Making mantles last
Submitted: Tuesday, May 20, 2008 at 00:30
nickb
Are there any tips/tricks in reusing or making a mantle in a gas lantern survive a road trip?
I used
mine for one night, packed it away in bubble wrap and when i went to use it the next night after going for a drive during the day is had broken off. This happened again to the next mantle I used aswell.
It is the first gas lantern I have used so any advice would be appreciated.
Reply By: Skinnydog - Tuesday, May 20, 2008 at 01:40
NickB,
After everything has cooled down, remove the glass and spray the mantle with hairspray. Makes them last a lot longer.
Hope this is useful.
304796
Follow Up By: RosscoH - Tuesday, May 20, 2008 at 07:09
Always had the same trouble, be carefull with it, pack it
well, it was always broken when we went to use it, resigned myself to the fact that this was going to happen every time so just started to treat it the same as all the other gear, no special treatment and haven't broken one since.
570849
Reply By: Krakka - Tuesday, May 20, 2008 at 05:07
Have heard the above works, also when you pack it in the car try to pack it central, not right in the back of the car. More central in the car is less
suspension reaction. If that makes sense. On a ship, the middle of the ship is the best place to be if you suffer from sea sickness as there is less rolling motion.
Cheers Krakka
304797
Reply By: Member - Footloose - Tuesday, May 20, 2008 at 06:22
Always repack your mantle in its original packing box , and sit it on top of something soft.
304798
Follow Up By: Richard W (NSW) - Tuesday, May 20, 2008 at 06:51
Nick,
Its also worth replacing the glass enclosure with a stainless steel gauze enclosure either now or when the glass it breaks.
570846
Follow Up By: Twinkles - Tuesday, May 20, 2008 at 07:36
Hey Nick,
Do you mean instead of glass permanently? Where do you get these?
570851
Follow Up By: Richard W (NSW) - Tuesday, May 20, 2008 at 07:42
Twinkles,
I think most of the
camping shops now sell them. Got
mine from KMart though.
570853
Follow Up By: Michael ( Moss Vale NSW) - Thursday, May 22, 2008 at 08:32
Big W have a full range of the Stainless shields and they are great. I broke so many glass shields, it wasnt funny, and always break the mantle.. The stainless unit does not give out the same light as a clear glass but is better than the frosted glass, in the middle somewhere, It is the best thing you will do. Many people are coming back to gas lamps now as they are finding out that the recharable lights batteries have limited life if you flatten them too many times.. Nothing like the sound of a mantle lamp anyway!! Michael
571223
Reply By: Sand Man (SA) - Tuesday, May 20, 2008 at 10:49
The only solution I can offer Nick, is to replace the gas lantern with a Versalite, or the EvaKool Torpedo 12 volt fluro.
I experienced a similar problem to you. The original mantle seemed to last ages but subsequent ones, not very long.
Maybe it had something to do with more off road travel where corrugations have a higher impact.
I changed over to 12 volt lighting and haven't broken a mantle since:-))
Bill.
304825
Reply By: ExplorOz - Tuesday, May 20, 2008 at 11:23
We now have converted everything to 12V lighting however I used to be able to get mantles to last for weeks of travel by packing the lantern standing upright. I used the original box and simply took the lantern off the bottle and placed it in the box upright, the box was packed so that it would not move (in with clothes, towels and bedding) however I am sure it was the standing upright that ensured the mantle stayed intack.
See how you go.
David
304834
Follow Up By: Rocky_QLD - Wednesday, May 21, 2008 at 07:34
Ditto that David
Our gas mantles now last for ages since we started transporting them the lamps in the normal upright position.
Rocky
571020
Reply By: darcla - Tuesday, May 20, 2008 at 14:41
Have been through all this for years . The only solution that I have found is to buy Companion branded mantles & they will last for weeks on the roughest roads that you can imagine. Kookaburra brand rarely last a night & if you have a glass will break them as soon as a hole appears in mantle . Definaetely reccommend the stainless steel mesh instead of glass does cut back on light a little but fantastic.
