
Any comments/experiences/advice ??
Reply By: Sand Man (SA) - Thursday, Jan 03, 2008 at 15:39
It will eat it!!!
Bill
AnswerID: 279552
Reply By: Member - Kingsley N (SA) - Thursday, Jan 03, 2008 at 15:50
Stevo,
I tow a campervan (see below) that probably gets to about 1500kg loaded (empty1200kg) with no problem at all behind my 3.0 auto.
You will need trailer brakes of course and I believe over ride hydraulics are preferred for camper trailers. I have electric brakes on the van.
Going up hill you do slow down but never to the detriment of most traffic. I use the PWR setting next to the selector when driving through traffic to give a quicker acceleration. I also lock it out of OD when the terrain is hilly to avoid unnecessary up and down shifts.
We can easily sit on 110+ on flat terrain, overtaking road trains etc with no problem.
Diesel consumption increases with speed and load of course. Expect about 15L per 100KM at around 95-100 with a full load. The highest consumption I recorded when towing at high speed on a windy day was around 17L.
The cruise control works OK when towing on the flat, but it drops out when you come to a hill, so I have learned to anticipate this and I press down on the accelerator to clear the hill, then ease off to the cruise setting at the top.
You will see 3.0 L nissans towing quite large vans and I am sure someone on the forum will fill you in on the heavy weights too.
Kingo
AnswerID: 279555
Follow Up By: Kazza055 - Thursday, Jan 03, 2008 at 17:15
Have to completely agree with Kingo.
We towed a 23' full van that weighed in at 2600kg plus we were probable another 200kg over on the vehicle load. With the weight you are proposing to tow, try OD but watch for the revs changing as this will indicate that the torque converter is slipping and slipping torque converters will generate unwanted heat.
We did about 18,000km touring back in 2006 and only used the three gears. I also tend to drive it like a manual and change down before the gearbox does and don't push the pedal to the floor. I had some hills like Moonbi 1 and Moonbi 2 on the New England Highway were I was down to 1st gear and 25kph coming over the top (luckily there was an overtaking lane but had nobody pass me).
It is a pity that Nissan haven't got a better auto but then I believe the towing capacity for the same vehicle is much higher in NZ.
FollowupID: 543744
Follow Up By: Member - Graham H (QLD) - Saturday, Jan 05, 2008 at 10:39
The legal towable weight for a 3 litre Patrol is 2500kg
The reason is that the drivetrain is lighter than the one in the 4.2.
I had one and my van was 2600kg so had to sell it and by a curiser to stay legal.
Despite what salesmen will tell you "just dont fill the water tanks"
If the compliance plate GVMm is over 2500kg its illegal to tow it with that vehicle
FollowupID: 544074
Follow Up By: Member - Graham H (QLD) - Saturday, Jan 05, 2008 at 10:58
Correction Should have been 3 litre Patrol AUTO
FollowupID: 544077
Reply By: AMack - Thursday, Jan 03, 2008 at 21:07
After experiences with 3.0auto and 4.2man, the 3.0 auto is ideal for your purpose. Both ok for moderate towing, with the 3.0 better of the 2, just avoid O/D at all times. Niether great for really big loads in my opinion. Great 4wd's though.
AnswerID: 279609
Reply By: Motherhen - Thursday, Jan 03, 2008 at 23:59
Stevo, For that weight camper you'll hardly know it's there. Just remember on the rough roads while you drive in comfort, that the camper will be rattling along behind you - slow down a little. We were given these words of wisdom from a seasoned caravaner when we stopped and the door hinge had broken on the windup camper - the gentleman had the right sized bolts ready to fix it before my husband could reach for his toolbox. We slowed down a bit after that and not so much fell off its hinges in the camper.
The auto has the same motor as the manual - just apparently rated lower due to breaking capacity of auto.
We towed a much heavier rig with a 3 litre auto.
AnswerID: 279652
Reply By: Member - greg S (QLD) - Friday, Jan 04, 2008 at 00:01
Stevo,
We have an 07 3L auto Patrol, and it tows our camper (weighs 1100 empty, 1600kg fully loaded) really well. It really surprised us how it went on Fraser Island in the really soft sand. Never got bogged, even with the camper on.
It will tow that camper easily.
Cheers Greg
AnswerID: 279653
Reply By: BMKal - Friday, Jan 04, 2008 at 02:53
Stevo,
A mate of mine that I go on occasional camping trips with tows a much heavier trailer than what you are talking about behind his 3.0l Patrol without any troubles. His is a large tandem trailer with steel cabinets on the sides, 2 x quad bikes on the floor, and a standard camper trailer canvas set-up on a roof rack above it all.
I pull my own camper trailer which weighs about a tonne loaded behind a 2.5 litre Landrover diesel. The size of the diesel engine has very little impact on the towing ability of 4wd's these days (despite what some will tell you). My Landrover actually pulls the camper better than the 4.0 litre petrol Prado that I used to have.
Cheers ............... BM
AnswerID: 279664
Reply By: Stevo - Friday, Jan 04, 2008 at 08:27
Thanks for all your responses, folks. I obviously won't have any problems.
AnswerID: 279700
Reply By: goingplatinumcomau - Saturday, Jan 05, 2008 at 00:46
Yes they fit on most tow trucks
AnswerID: 279858
