Adapting Stainless BBQ Grill
Submitted: Tuesday, May 20, 2008 at 10:40
ThreadID: 57797 Views:1888 Replies:3 FollowUps:2
Somehow I have ended up with two stainless steel grills that won't fit my home barbecue, so I've turned my mind to how I might use one for camping.
I already have a solid steel plate for camping - it has nuts welded in the underside corners and, when in use, I screw in a set of 10" bolts as legs.
Has anyone done something similar with a grill? - keeping in mind that this one is stainless and made from bar - ie no flat surfaces. Ideas?
Spliney
Reply By: Sand Man (SA) - Tuesday, May 20, 2008 at 11:07
Spliney,
It should be easy enough to weld some nuts to the "underneath" side of the grill. Just a matter of using stainless rods on an arc welder, then you can use similar (stainless) bolts to screw in to the nuts.
Bill.
Bill
AnswerID: 304830
Follow Up By: Sand Man (SA) - Tuesday, May 20, 2008 at 11:11
Another option, if you didn'[t want to weld the stainless, would be to make up a rectangular frame make out of "angle iron". This could be from mild steel, or stainless steel angle if you wish to match the grill. Then weld the nuts to the underside of the frame and simply drop the grill into the frame.
Bill.
Bill
FollowupID: 570877
Reply By: Dirty Smitty - Tuesday, May 20, 2008 at 11:18
Or you can mig weld mild steel nuts to the stainless steel grill.
AnswerID: 304833
Reply By: Hairy (NT) - Tuesday, May 20, 2008 at 22:33
Gday,
Dont be scared of stainless...
Any thing you can do with mild steel you can do with stainless.
Just use stainless rods or wire.
You CAN weld stainless to mild steel but use a stainlees rod, not the other way around.
AnswerID: 304979
Follow Up By: spliney - Wednesday, May 21, 2008 at 07:54
Thanks all - I have a couple of ideas to work on now.
Much appreciated
Spliney
FollowupID: 571022
