Plastic taste-caravan tanks
Submitted: Sunday, Feb 24, 2008 at 20:59
Emanuel
Hello to all, I have a Jaco van which is 6 mths old and I,am still getting that horrible plastic taste, how can i get rid of it, I was told to put in some Bi-carb but
mine was out of date and it made on differance anyway, can any body help me, Thanks 2-Gee,s
Reply By: Notso - Sunday, Feb 24, 2008 at 22:14
You need to put in heaps of Bicarb, a couple of packets, around half kilo.
Make sure you don't use ordinary garden hose to fill your
tank as it will make the
water taste too. Get the food grade hose if you don't have it already.
Make sure you fill it right up after adding the bicarb to a bucket and dissolving it and pouring it in.
Leave it soak a day or so. Then drain and rinse a couple of times.
289217
Reply By: Sand Man (SA) - Monday, Feb 25, 2008 at 08:14
Milton's Baby Bottle wash is a good solution to clean and deodorize the
water supply system. Cost is about $6.00 from any
supermarket. You will use about 800mm for a 60 litre
tank.
My thoughts are something else is contaminating the
water. Even though still new, the
tank itself shouldn't give that taste.
As mentioned above it is best to use food grade hose to fill the
tank, but more important is that the supply hose from the
tank to the tap is also food grade quality.
Also, topping up the
tank after returning from a trip helps as
289254
Reply By: Go-N-Grey (WA) - Monday, Feb 25, 2008 at 10:35
Had exactly the same problem with my new Supreme, couldn't stomach the
water. Did all the bi carb tricks etc, still was undrinkable.
Problem was $6 plastic hose used to fill it. Leave it in the sun with some
water in it to let it
cook - you then have concentrated plastic cordial. Then fill your caravan tanks and you have the excellent taste......
I also had the same problem with my 75 litre collapsible
water bladder which I lay the floor in the back of the LC. Same taste, different
water container material.
Get a good quality food grade hose, they usually are blue, problem solved.
289268
Reply By: Member - barry F (NSW) - Monday, Feb 25, 2008 at 19:00
If you put a search in "plastic
water taste" between dates of mid Jun & Mid Nov 07 you will get heaps of info. Good luck
289343