304862
Follow Up By: darcla - Tuesday, May 20, 2008 at 16:53
I think i muffed it there I meant Coleman, mate went from
Perth via
Talawana track Rudal river
Marble Bar Coral Bay , back to
Perth on 1 mantle thats why I now use them. I might add in the back of a Troupie.
570915
Reply By: equinox - Tuesday, May 20, 2008 at 14:51
Hi nickb,
If a mantle lasts for more than one day on my trips then I'm on a winner.
I always pack one mantle per day.
304864
Follow Up By: Member - Ian W (NSW) - Tuesday, May 20, 2008 at 16:05
Some people to seem to go O.K. with mantles and others have no end of trouble.
Yes! I've done the hairspray bit and no longer bother cause I don't experience the problems some others seem to do.
I use only Coleman brand mantles, always pack the dual fuel lantern back into the original carton. The gas lamp I remove from the bottle and again, back into the original box. They are always packed upright, never on their sides and travel in the front storage box on my off-road tent trailer over pretty rugged terrain.
The only time they seem to need replacing is when they eventually burn through on one side.
Ian
570907
Reply By: nickb - Tuesday, May 20, 2008 at 17:40
Cheers for the quick replies!
It was packed lying on its side so maybe that was the problem. I already have some 12V lights, I wanted to try the gas lantern. Seems to put out heaps of warm coloured light.
What is the reason for changing the glass enclosure to a mesh enclosure? I have been told my glass enclosure won't last very long and I should expect to change it occasionally because they are a consumable item.
Will have to try the Coleman brand mantles, not sure which brand the
camping shop provided me with.
Nick
304900
Reply By: Member - John L (WA) - Tuesday, May 20, 2008 at 18:52
We cut off a section of PVC
water pipe that just fits over the lantern glass, leave mantle on,wrap all in bubble wrap, pack into original box & store upright in camper trailer storage boxes - sounds excessive but have done WA - Qld -WA return on all types of roads & not broken one! In fact present mantle so old can't remember brand. Cheers
304913
Reply By: tonysmc - Tuesday, May 20, 2008 at 20:47
Nick,
about 20 odd years ago I did a trip to
cape york with a few other cars. Each night we would get out our lanterns and
mine was the only one that had survived the day. None of us could work out why, we looked at storage packing, etc and even tried putting their laterns in my car to no avail.
Then one night I was watching them put in a new mantel and light it up and I said "dont you burn them first?" as thats what I was told to do. "No, whats that?" they all said. So I showed them that you attach the mantel and light it with NO GAS on and let it smoulder away until the whole thing has burnt (may need to do this a couple of times.) Then once it had cooled down it is ok to light.
I have no idea why this works, however this was the way my father showed me how to do it and it seems to work. Their and my mantels still broke , however they lasted a hell of a lot longer than one day.
Cheers Tony
304952
Reply By: Member - Roger B (VIC) - Tuesday, May 20, 2008 at 21:11
Nick B. I pack my gas lamp upright in an old plastic flower pot after wrapping it all in foam first. Hair spray seems to help. It's very important to buy the proper mantle for the lamp too.The cheapies don't last, fall apart, especially if they're the string tie type, the string snaps. Also the cheap ones stink when burning in. I read an article some years ago about the cheap imports from India being quite toxic. The above works for me. Cheers.
Roger B......
304963
Follow Up By: nickb - Tuesday, May 20, 2008 at 21:30
The ones I've been using have the string, they are the ones they gave me when I got it. Shouldn't really be surprised should I?!
570973
Reply By: trains - Wednesday, May 21, 2008 at 11:31
Regarding the hairspray.
We did our central trip for almost 4 weeks over all sorts of terrain and road conditions.
Old 242b coleman lantern, sprayed mantle with hairspray before pre burning it.
Lasted the whole trip.
Been doing this since the Tilley lamp days, and have had a great run out of mantles, far better than those who dont do this.
Trains
305043
Reply By: Member - Warfer (VIC) - Thursday, May 22, 2008 at 03:59
The guys using the hairspray usually tie down the Lantern with there fishnet stockings !
305202
