Static electricity and refuelling?
Submitted: Saturday, Jul 12, 2008 at 19:56
Member - V8Diesel (WA)
further to a previous post, I thought I'd start a new one on this topic so it's easy to find in a search.
If I am filling a steel 44 gallon (205l) drum on the back of a ute or trailer, exactly what should I earth and to where?
I was thinking about running one of my jumper leads from a scraped bare metal section of the drum down to a copper rod pushed in to the ground where possible or jammed under the tyre. That's how I used to earth generator trucks and it was considered standard practice at the time.
I am assuming the pump and nozzle are earthed and the flow wont build up a charge as otherwise we'd all be in strife.
I know in helicopters they clip a earth strap on to the airfarme first.
I should also point out I must have put at least 30,000 litres of fuel in 44's at one time or another without a problem.
On another note, two of us used to lock fingers and lift full 44's up on to the back of HJ75's. To get them down we'd just dump them off the edge on to 7.50 x 16 tyre. That's why I'm a cripple now I guess.
Reply By: Member - Graeme W (NSW) - Saturday, Jul 12, 2008 at 20:24
When I worked on helicopters, the copper rod into the ground or the earth lead from the aircraft under a skid was generally accepted practice when away from base and nothing else was available. A nearby drainage grate could also be used if available, to clamp the earth lead to.
Procedure was: aircraft to ground, tanker to ground, tanker to aircraft. The person carrying out the refuel would dissipate any static from themselves through this process, simply through connecting the earth leads to ground.
I would think the process you've described above would be more than adequate for fuelling drums.
I would assume though that vehicles could still build up a fair bit of static, so it's better to be safe than sorry.
As an example, if the rescue sling from a helicopter was lowered to you and you simply reached up to grab it, you would quite possibly find yourself sitting on your backside from the static build up jumping to your outstretched hand. Letting the sling touch the ground and standing on it would dissipate the static.
Graeme
315014
Reply By: Member - Kiwi Kia - Saturday, Jul 12, 2008 at 20:29
The potential problem is a static discharge between the fuel hose nozzel and the drum at the filling point. If you "BOND" the drum to the hose at some place away from the filling point then there will be no spark in that critical area where there is a high concentration of fuel vapors. Although it is called an earth it is actually just ensuring that there is an equal potential on the drum and the hose.
315016
Follow Up By: Member - Graeme W (NSW) - Saturday, Jul 12, 2008 at 20:35
You're right, Kiwi. I should have mentioned that in my reply above. Anywhere there's vapour is going to be the most dangerous point.
581110
Reply By: Member - Axle - Saturday, Jul 12, 2008 at 20:42
Mate, not sure what the answer is!!, All i know is our fuel supplier years ago used to carry 44s of petrol , diesel, engine oil ,on a 8 tonne table top, for years!, used to bowl them off the side no worrys. They carry on with unbelievable issues now that probably will never happen. what the real problem is i think is litigation if something where to happen, Its just the modern world we live in!...lol
Cheers Axle.
315020
Follow Up By: Member - Paul C (NSW) - Saturday, Jul 12, 2008 at 21:24
I've seen a few videos of static discharge in servos. It Happens.
Filling multiple 44's and having a static charge ignite a known fuel source is not a situation I would want to be near.
Simple fire triangle is Fuel,Heat and Oxygen, the more fuel the greater the fire. Remove any one of these and you have eliminated the fire. Remove the chance of the static ignition in the first place and you are a lot safer.
I had a Navy fitter tell me once how he used to knock the top off oxy bottles and use them like torpedos. Showed him a video of an oxy/acetylene delivery truck blown to smithereens with parts of the driver strewn over a half k radius. It made him think how lucky he was!
Carry on is hours or days of paperwork to do a five minute job, and I agree, it happens.And it can suck.
In this case a simple strap between 44 and nozzle would take bugger all time and effort and save a world of heartache both for the filler and anyone unlucky enough to be at the servo at the time.
Just my 2c
Paul
581133
Reply By: DIO - Saturday, Jul 12, 2008 at 21:47
Most (probably all) Service Stations that I patronise have very conspicuous signs prohibiting the filling of drums on trailers, drums in the back of cars (vehicles) drums held off the ground whilst filling etc ALL for the reason of STATIC ELECTRICITY. If the container is not earthed/grounded then it is possible that it could earth back through (onto) the nozzle or user.
315031
Follow Up By: Shaker - Saturday, Jul 12, 2008 at 22:59
Maybe they should provide earthing points! (Too logical?)
Or ..... help lift the 44 back into the vehicle.
581155
Reply By: Member - Lionel A (WA) - Saturday, Jul 12, 2008 at 23:23
Again I pose the question, if refuelling a vehicle which is not earthed [and most of them dont appear to be] then where is there any more risk in filling a container on the vehicle ?
