Battery Solar charging order Question for Solar Gurus
Submitted: Thursday, Jul 17, 2008 at 09:33
ThreadID: 59850 Views:4221 Replies:6 FollowUps:15
I have a dual battery ( main and Aux) set up with ARB isolator in the fourby and a third battery in the trailer which is currently connected to the Aux via an anderson plug. While I am on the move all is fine.
I am about to add a solar panel and while stationary I would like to set it up so the solar panel automaticaly charges and maintains the trailer's battery first, then the aux in the 4wd only after the trailers battery is full or near full. Opposite for discharging, drain the aux on the fourby first then the trailers battery.
Is there a solar regulator / set up or similar on the market than can do this. I can do it manually but would love a system that is automatic.
Reply By: Boobook2 - Thursday, Jul 17, 2008 at 09:36
Oops double post because the first time it said server aplication not available.
AnswerID: 315728
Reply By: Affordable Batteries & Radiators - Thursday, Jul 17, 2008 at 10:58
Easily done.
Simply fit a automatic isolator to the trailer battery. (Opposite to a normal dual battery system). This would require a 2nd Anderson plug or similar manual switch to swap the normal charge circuit coming from the car to the OUTPUT of the isolator when you connect the solar panel. I would simply have 2 plugs on the draw bar. 1 for charging when you drive and one for solar.
Derek.
AnswerID: 315738
Reply By: Boobook2 - Thursday, Jul 17, 2008 at 12:02
Derek that is kind of where I started thinking. The issue I think this has compared to what I want is that with say 100 W of solar panels, I get about 5A charging current at best. I would like that all to go to the trailer's battery ( untill it is full) on the basis that the vehicle's aux battery will get charged by day trips anyway. After the trailer battery is full, then charge the vehicle aux battery for extended periods when I don;t drive anywhere. I am pretty sure what you described will give about 1/2 of the charge to the vehicle aux battery and half to the trailer's battery, assuming similar batteries, fine for 100A or so of alternator capacity, but sharing a thin resource from solar. Am I making wrong assumptions?
I think rotronics make an isolator / charger that charges one battery at a time but their web site is petty hard to navigate / understand.
I think some marine set ups do the same thing for house / starter batteries.
AnswerID: 315744
Follow Up By: Affordable Batteries & Radiators - Thursday, Jul 17, 2008 at 15:57
The problem you will have is that your battery will never really be full on the camper and the charge curve will drop down to 1 amp for the last few hours and then the sun will go down before you can switch. You would be best to use those batteries as a bank and the panel can push its full 5A into the bank. The method I described at first would switch at 13.5V and then charge both batteries in parallel. This would utilise the full power that the panel can give you.
If you have a lot of money to spend on this project there are devices that can be used but I would not spend too much in this system.
FollowupID: 581958
Follow Up By: Affordable Batteries & Radiators - Thursday, Jul 17, 2008 at 16:26
Using a automatic isolator controlling a 30A double pole relay you could get the switching you are after. When the camper battery is below 12.5V it will charge on its own until 13.5V at which time the isolator will kick in and energise the relay which will divert the power to the car. When the camper battery drops below 12.5 the isolator will switch off and the relay will return the power to the camper battery.
FollowupID: 581961
Reply By: Boobook2 - Thursday, Jul 17, 2008 at 17:03
I just found this which I think does what I want.
http://www.morningstarcorp.com/products/SunSaverDuo/SunSaverDuo.shtml
It will charge the second bank when the first is 90% full. ( programmable).
I will also have a think abou t your last comments which might do what I want. Thanks
AnswerID: 315780
Follow Up By: Affordable Batteries & Radiators - Thursday, Jul 17, 2008 at 17:17
It is a parallel system not switching. I have seen this unit.
The 50% / 50% priority setting splits available charge current equally between
two battery banks. This priority setting is ideal for systems with two equal-sized
battery banks that require simultaneous charging. If one battery bank reaches full
charge before the other, more charge current will be diverted to the lower stateof-
charge battery.
DIP Switch 3 OFF: 90% / 10% Priority (factory pre-set)
DIP Switch 3 ON: 50% / 50% Priority
FollowupID: 581970
Follow Up By: Boobook2 - Thursday, Jul 17, 2008 at 17:53
Derek, looks like it is just you and me.
It simialrly says the following.
For the 90/10 setting is says "The 90% / 10% priority setting allows Battery #1 to receive 90% of available charging current, while Battery #2 receives 10% of charging current. This setting
is ideal for RV and boat systems where a “house” bank requires most of the available charge current and a separate engine starter battery requires only a “trickle charge” to remain topped-off. When Battery #1 reaches full charge, more charge current will be diverted to Battery #2 as needed."
Isn;t this kind of in parallep at 90/10 or 50/50 until one battery is full then it will go over to the other.
If I make the Trailer battery the 90% that sounds similar to what I want yeah?
FollowupID: 581981
Follow Up By: Affordable Batteries & Radiators - Thursday, Jul 17, 2008 at 18:24
Yes if you did not draw any power off battery #1 and then it started to push more current to battery #2 great. The problem is that this may not happen in a camping situation off a 100W panel. The system is good but I would not expect to get more then 1 amp going to the car unless the camper battery is full and you don't use it. (No radio, pump, fridge, lights). Even a few minutes using one of these items would decrease the chance that the car would get any more than 10% in any given day.
I do like the system and the remote head too but it is not ideal at the cost.
FollowupID: 581985
Follow Up By: Boobook2 - Thursday, Jul 17, 2008 at 18:45
hmm I think that is a good point about the use as you go during the day.
