GPS navigators
Submitted: Tuesday, Jan 22, 2008 at 13:06
ThreadID: 53779 Views:4846 Replies:6 FollowUps:6
Hi All
I currently run a laptop with ozi explorer and hema maps and gps aerial. I want to get a portable unit for street navigation that can also run ozi explorer when touring. My other uses would be in the boat for marine use and also i drive a truck and hopefully the software also has truck routes etc like the hema truckie atlas. Is there such a unit on the market that can do all these task's? Can i download street nav software to my laptop and were from? I have been told that an ISUS ( spelling) or similar pda may be suitable? Hope you get the drift of what im after.
jay
Reply By: Mr Pointyhead - Tuesday, Jan 22, 2008 at 14:22
I would think that one of these
http://h10010.www1.hp.com/wwpc/us/en/sm/WF05a/215348-215348-64929-314903-215384-3544499.html
With
http://www.travroute.com.au/index.php
for routing.
The HP PDA will also required a external bluetooth GPS. The advantage of the HP PDA is that is has a high res screen which makes for easier reading.
The ASUS one is this
http://www.travroute.com.au/index.php?page=shop.product_details&flypage=shop.flypage&product_id=9&category_id=27&manufacturer_id=0&option=com_virtuemart&Itemid=1
It has the built in GPS but it has a lower resolution than the HP.
If you are in Melbourne I would suggest visiting
http://www.ja-gps.com.aushop at St Kilda as they should be able to provide support you need to get a solution up and running
AnswerID: 283114
Reply By: Member - Doug T (FNQ) - Tuesday, Jan 22, 2008 at 14:42
Forget all the other crap, if you drive a truck and want truck routes ,not available yet but the Garmin units can be set for trucks, and the only way you'll get routes is to make them yourself The units Route Planner lets you save 50 routes , on the Garmin mapsource software you will get to put on your PC , and the best unit for that is the Garmin SP2700 .
See Details Here
The StreetPilot 7200 can keep you entertained during your travels, with an internal MP3 player. The built-in MP3 player lets users browse music by artist, album, song, or genre. Music can be loaded onto an SD card and is “drag-and-drop” easy – no special software is required. All music or speech files can be transmitted over the vehicle’s existing speakers, through the StreetPilot’s built-in FM wireless transmitter, The entertainment audio is muted when navigation instructions are given
AnswerID: 283118
Reply By: Skippy In The GU - Tuesday, Jan 22, 2008 at 16:02
Any of the Asus or Hp pda's will do the job, The rx5965 can be brought from $ 400 and it has an inbuild sirf111 gps and Tom Tom installed, you can also add OziCe with your maps from your Laptop onto a SD card , I wouldn't recommend taking it out to sea they aren't waterproof.
AnswerID: 283140
Follow Up By: Bonz (Vic) - Tuesday, Jan 22, 2008 at 23:08
thats my setup but with a Hx9500 and 6 gig on board
FollowupID: 547834
Reply By: Sand Man (SA) - Tuesday, Jan 22, 2008 at 18:32
Jay,
If you want to run OziExplorer you will need a PDA that runs Windows Mobile 5 operating system.
A PDA with an inbuilt GPS like the HP units would be a good choice. These accept SD and CF cards and you load the maps to the card to save on board memory. NATMAP Premium maps are excellent for country wide travel, but you need to run a conversion on the maps to enable them to be recognised by OziExplorer CE, the version that runs on the PDA.
If you already own OziExplorer (it's on your laptop right?) the additional cost for a CE version through the ExplorOz shop is minimal.
For street navigation you will require something like CoPilot Live 6, available from GPSOZ, or TomTom Navigator 6 if you can buy it.
Another option to consider is to enquire with GPSOZ on the suitability of buying the CoPilot Live Pocket PC, which runs windows mobile and then install OziExplorer CE and the maps on it.
The folks at GPSOZ will give you practical advice.
I have both CoPilot Live 6 (running on my PDA) and a TomTom street navigator and I would have to say they compare favourably with each other. The 3D view in TomTom is better than CoPilot but all other features are similar.
TomTom Navigator 6 is available, but only from overseas, which means you would need to buy it with UK or US maps, then buy the Aus maps separately. TomTom UK
The other advantage of TomTom over its competitors is the availability of a wide range of maps for other countries if you are travelling, otherwise CoPilot is fine.