Just something I have been pondering for ages.
Cheers.....Lionel.
315045
Follow Up By: Member - Paul C (NSW) - Saturday, Jul 12, 2008 at 23:42
Lionel
A bloody good question which I hadn't given any thought to until now.
Most modern vehicles have a spring loaded inner cap in the filler neck which should maintain constant contact with the nozzle which should provide equipotential bonding whilst filling.
Someone out there must have more to add!
Paul
581164
Follow Up By: Sand Man (SA) - Monday, Jul 14, 2008 at 14:02
I believe that providing the fuel source (jerry or container) and the vehicle being filled have a common earth potential, you are safe.
I use a "Tanami pump" to transfer fuel without removing the jerrycans from the trailer. I simply ensure they are earthed to the trailer, which in turn are earthed to the vehicle via the safety chains to the towbar and thus the chassis and therefore provide a common earth potential.
I used to connect a jumper lead from the jerrycan to the vehicle until I confirmed the safety chains provided a sufficient earth path.
The jerrycans sit in a rack, but are insulated from the trailer by rubber cushions, so I use a length of chain to secure the jerrycans in their racks. This provides both a security link (padlocked) and an earthing path to equalise the potential between the jerrys, trailer and vehicle.
The common earth path can be checked with a continuity tester.
Bill.
581391
Reply By: Member - V8Diesel (WA) - Sunday, Jul 13, 2008 at 08:55
OK, what if I just dragged the nozzle on a bare metal part of the ute / trailer, then did the same thing on the drum. Surely that would dissipate any static charge? Even just touching everything first should do it.
As I mentioned earlier, I have filled countless 44's on the back of utes in all conditions. You'd think if it couldn't build a charge travelling 1,000km's in dry desert winter air, then it wouldn't do it.
While I'm thinking about it. What about detonators? I've lugged heaps of them all over the place too and you just pick them up. Surely that would be a prime case for static discharge danger. You can't use two way radios anywhere near them by law, but I've never had to carry an earth strap in the vehicle.
Hmmmmmm..........the obvious question still remains - what is the difference between filling a drum on a vehicle and refuelling the vehicle itself? I've had plenty of static 'zaps' from cars. I had a Fairlane that was notorious for doing it.
315069
Follow Up By: Mike Harding - Sunday, Jul 13, 2008 at 09:29
The problem is... you have to be right every time... the static only has to be right once.
A post above raises the valid point of the vehicle not being earthed and he's quite correct but usually when the driver alights from the vehicle he discharges the static to earth through his body - if it's a high charge you'll feel the familiar Zap! If the drum is sitting on a mat in the ute it may not be discharged
There have been a number of petrol station fires in the USA caused by static, some have been shown to be due to women getting back into the car for their handbags which charges them up again, when they get out and touch the filler area a nice spark jumps across between the vehicle and their fingers through all that petrol vapour = boom.
When I fill up, I get out of the car place one hand flat on the paintwork above the filler area and the other on the metal of the pump nozzle (whilst the nozzle is still on the pump) I then pick up the nozzle by the plastic handle and fill up - easy, quick, simple and safe. You could do the same with the drum.
Mike Harding
581191
Follow Up By: Dave(NSW) - Sunday, Jul 13, 2008 at 09:51
It's the static from the fuel dropping into the drum you have to worry about, That's why you should use an earth strap.Fuel flows into your car down a filler pipe and doesn't create as much static so filler nozzle is enough earth.
Dave..
581197
Follow Up By: Member - Paul C (NSW) - Sunday, Jul 13, 2008 at 18:20
I could be wrong here but the charge of coulombs is built up whilst the flow of fuel is at high levels. ie whilst being pumped.
A lower flow would not be able to build up enough charge to create a spark between materials at different potentials. The charge would be dissipated relatively quickly once the trigger is released.
A good example of this is "sucker" trucks which vacuum dust through suction hose with reinforced metal spirals. Exposed metal can give a shock whilst suction is present with dust flowing. Turn off the suction and you will not get a shock because the friction required to provide enough coulombs to create a spark is negated.
I have spent hours tracing circuits to find the cause of electrical shocks only to find exposed metal spirals in a suction hose is the only likely culprit.
581271
Reply By: Member - Shane D (QLD) - Sunday, Jul 13, 2008 at 10:15
This is what the worry is about.
Drum fireThe static electrictric lady.
The static electric man (NO sexism here).
Adding to what has been, said I think the problem is if you let go of the pump, move around and grab the pump again, this is what causes the problem,Thats why now we have to stand there holding the trigger with our hand.;
I filled 2 44's in the back of my ute and servo owner told me that I must grab the drum and the bowser's metal frame to discharge any static build up.
Shane
315080