Actually while looking at all of this I came across a MPPT charger. Several references to these talk about them being constant power instead of constant current. Ie instead of getting about 70W out of a 100W panel ( ie say 6A at 13.8V instead of 6A at 18V) you get about 8A at 13.8V or 9 at 11V. It achieves this by going DC - AC - DC internally and can generate more amps at the output than the input in the same way as a transformer can. They have 95 - 100% efficiency.
This is like getting 30% extra solar panel for not much more cost.
Do you have anything like that Derek?
FollowupID: 581992
Follow Up By: Affordable Batteries & Radiators - Thursday, Jul 17, 2008 at 18:54
Have you got a link ?
FollowupID: 581995
Follow Up By: Boobook2 - Thursday, Jul 17, 2008 at 19:20
Take a look at these
They are called MPPT or Maximum Power Point Tracker regulators
Pretty good description of how they work and benefits
Morningstar MPPT
I have even seen some that can charge 24V systems from 12v.
They seem to be a DC - DC converter that always tracks the peak power output of a solar panel in any light condition, and has a 4 stage regulator built in.
FollowupID: 582007
Follow Up By: Ozboc - Thursday, Jul 17, 2008 at 19:24
i may have a 80 watt solar panel for sale if you in the sydney area - i have used it maybe 5 times - selling as i am upgrading to 160 watt system
Boc
FollowupID: 582009
Follow Up By: Boobook2 - Thursday, Jul 17, 2008 at 19:25
Also here is a description from a different company called blue sky.
How Do Solar Boost™ Controllers Increase Charge Current?
Solar Boost controllers increase charge current by operating
the PV module in a manner that allows the module to produce
all the power it is capable of. A conventional charge controller
simply connects the module to the battery when the battery is
discharged. When the 75W module in this example is
connected directly to a battery charging at 12 volts its power
production is artificially limited to about 53 watts. This wastes
a whopping 22 watts or nearly 30% of the available power!
Patented MPPT technology used in Solar Boost controllers
operates in a very different fashion. The Solar Boost controller
continually calculates the module’s maximum power voltage,
in this case 17 volts. It then operates the module at its
maximum power voltage to extract maximum power. The
higher power extracted from the module is then provided to
the battery in the form of increased charge current. In
conditions where extra PV power is not available, Solar Boost
controllers will operate as a conventional controller with very
low voltage drop.
The actual charge current increase you will see varies
primarily with module temperature and battery voltage. In
comfortable temperatures, current increase typically varies
between 10 to 25%, with 30% or more easily achieved with a
discharged battery and cooler temperatures. What you can
be sure of is that Solar Boost charge controllers will deliver
the highest charge current possible for a given set of
operating conditions.
Waddya reckon?
FollowupID: 582010
Follow Up By: Affordable Batteries & Radiators - Thursday, Jul 17, 2008 at 20:07
Great but how will you switch between batteries.
I will give it some thought.
FollowupID: 582022
Follow Up By: Boobook2 - Thursday, Jul 17, 2008 at 21:05
Dunno, and after your post 3 of 9 I am not sure that what I am trying to do makes sense. I have to apply some Vintage Port thinking juice to the problem.
FollowupID: 582025
Reply By: Sand Man (SA) - Thursday, Jul 17, 2008 at 21:56
The problem as I see it is regardless of how efective the method of connection and the use of another Isolator, the chances are that you would probably have a fridge in the circuit and with around 5 amps coming from the solar panel, you probably won't achieve that point where the trailer's battery has received sufficient charge to enable the isolator to cut over to the vehicle's auxiliary battery.
Bill.
Bill
AnswerID: 315831
Follow Up By: Affordable Batteries & Radiators - Thursday, Jul 17, 2008 at 22:03
Unless you switch the load.... but now it's getting too complicated. We don't know the load at this point.
FollowupID: 582038
Reply By: Mainey (wa) - Thursday, Jul 17, 2008 at 23:44
Questions that require answers first:
(1) What Brand, type and size are each of the Auxiliary batteries your using ?
(2) Where will you have the Solar panel situated when working ?
(No, the answer's not "it's in the ###### sun")
(3) Do you use a Solar regulator, (what brand & model is it) ?
(4) What current is being drawn from EACH Auxiliary battery ?
(5) are you prepared to get an extra Solar panel ?
Mainey . . .
AnswerID: 315850
Follow Up By: Boobook2 - Saturday, Jul 19, 2008 at 06:51
Mainey
Wet cell Deep Cycle in the fourby Aux, ?? in the Van, probably similar for charging reasons
Usually portable up tp 10m away, unregulated leads.
That is the $64,000 question. I want one that splits the charge as described but now have MPPT as a must have feature.
3way fridge mostly during travel plus lights and 2 way fridge, say 1- 4 A when stopped.
Yep I dont have any now, and am thinking of 2 x 85W
FollowupID: 582242
Follow Up By: Mainey (wa) - Tuesday, Jul 22, 2008 at 10:39
(1) The problem you will have is the very slow charging time of a wetcell Deep Cycle battery by solar power in comparison to AGM batteries!
AGM DC batteries are recommend as they charge much faster and are the only battery type recommended for Solar charging.
(2) No problems here with the "lead" - BUT will require a Solar Regulator adjacent to the (actual) battery for best results.
(3) I would use a manual switch over system between the batteries, unfortunately as your batteries are placed a long distance apart, the effectiveness is limited to the closest battery to the Solar Regulator.
(4) Refrigeration would probably draw ~12ah to 15ah (Amp Hour) when the 3 way fridge is not running on gas or your travelling, so that has to be replaced in a 'day'
The two x 85ah Solar panels combined will give ~11 or ~12 Amps max for only the "peak" day light hours.
(5) Get a quality brand solar panel that gives good max rated power and one that will also work in low light conditions, this gives longer charging times per day, therefore gives more amps per 'day' than elcheapo solar panels will supply to the batteries.
Mainey . . .
FollowupID: 582786
