Porta Loo problem
Submitted: Wednesday, Jan 23, 2008 at 10:57
Vince NSW
The pump on the Thetford Porta Pottie stoped working on the weekend. Stupid me did not drain the fresh
water tank after the trip before and it looks like we have some alge growing in the flushing
water.
Anyone know how to get the pump out ?
Vince
Reply By: Member - Andrew (QLD) - Wednesday, Jan 23, 2008 at 11:34
I don't believe you can without cutting it on the bellows type....
Check out the pdf files at
Thetford Repair Instructions
283290
Follow Up By: Vince NSW - Wednesday, Jan 23, 2008 at 12:02
Thanks Andrew. from the instructions it looks like you are right.
New pump is the order.
Vince
547903
Follow Up By: Member - Andrew (QLD) - Wednesday, Jan 23, 2008 at 12:16
I might just go down to the garage and check on
mine, now that you have reminded me..... ;-)
547906
Reply By: Sand Man (SA) - Wednesday, Jan 23, 2008 at 17:31
Vince,
Interesting information mate.
I never drain the flushing
water either. I always top it up after cleaning but add about 50ml of Bio Magic to it.
Never known it to grow alge.
I use Bio Magic in both tanks. Gave the original Thetford "poison" the flick long ago.
Maybe I should open the camper a take a squizz at the dunny stored therein:-))
283366
Follow Up By: Vince NSW - Thursday, Jan 24, 2008 at 08:42
Thanks Sandman. Where do I get Bio Magic ?
548101
Follow Up By: Sand Man (SA) - Thursday, Jan 24, 2008 at 13:27
Vince,
Here's reference for the Bio Magic Web site.
NSW RetailersUses (scroll down to Portable
Toilets)
548131
Reply By: meandet - Thursday, Jan 24, 2008 at 08:37
Hi Vince
Our Porta Potti sometimes blocks with algae. Providing that the bellows is not split or something similar, I unblock it by inserting a small length of whipper snipper cord inside the flushing outlet in the bowl and wriggle it around whilst holding a little bit of pressure on the bellows. It has worked several times. Worth a go before you destroy the bellows. Good luck
283463
Thanks for
the tip Peter. I will try it tonight before I cut the bellows out
Vince
548102
