Innaminka to Birdsville
Submitted: Monday, Nov 03, 2008 at 22:16
ThreadID: 63213 Views:3327 Replies:13 FollowUps:2
Hi All,
Just doing a bit of investigation for Easter 2009 on a trip we're planning from Innaminka to Birdsville and loking into the state of the road.
Our biggest issue is our car - a 2006 Nissan X-Trail - will we make it?????
We will not be towing anything, and we will be accompanied by a land cruiser and a range rover.
Has anyone driven that recently or over easter with some advice for us?
Looking forward to the trip!
AussieScotts
Reply By: Member - cuffs (SA) - Monday, Nov 03, 2008 at 22:30
I did Birsville to Innaminka via Walkers crossing after the Birdsville Races towing an off road box trailer full of camping gear, driving a 04' X-Trail.
I was with two other vehicles and did not require any recovery, drive in auto not 4WD lock (can overheat) & plenty of momentum.
If you have two other vehcles with you, you will have no problems if you need to be snached out.
Check the weather and road conditions closer to the time.
AnswerID: 333501
Reply By: pmacks - Monday, Nov 03, 2008 at 22:34
G'Day,
we drove along that way via cordello downs in September and the road was fine quite comfortable at 80 k's and we were towing an off road camper. There was only one or two spots that were a bit ruff but generally the road was OK. Mind you that was 6 qweeks agaon and it could have changed by now
pmacks
AnswerID: 333502
Reply By: Member - Roachie (SA) - Monday, Nov 03, 2008 at 22:34
If you choose to go via Burke and Wills Bridge, Arrabury Station, then either Haddons Corner or Cordillo Downs, you shouldn't have any trouble at all unless it's been raining.
Tyres could be your main concern......if you only have the dodgy highway-type tyres that most soft-roaders come with, you could experience problems with the gibbers.
Good luck and have fun
Roachie
AnswerID: 333503
Reply By: Mad Cowz (VIC) - Monday, Nov 03, 2008 at 22:47
When we drove walkers a few months ago we could have gone most of the way in our Berlina, I wouldn't but you could then, took us about 7 hours with a few stops
MC
Carpe Cerevisi
AnswerID: 333509
Reply By: aussiedingo - Tuesday, Nov 04, 2008 at 07:31
G'day aussiescotts, we did the trip also in September, the worst road was the Innaminka end from Thargomindah, Cordello Downs road to Birdsville was a breeze. Next easter is a long way off, check when it gets closer - only needs a bit of rain! check my profile, seee yaa, dingo
AnswerID: 333543
Reply By: Sand Man (SA) - Tuesday, Nov 04, 2008 at 07:33
There are two main routes between Innamincka and Birdsville.
Via Cordillo Downs (longer)
Via Walkers Crossing (preferred route for locals)
Both routes are generally in good condition but obviously wet conditions may change at any time. If you have young kids and choose the Walkers Crossing route, plan for an overnight stop along the way.
Closer to departure time, keep your eye on the road conditions report and if there is any doubt at that time, give the ranger's office or police station a ring for final decision.
Bill
Bill
AnswerID: 333544
Follow Up By: Sand Man (SA) - Tuesday, Nov 04, 2008 at 20:46
Correction folks!
If you have young lids and choose the Cordillo Downs route, plan for an overnight stop.
Bill
Bill
FollowupID: 601449
Reply By: Member - Bucky, the "Mexican"- Tuesday, Nov 04, 2008 at 08:52
AussieScotts
Easy as, in your vehicle, just watch out for rocks, if you go via Walkers Crossing, for the last few kms, just before the Birdsville track, if you go that way.
You should let your tyres down to about 25 psi, on those roads, as it will allow your tyre to mould around the gibber/rocks, rather than bounce over them, and thus try and punch through the tyre, causing damage and punctures.
I have not done the Cordillo Downs road as yet, ...
You may have no choice, if there has been rain in the area.
Just check with the locals at the Innaminka Trading Post (general store).
We have a saved track file thru Walker's Crossing, and more, if you have a Garmin GPS, and mapsource software, and are in doubt of directions.
Bucky
AnswerID: 333558
Reply By: MEMBER - Darian (SA) - Tuesday, Nov 04, 2008 at 09:07
Agreed with much of the above - I'd invest in robust tyres too, for peace of mind - those stones up there are likely to wreak havoc on town tyres, especially if you have a decent load - and keep in mind there is a fair chance you could easily strike very hot weather still in April (a shoulder season in effect). Have a great trip.
AnswerID: 333562
Reply By: Member - John and Val W (ACT) - Tuesday, Nov 04, 2008 at 09:12
Hi AussieScotts,
If you go via Walker's Crossing - great trip - watch out for the approaches to the cattle grids. On some of them the approaches were scooped out when we were last there, so if you hit them with any speed at all (ie more than about 15kph) you got a very nasty jolt, even a tendency to become airborne.
Val.
J and V
- Albert Einstein
AnswerID: 333564
Reply By: Member - Phil G (SA) - Tuesday, Nov 04, 2008 at 10:32
I did it in a Corolla in 1978!!
Carry the extra spare tyre and try not to overload the vehicle. Your fuel consumption should be about 10 l/100k on those roads.
AnswerID: 333580
Reply By: Member - Mal and Di (SA) - Tuesday, Nov 04, 2008 at 17:35
A few weeks ago we came into Cordillo Downs from the north ie Bedourie and then down to Innamincka. The tracks that we covered would all have been suitable for a normal sedan driven to the conditions but obviously a fourby with clearance made it a lot easier.
There is a very good camp spot on a creek just east of
Cordillo Shed with permanent water and lots of bird life.
We have renamed it SONY WATERHOLE due to the fact that was the last time we can remember seeing our Sony video camera.
The coordinates are S 26 44 782 E 140 51 962. Have inserted a photo and if you find my camera a MM would be nice.
M.Image Could Not Be FoundImage Could Not Be Found
AnswerID: 333631
Reply By: AussieScotts - Tuesday, Nov 04, 2008 at 21:46
Hi All,
I'm blown away by all your replies - thanks all for all of your fantastic advice.
Look slike I'll need to get some AV tires, check the road conditions and I'll be set!
Ay more tips gratefully received,
happy travels,
AussieScotts
AnswerID: 333672
Follow Up By: ozscot - Thursday, Nov 06, 2008 at 12:37
Hi Cousins,
I also own a 04 exy, and have taken it along the Oodnadatta track and up the Birdsville then on up to Lawn hill and loads of side shoots. We are mostly on our own and tow a Cub camper.
We have yet to have a major problem worst thing to happen was a puncture on the Oodnadatta track.
We were told to drop the pressures on the Oodnadatta but told not to on the Birdsville, go figure.
We carry a spare tyre as well as a spare wheel now as it can be hard to find tyres our size out there. We use normal road tyres and like I said so far only one puncture.
We do take it easy and don't drive too fast after all we are out to see the country not watch it flash past.
I say do it and have a ball.......
FollowupID: 601696
Reply By: Member - Stephen (WA) - Wednesday, Nov 12, 2008 at 01:12
Nissan X-Trail + Walkers Crossing Track + No Rain = Easy Peasy.
VKS737 - Mobile 2735
AnswerID: 334789
