Fishing rods.
Submitted: Thursday, Jul 24, 2008 at 18:46
jodie0075
Hi all , just wondering if anyone has some good tips on the best way to carry fishing rods on a trip. Doing a trip to the NT soon and dont want them getting caught up etc in any other gear,also not to go missing. Have a couple of ideas but would love some suggestions.
Reply By: sweetwill - Thursday, Jul 24, 2008 at 18:56
hi jodie0075
when i travel my rods go into pvc pipe with screw ends on them then a small padlock to keep the honest people out cheers bill
316977
Follow Up By: jodie0075 - Thursday, Jul 24, 2008 at 19:33
Thanks Bill, that was one of ideas i was thinking of.
583322
Reply By: Sand Man (SA) - Thursday, Jul 24, 2008 at 19:10
Yep,
If I'm going fishing seriously, a 100mm PVC pipe with reinforced ends holds my range of rods. The "bazooka" ends are lockable which secures the rods from the opportunist thief.
If I'm only taking a couple, they are usually mounted inside the vehicle, along the roof lining and attached to the grab handles fore & aft with velcro straps.
Bill.
316978
Follow Up By: jodie0075 - Thursday, Jul 24, 2008 at 19:39
Hi ,will only be taking a couple of rods and like the velcro idea. Might even try to velcro mount them on the top of the canopy inside. cheers.
583324
Follow Up By: Sand Man (SA) - Thursday, Jul 24, 2008 at 20:08
Hi Jodie,
You can get the velcro straps from Dick Smiths. They are made for cable strapping and are about 5-6 inches long.
Bill.
583339
Follow Up By: gav99x - Friday, Jul 25, 2008 at 10:23
"If I'm only taking a couple, they are usually mounted inside the vehicle, along the roof lining and attached to the grab handles fore & aft with velcro straps."
ditto
583431
Reply By: swampy460 - Thursday, Jul 24, 2008 at 20:23
I to carry
mine in a 100mm pvc tube, but I've got this theory that if you put a lock on something people will want to know whats in it (for Them). So all I've done is put a cheapo
water tap off a 20 litre type plastic
water drum on one of the end so that people think that its a
water tank. And I keep them in home made calico rod bags to stop abrasion and I also cut some foam/sponge for the ends to custion any movment.
Swampy
317004
Reply By: Member - Netnut (VIC) - Thursday, Jul 24, 2008 at 20:29
G'day Jodie,
Why carry the weight of stormwater pipe if you don't need to?
I place my two-piece fishing rods in separate long, thin middleweight polycotton bags my wife made up on her fancy sewing machine. She even attached some tie strings at one end!
I use a short length of bungee cord to hang each rod inside the canopy roof ie: from the internal frame. I find the bungee cord better than velcro as it _Affordable_Storage_Drawers.aspx up tight to minimise vibration. I have just finished stowing my dune flagpole and long-handled shoevel in the canopy and out of the way using the same method.
Catch a bigun !
Netnut
317005
Reply By: WanderGC - Thursday, Jul 24, 2008 at 21:12
I bought for $10 from an art supply store an folio tube. Is extendable to fit what ever size rods you have. I attach
mine to the cargo barrier in with rock straps. the tube only weights a 100-200 grams so is very light.
317018
Reply By: Member - Nev (TAS) - Thursday, Jul 24, 2008 at 21:15
Hi Jodie,
I use the PVC pipe with one end glued. The other end has a small padlock (back of car). I have lined the inside of the pipe with indoor/outdoor carpet and each end with foam. Bloody fiddly to glue in place but works
well. I also put my rods in extra thick cloth rod bags inside the pipe. I haven't had any damage this way and carry both spinning and fly rods together. I have one fly rod that is worth over $600 so I like to protect my investment. Having snapped a couple of rods that were stored inside the car some years back I am not keen to do that again. I was not a happy camper when I got to my fishing spot to find both of my rods converted from 2 piece to 3 piece. My language was somewhat bluer than the
water.
Rgds
317020
