Tom Tom or similar system ifo required
Submitted: Monday, May 05, 2008 at 21:58
Mainey (wa)
GF, has just installed a Tom-Tom into her 4by and it works a treat in town, giving speed and distance to probably any place she needs.
question: as it's only $299 is there a more sophisticated model or brand that gives more detailed information about the WA and NT coast line area??
What are their pitfalls (if any) and what brands have a 'bad' name etc...
Mainey
Reply By: Peter McG (Member, Melbourne) - Tuesday, May 06, 2008 at 03:37
Reply By: traveller2 - Tuesday, May 06, 2008 at 08:26
I bought one of these
http://cgi.ebay.com.au/BN-4-3-BLUETOOTH-GPS-NAVIGATOR-NAVIGATION-PLAY-MP3-MP4_W0QQitemZ300221972628QQihZ020QQcategoryZ34288QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
It has a 4.3 screen, uses Win CE 4.2 OS so will run the latest Oziexplorer CE version, bluetooth h/free, a/v input for reversing camera (can flip the image etc), plays mp3's & 4's, video's, uses a standard Nokia battery which can be easily changed, 20 channel receiver, has an external GPS antenna connection, headphones,etc etc quite amazing for just over $200 inc postage.
The nav software supplied (route 66 & another which I've forgotten) works
well with warnings for red light, speed camera and thousands of POI's. Very quick with rerouting and alternative
routes if you miss a turn and seems to remember your preferred route .
Great unit, no connection to seller etc etc.
302272
Reply By: Sand Man (SA) - Tuesday, May 06, 2008 at 10:39
Mainey,
I have a TomTom 720 and for metropolitan use it is excellent as an electronic "street directory" with verbal directions included.
I have only trialled it in the country on the
York Peninsula and it shows the roads, but not much other detail. You cannot save the trip as a route and cannot record waypoints along that route.
For Country wide use in the more remote areas and with the ability to record (and optionally save) route and waypoints, I would recommend a PDA running Oziexplorer with NATMAP Premium, or similar loaded. This will give you a detailed electronic display as you would expect from a good road map, but with the addition of a constantly moving map as you travel.
A further option with a PDA, is the ability to load the TomTom or CoPilot applications and run them concurrently if you are looking for a single piece of hardware.
A more "proprietary" solution but still similar to a PDA/Ozi/CoPilot would be a Garmin Nuvi plus "accessories" and Doug would be the man for this option.
Personally, I prefer the "street directory" and "road map" functions to remain separately controlled and viewable on different devices although this requires a higher cost outlay.
A good site to research is
GPSOZ as they are retailers for all the main brands of hardware and software and will give sound advice, once you known what you are focussing on.
Bill.
302295
Reply By: Mr Fawlty - Tuesday, May 06, 2008 at 14:10
Basically these things have two internal systems that must interface perfectly... The Mapping software must engage perfectly with the Navigation Software..... From experience I found that the "route 66" mapping was superiour to the sensis mapping outside the metro areas.... Not that that helps at all but if you want electronic mapping then perhaps "Track Ranger" is what you need.
I bought an elcheapo off Ebay with a HUGE screen for $199 with route 66 maps and Navmate Pro navigation (and that part of it is on an SD card so can be updated easily via CD without having to plug your navigator into your PC... so if you get my drift you only need 1 CD to update all the Navigators you own). This gizmo finds roads that don't exist anymore...
302324
