Horrible tasting Water
Submitted: Friday, Jun 20, 2008 at 19:54
arofs1
We bought a new van in 2001 and have traveled around much of Australia including all states. I read several caravan forums and often read about people with poor tasting
water in their tanks. I know filling from a
water hose causes bad tasting
water, but I am pedantic with things like that and always fill ours with
tank water through a short syphon hose, so I knew the problem was something different. We have never had that problem until recently and when I looked at the plastic piping and
tank found a lot of mould growing inside the pipes and I suspect the
tank also.
My remedy to fix the problem was to go to
the pool shop and add about 2 litres of chlorine to the
water tank. I then cut a length of pipe to go from the
hand pump in the sink to the inlet
water filler pipe on the outside the van. As I have previously installed an electric Whale pump in
hand pump sink pipe line I was then able to pump heavily chlorined
water through the pipes and back into the
tank several time a day for a couple of days. An inspection of the plastic pipes now showed them to be crystal clear again and the
water taste is also fine again.
I am sure this is not the only way to solve poor quality
water problems, but it worked for me and I thought someone else may also get some benefit from my experiences, as
well as realizing that others may have used the same or similar methods
well before me.
Brian DJ
Reply By: Member - Mark G (NSW) - Friday, Jun 20, 2008 at 20:27
arofs1; go and see any good caravan place or someone who sells
camping gear and buy tablets that go in your
tank that stops the growth in your
tank.cant think what they are called but someone on the
forum will know the name of them.
311295
Reply By: Member - Redbakk (WA) - Friday, Jun 20, 2008 at 20:31
Thanks mate.....I was wondering how I was going to tackle that job...duly noted.
311296
Reply By: motor_head - Saturday, Jun 21, 2008 at 00:59
Also arofs1, drain and flush your
tank after every trip, then flush again before you refill for the next trip, i have never had the problem you described (maybe because thats what i do) but doing that may help.....i dont know if it will but its something to experiment with.
311343
Follow Up By: Member - Graham H (QLD) - Saturday, Jun 21, 2008 at 07:46
Get some
Tank Kleener Camec distribute it. Available at most
camping stores Just follow instructions.
577365
Reply By: MEMBER - Darian (SA) - Saturday, Jun 21, 2008 at 10:16
I keep
mine full as a goog with tap
water in between trips - no air - no light -
Adelaide water having about 30ppm CL may have something to do with it too but :-o).
311395
Reply By: Sand Man (SA) - Saturday, Jun 21, 2008 at 10:39
Brian,
If you can "see" mould in the piping, the chances are you have the wrong type. All piping should be food grade plastic which is not "see through. This tubing will inhibit the intrusion of light and thus mould growth.
Bill.
311404
Reply By: Member - Duncs - Sunday, Jun 22, 2008 at 10:52
I carry
water in 20l jerry cans and have never had a problem.
Also if I get a leak I only lose a portion of my
water supply.
Too simple really.
Duncs
311589