I have just completed a trek using both a laptop running OziExplorer and the PDA as a "backup".
I have now convinced myself the ease of reading the PDA screen (despite its smaller size) plus "tapping" the screen to record a waypoint leaves the laptop operation for dead.
My laptop (Dell Inspiron 6000) appears "washed out" in sunlight and is therefore very hard to read properly.
The PDA was sitting just above the instrument panel, attached to the window and was always easy to read the map.
Just my experiences for your reference.
Bill
AnswerID: 283158
Follow Up By: Bonz (Vic) - Tuesday, Jan 22, 2008 at 23:20
You don't have to have Windows Mobile 5 for Ozi, it will run on Windows CE 2002. Tom Tom 6 is pretty good, I like it, but Co-pilot 6 allows u to route thru a waypoint or predetermined place so I think that better (ish) or just use TT6 to take you to that place then the next etc etc etc
Sounds like you've got a similar setup to me Sandy
FollowupID: 547836
Follow Up By: Sand Man (SA) - Wednesday, Jan 23, 2008 at 09:28
Hi Bonz,
Yes, Ozi will run on various versions of Windows CE or Mobile Operating Systems. I was assuming Jay was maybe going to buy a new'ish PDA and therefore would more than likely be using WM5 or even WM6.
I can't keep myself from "experimenting" to obtain the most practical
"tools" for travelling.
Although I have CoPilot 6 and TomTom Navigator 6 available on the PDA, the practical restriction from running either of these programs and Ozi at the same time has led me to two devices. The programs will run and receive input from the GPS OK (using GPSGate), but I cannot switch between the applications. TomTom and CoPilot both take up the full screen and you can't get at the switcher icon to swap to Ozi, etc. So you need to close down whatever city navigator that is running to see OziExplorer.
Now I run Ozi on the PDA and TomTom on a Go 720 so I can see and operate both at the same time if necessary.
There doesn't appear to be any way to assign the switcher program to a button on the Dell Axim PDA I have, which would overcome the practical restriction.
Bill.
Bill
FollowupID: 547872
Follow Up By: Bonz (Vic) - Wednesday, Jan 23, 2008 at 17:56
mmm GPSGate eh? Got to try that. I have programmed the extra keys on the bottom of the PDA to open TT or Ozi and I can switch between them with these keys or another I have down there that opens like a menu that I can select the running application I want, maybe that just a HP thing.
I also have TT6 and Ozi running on Mobile6 and its not too bad.
FollowupID: 547977
Follow Up By: Sand Man (SA) - Thursday, Jan 24, 2008 at 13:17
Bonz,
Onya Mate!
You have just provided me with the solution I have been seeking.
I too have buttons assigned to Ozi and CoPilot to start the applications, but I never considered also using them once the programs were running. Easy as. Can now swap between them at will and with GPSGate, each application shares a virtual port for the GPS input.
And me in the IT game too.
Sometimes the simple things are just overlooked.
Well done mate!
Bill
FollowupID: 548130
Reply By: barraboy2 - Tuesday, Jan 22, 2008 at 22:22
Jay
Have a look at a Magellan Crossover GPS at www.nextdestination.com.au it might help.
AnswerID: 283212
Follow Up By: Skippy In The GU - Wednesday, Jan 23, 2008 at 00:29
I didn't know you can load OziCe onto the Magellan
FollowupID: 547842
Reply By: John S (NSW) - Wednesday, Jan 23, 2008 at 22:15
Hi All,
We use Imate K-Jams/JasJams with Bluetooth GPS's and CoPilot 6.5 (soon to be 7) and have found this to be a fantastic combination. Just two devices to deal with, and the GPS we use run for 26hrs between charge, so they are great for multi vehicle use.
We travel a lot around NSW & VIC for work and found it to be 99% accurate door to door. Even off road we have found that CoPilot covers around 90% of the tracks we have travelled (but routing on fire trails can be a bit poor) but nether the less capable of getting you in and out without much fuss. The routing optimiser is great for plotting fast 'milk runs'.
I believe that CoPilot will be releasing their Heavy Vehicle version in the near future for Australia (due the massive success in the US).
As far as marine use goes, CoPilot is useless, except for the fact it can act as a standard GPS and direct you from point A to point B via Long & Lat Coords.
Regards,
JohnS
AnswerID: 283439
